Question about Gretech GOM Media Player
Stream 3 AVI Splitter ffdshow Audio Decoder MONOGRAM AMR Encoder MONOGRAM AMR Mux -------------------- MEDIA TYPE 0: -------------------- [AM_MEDIA_TYPE] majortype: MEDIATYPE_Stream {E436EB83-524F-11CE-9F53-0020AF0BA770} subtype: Unknown GUID Name {726D6173-0000-0010-8000-00AA00389B71} formattype: FORMAT_None {0F6417D6-C318-11D0-A43F-00A0C9223196} bFixedSizeSamples: 1 bTemporalCompression: 0 lSampleSize: 1 cbFormat: 0
Windows 7 Media Player 12.0.7601.17514 configuration setting are corrupted and remain corrupted after resetting the Media Player to its default settings. How do I completely rebuild the default Media
You may be able to remove then put back WMP from Programs and Features in Control Panel. Click on add/remove features and you should see it there. Uncheck the box and apply. Restart afterwards then check the box and apply. May require another reboot.
Jan 14, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Tip
Re-encode Windows Media ASF with FOURCC of WMV1, WMV2 or WMV3 with VirtualDub
First you will require the fcchandler WMV filter in the plugins folder in order for VirtualDub to index the ASF file VirtualDub will still show MISSING CODEC after the ffcchandler has parsed the file for use, you may still be able to hear the audio that might be in WMA format you may also need to check the audio lead OR lag this can be adjusted in the advanced settings.
Two options are available to you for the WMV3 (Windows Media Video 9) download the wmv9VCMsetup.exe this will give you the required VCM (Video Compression Manager) for WMV3 only the WMV1 (Windows Media Video 7) and WMV2 (Windows Media Video 8) were exclusively intended for use with the ASF/WMV container and the DirectShow architecture. Microsoft won’t allow any encoding, decoding, or editing outside their own software without licensing and only release the WMP9 VCM through popular demand you will have to use the ffdshow filter for these.
If you want to re-encode the WMP7 and WMP8 formats I would download the ffdshow filter and set in the VFW Configuration settings for WMV to use the libavcodec GPL open source free codec library
Check out this SITE for more info on the Simple WMP9 and Advanced VC-1 profiles if you are interested for me the WMV is obsolete since MPG4 can on the scene even Sky and iPlayer use MP4 now due to is small download size.
When you have reassigned FOURCC to the libavcodec for WMV1 and 2 VirtualDub will then be able to use the ffdshow Video codec to re-encode the ASF file VirtualDub will see the VCM as the ffdshow Video Codec as shown below.
Don't forget to select the compression method I use DivX Home Video format the PCM audio is set as default so a can watch them on my standalone DVD player using the uncompressed audio will give you the best synch results. You can use the more popular and smaller AC3 or MP3 codecs but you will have mixed results depending upon the WMA audio codec anything above V2 should be ok and error free when re-encoding to your desired audio stream.
It may take a few goes to make sure that the audio is in synch for the re-encode but take time to make using the preview to make sure it is correct and add the correct millisecs of delay, you may hit it first time
It's also a good idea to install the MPG4 Windows Codec right clicking on the INF file in this mpg4vki.zip to ensure that you can play them on normal media players
If you plan on using the popular MPG4 codec DivX now at v6.9.1 then you must disable this FOURCC within the ffdshow video decoder otherwise you will encode a DIVX or DX50 file with sound an blank video let the DivX Professional Codec do the talking If you plan on using the other popular MPG4 option the Xvid is already in the libavcodec so you can select either as shown below the blue marked must be disabled if you want to use DivX Pro and WMP9VCM, the WMP7+8 shown in red using the libavcodec's
FOOTNOTE:
There is a difference the DECODER is FFv in RED and the ENCODER is FFe in BROWN is the video encoder as shown above selected on the VWF configuration menu option from ffdshow is what needs to be changed for VirtualDub's ASF and WMV needs.
on Feb 09, 2010 | Computers & Internet
Xvid for windows vista
I've spent a lot of time this weekend finally setting up Windows Vista Media Center, and I suddenly realised that Vista Media Center won't play Xvid and Avi files even if Windows Media Player will. If you want to add support for third party codecs including Xvid and Avi files in Vista Media Center then you need to install the Media Control Plugin For Windows Vista Media Center.
This plugin allows Windows Vista Media Center to utilize te FFDShow decoder, which needs to be installed seperately ((FFDShow rev 1108 recommended: download the last version from http://sourceforge.net/projects/ffdshow-tryout)). FFDShow adds support to Vista for MPEG-4 video formats like DivX, Xvid, H.264 and also alllows MP3, AAC, Dolby AC3, and OGG Vorbis audio files to be played back.
The Media Control Plugin for Windows Vista MCE also adds the following additional features:
  • Switching embedded audio and subtitles streams while playing a video: works with AVI, OGM, MKV
  • Switching between external subtitle files (.SRT, .SUB)
  • Switching between FFDShow presets (audio & video)
  • Setting and loading bookmarks inside a video with visualization of the pictures of the saved bookmarks
  • Real fastforward (and rewind) exactly like in the TV module (with 3 different speeds)
  • Switching and setting post-processing filters in FFDShow (video filters only)
  • Separate application to assign keyboard/remote control shortcuts to the commands and the MCML pages of the plugin.
  • Full remote control support (6 buttons are mapped by default, but this can be changed)
  • Default mapping (works in full screen while watching a video, except the blue button that is always caught) :
    • Fast forward / rewind buttons
    • Blue button : loads the startup page of the plugin
    • Red button : switches audio stream
    • Green button : switches subtitle stream
    • Yellow button : switches subtitle file
May 06, 2011 | Dell Computers & Internet
CANNOT PLAY 3GP FILES
There are several ways to play 3GP files. My personal favorite is VLC Media player (or if you prefer using Windows Media player, pls refer to 2)
  1. VLC ( http://www.videolan.org/vlc/) media player (freeware) is presented as the easiest solution to playing back many of the common multimedia files that are available. However, while VLC does in fact support the 3GP format, it does not include software to decode AMR audio. If your files have AAC audio then technically, VLC should be able to play your 3GP files.
  2. Windows Media Player can technically play 3GP files, but you will need to install some extra software. Firstly, the 3GP container needs to be accessible and then you also need software that can decode the video and audio (H.263, H.264, AAC, AMR). You can use either
Aug 07, 2010 | Computers & Internet
I want sound card drivers ,PCI\VEN 8086&DEV 266E&SUBSYS
I want sound card drivers , PCI\VEN_8086&DEV_2415&SUBSYS_00B41028&REV_02\3&29E81982&0&FD
Plz tell me, where can I get the drivers on internet?
Jan 07, 2009 | Compaq Creative Sound Blaster PCI 128...
How can i play AVI files on my media center/player on vista
Windows Vista Media Center won’t play Xvid and Avi files, even if Windows Media Player will play these files. If you want to add support for third party codecs including Xvid and Avi files in Vista Media Center then you need to install the media control plugin for Windows Vista Media Center.
To install the Codec please click on the below link or copy the URL and paste it in your web browser..
http://damienbt.free.fr/index.php#download
This plugin allows Windows Vista Media Center to utilize te FFDShow decoder, which needs to be installed seperately ((FFDShow rev 1108 recommended: download the last version from http://sourceforge.net/projects/ffdshow-tryout)) FFDShow adds support to Vista for MPEG-4 video formats like DivX, Xvid, H.264 and also alllows MP3, AAC, Dolby AC3, and OGG Vorbis audio files to be played back.
have any other queries, please let me know..
Thank you.....
Oct 13, 2008 | Computers & Internet
Regarding video clips
The vidios recorded in mobile phones are of 3gp format. This is different format then using windows player. You have to install Nokia Multi Midia Convertor from PC suite cd into your PC. There are more players for playing 3gp format named MMConvertor Pro. You can easily download them from free webs or can mail me patel352003@gmail.com
Jan 13, 2008 | Nokia 3230 Cellular Phone
Computers & Internet Logo
406 people viewed this question
Top Gretech Computers & Internet Experts
Tony
Abdul Mannan
Abdul Mannan
Are you a Gretech Computer and Internet Expert? Answer questions, earn points and help others
