Question about LG Washing Machines
Download User Manual for LG top loading washing Machine WFT7516LN
  • 223 Answers
SOURCE: LOOKING FOR USER MANUAL FOR WFT2400 BOSCH FRONT LOADING WASHING MACHINE
Try this website: www.bshappliancecare.com and I think you might find what you are looking for. Good luck.
Posted on Sep 26, 2008
  • 566 Answers
SOURCE: LG WM1832CW
hi linda from what you describe? the machine does wash cycle? but won't spin cycle? if the machine is a couple of yrs old ? it may well be the motor that runs machine is in need of some new brushes fitting ? they are not expensive and may be worn too low to activate the higher revolutions needed for spin cycle it is not a difficult job to drop motor off and check/replace if you have a good male/ friend? with elec competence ? have found this problem on other machines and most recent zanusi cost £5 for 2x new brushes as apposed to the £££££s the lady was estimated for a timer ? by plumber so why not check it out b4 you part with money ? best wishes/luck
Posted on Oct 19, 2008
mastatech
  • 478 Answers
SOURCE: We just purchased a top load Kenmore 800 washer
The first thing seems to be the timer,or the water level switch. Try filling the washer with water by hand, if it starts to agitate after being filled its the timer, if not it is the water level switch, let me know if you need further assistance.
Posted on Mar 13, 2009
SOURCE: LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Posted on Dec 19, 2009
blueextc3221
  • 15935 Answers
SOURCE: where is the lid cover interlock switch or sensor
First of all, unplug your washer. You will need to remove the console in order to get to the lid switch. The washer may have release tabs under the console at each front corner. Simply slide a putty knife straight in from the front at each corner and push in while lifting up. You should feel the release tabs push in and the console will pop up. If not equipped with this type of console, you may have a console that has removable end caps. They can be removed by gently prying up on the top of them from the rear on each side. You may have to use a small screwdriver for this. The caps should pop right off. Once removed, you will need to loosen a screw under each cap. Once you have the console loosened, carefully lift it up and lay it back over the rear panel of the washer in its resting position. Be careful not to damage the small plastic hinges that hold it in place. Now you will need to perform the following steps:
1. Under the console you will find the lid switch connector. Unplug the switch from the connector.
2. There will be two brass colored clips. You will need to remove these to remove the machine casing. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver away from you while holding into the groove and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Now pull the case from the frame by lifting from the back first.
You do not have to remove it all the way from the frame, just enough to gain access to the switch. All there is to the switch is a couple of screws holding it in and a ground wire. It's a pretty easy repair job. Some models will have the switch located on the right-hand side of the lid rim opening, while other models will have the switch located on the left-hand side near the lid hinge.
Once you've completed your switch installation, make sure you get the case back on the frame correctly by following these steps:
1. While looking down through the lid opening, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
LG washer drains withour washing!!!!
Call LG customer service. The unit is probably still in warranty. If not contact a certified LG repair shop and have them come examine and if possible repair the machine.
Apr 09, 2015 | LG WFT1071TP Top Load Washer
I want a user manual for LG washing machine WD-10810MDS
Try downloading manual HERE
If this information it's useful, please rate it.
Apr 02, 2013 | LG WD-1280FHD Front Load Washer
I need english owners manual for LG Top load washing machine model no.WF-T7512HN
Have you tried going to the company's website? You can probably download the manual you need.
Dec 09, 2012 | LG WFT1071TP Top Load Washer
Require an owners manual for L G -H950 top loader
Do you mean the LG WT-H950 top loader? LG' s Australia site had the manual for the washer on their support site: http://www.lg.com/au/laundry-floorcare-appliances/washing-machines/LG-top-loader-washing-machine-WT-H950.jsp . Click on the Support tab and the link to the PDF of the manual is on the right hand side of the page.
I hope this helps. If you have a different washing machine, please add a comment with the full model number.
Feb 28, 2012 | LG Washing Machines
How do i take front cover off washing machine
According to the model for removing the cover varies so here is the link for instruction.you can download your particular manual (model number)Zanussi - Washing Machine user manual, operation instructions.Good luck
Sep 28, 2011 | LG WM-1480FHD Front Load Washer
I need the manual user of LG washing machine WD TDK
You will need to type into your search engine the '(make) washer manual' and you should be presented with a number of sources from which you can either download a manual for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Feb 11, 2011 | LG WD14121 Front Load Washer
I am looking for a manual for a top loading LG Fuzzy logic 7.5 washimg machine
You can download the LG washing machine manuals in the below link
http://www.fixya.com/postanswer.aspx?thid=6467980&prdid=0&ctgid=130&ref=unsl
Oct 19, 2010 | Washing Machines
Does any-one have a user manuel or any type of manual for a lg washing machine model WFT752A please
I have checked all of my LG data and that model is coming up anywhere. Can you check the model number to be sure it is correct?
Also, can you provide a S/R number so I can cross check for the manual?
Apr 24, 2010 | LG WFT1071TP Top Load Washer
I want user manual in english for LG washing machine model WD-10660N
just search your LG washing machine model WD-10660N on google search machine and download manual of it through internet.
Dec 06, 2009 | LG Washing Machines
LG WF-T753A Top Loader washer hot water inlet valve
Just found this whilst looking for known issues with my machine as the cold water won't stop when filling.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WF-T753A-_E
Aug 25, 2008 | LG WFT1071TP Top Load Washer
Washing Machines Logo
237 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
