Question about Dryers
We have a GE DPGT750ECPL Profile Harmony electric dryer. When you turn it on it gets hot and rotates like its supposed to however, there is no air blowing so the clothes are not getting dry. Could this be a fuse or is there a fan that isn't working?
    President:
  • 2,468 Answers
The blower wheel inside the unit is either broken apart or the wheel on the motor shaft is stripped or jambed in place and can no longer rotate
Posted on Oct 14, 2010
How do I clean lint from inside GE Harmony Profile Dryer?
You have to remove the panel. The assume the lint filter works better then they usually do and do not make it easy to open up and clean inside. You may have to open it from the back side which does open up to allow repairs, etc.
Aug 12, 2014 | GE Profile Harmony DPGT750ECPL 7.3 Cu. Ft....
My GE profile harmony dryer blows cold air on any setting do I need to replace heating element?
Yup...heating element (usually there are two) is done. Likely the first one was done long ago and the second has finally died.
Dec 03, 2013 | GE Profile Harmony DPGT750EC Electric...
My GE Harmony dryer has stopped heating. All of the cycles work (air comes out), it just wont get hot.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | GE Profile Harmony DPGT750EC Electric...
My GE Profile Harmony Dryer is no longer Heating
Does it get hot when you turn it on, and then never gets hot again while its running? On my dryer the solenoid broke, when the dryer was cold it worked and the dryer operated properly because the dryer and solenoid were cold and the solenoid wire was closed, when the dryer was hot enough the solenoid opened and the heat would not restart. the solenoid is a coiled wire which is used to open the gas valve.
Dec 28, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony Dryer Drum will not turn
the inertia switch on the shaft of the drum motor has failed This will require removal of the drum motor
Jun 01, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Harmony Profile Electric Dryer
Try this - page 13 especially http://products.geappliances.com/ProdContent/Dispatcher?REQUEST=SKUOBJECTS&DOCUMENT=Use%20and%20Care%20Manual&SKU=DPGT750ECPL or call these guys - they might tell you. http://www.geappliances.com/service_and_support/contact/ hope this helps
Mar 01, 2007 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
101 people viewed this question
Top Dryers Experts
