Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Have broken the automatic document feeder top tray and Kodak doesn't sell replacement parts. Kodak informed me to buy a newer model My 5500 works fine. Can you help lead me in the direction to buy a new or used automatic document feeder top tray? Thanks, Cliff
    Problem Solver:
Find & salvage the tray from a used 5500. I occasionally find items thru ebay, craigs list (by placing a wanted notice), computer repair or recycling centers & even goodwill stores. Alternatively see if the tray can be fixed or modified.
Posted on Oct 14, 2010
Testimonial: "great answer"
How do you get the rear-access door open to clear a paper jam? The model I have is a KODAK ESP5210
Remove and inspect the paper tray.
CAUTION: Do not place the printer on its top or right side when you remove the paper tray. Ink could possibly leak into the printer and cause damage.
  1. Turn off the printer.
  2. From the back of the printer, disconnect:
    • power cord
    • USB cable (if used)
  3. Turn the printer on its left side.
  4. Open the paper tray.
  5. From the bottom of the printer, do the following depending on your printer model:
  1. Check the paper tray for the following:
    • surface scratches
    • bends
    • ink contamination
    • broken parts
  2. If the paper tray is broken, contact Kodak to order a replacement, otherwise do the following:
  3. Install the parts that were removed in Step 5.
  4. Place the printer upright.
  5. Connect:
    • power cord
  6. Turn on the printer.
  7. Make a print to check the functionality of the paper tray.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Mar 18, 2011 | Kodak EASYSHARE 5500 All-In-One InkJet...
Need to replace broken paper tray. Does parts manual show how to order.
You can buy them on ebay like the following link. Kodak does not sell the part on its own. Printer is to cheap for that.
http://cgi.ebay.com/Kodak-ESP-3-ESP-5-Paper-Tray-/200578575161
Mar 07, 2011 | Kodak ESP 5 Printer
Paper jams
Paper jams - Kodak Printers
Feb 19, 2011 | Kodak Office Equipment & Supplies
My lcd is broken cab it be rreplaced or fixed?
It is not possible to buy a viewing screen directly from KODAK.
Because the camera has been dropped KODAK might determine this fault as Out of Warranty
An Out of Warranty repair for this model for this fault is about 48 pounds + shipping. KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
In order to arrange your repair/Trade up: Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Jan 15, 2010 | Kodak EasyShare C913 Digital Camera
Brother MFC8440 - Left Hinge Assembly broken
Brother will not sell to end users, contact a Brother Dealer in your area.
Jul 26, 2009 | Brother MFC-8440 All-In-One Laser Printer
Faxing
if using the feeder probably face up as it will likely pull the document in and invert it to lay face down on the scanning glass.
if you lift up the feeder (like lifting the top of a copy machine), then it would be face down on the glass.
there should be an image on the feeder illustrating how the document should be placed - if it looks like a page with lines on it with a bent corner then it is face up.
Apr 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
How to replace Hinge assembly of Automatic Document Feeder
You can try to get a hinge @ a local authorized brother dealer. I just got mine for 20 bucks, I think that the guy ripped me off, but I needed. Once you get it, it is very easy to replace. 1St, replace the old one by removing the screw in the back of the hinge (back of printer). then pretend that you are lifting the whole automatic feeder up. At this point you will see the right hinge looks likeit it coming out. Don't pull it out completely. Just pull it enough that you can flip the feeder enought so you can uncrew the 3 screw attached to the feeder. Once you remove the broken part, install the new hinge. make sure that you screw hinge first before you slip it down to the bottom hole then screw the hinge to prevent it from moving.
PS: try not to flip the feeder too far back
good luck
Mar 23, 2009 | Brother MFC-8440 All-In-One Laser Printer
How to fax
First you need to get the fax service activated with your phone company. Make sure that you do not have distinctive ringtones nor voice mail activated on your line, because these features are not compatible with the 5500 printer.
Once you got that, then you need to:
- Put what you need to fax on the ADF (automatic document feeder)
- Press the FAX button on the printer
- Dial the number (including area code)
- Press the START button
And your fax should get going.
Nov 19, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Broken Black Arm on Scanner Attachment (Detects insertion of documents)
Unfortunately, you can't buy the sensor finger by itself. You need the DADF Assy.
Duplex Automatic Document Feeder Assembly
Part Number: 004K07270
Jun 04, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Top feeder won't work properly
hello!
have you tried cleaning the separator pad inside the automatic document feeder?
try to Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
If the problem persists, clean the rollers and separator pad manually
May 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
125 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
