Question about Philips Televison & Video
The base plate of my tv shattered and needs to be replaced where can i source a that part
    Problem Solver:
  • 87 Answers
Call a tv repairman
Posted on Oct 14, 2010
Where can I get a base gear for a magic bullet
perhaps from the manufacturer. that wold be the only source I can think of
Aug 03, 2016 | Blenders
LG 32 inch lcd tv. When you turn it on, the screen (no picture) looks like a shattered window. The set is not hooked up to cable, channels aren't set yet. I just bought the tv for my son.
You need to hook this set up to viewable source to verify if there is a defect.
Then select the source, and check for problems, then.
Is the set used or new?
Brian
Aug 02, 2008 | LG Televison & Video
How do i remove the mirror glas on the right door mirror without shattering the glass to get to the motor assembly?
It is very difficult NOT to break the glass when taking it out. You would need a specially made flat hook tool to get in behind the backing plate to lever it off. They usually only clip into place. Price a replacement mirror and back plate. For the cost it might be cheaper just to shattering the old one and replace it once the motor is repaired.
Jan 19, 2018 | Cars & Trucks
Need to replace bulb
Remove and examine the lamp this set (based on model indicated here) uses---is it intact or shattered inside?
Easy to get at and instructions are in the owner manual.
Apr 19, 2012 | Toshiba 65H82 65" Rear Projection...
Picture tube is discolored almost like a shattered glass appearance?
That shattered looking glass effect is your LCD panel shattered. Your panel needs to be replaced. Would be more cost effective to replace your TV.
May 12, 2011 | Vizio L32 32 in. LCD HDTV
Glass turntable in tricity tmc209 says "microwave only" What do I use for convection or combi cooking? Does turntable still need to rotate for convection cooking?
definately dont use the standard glass plate for convectional 'oven' cooking, as it will shatter. i have had TWO plates shatter so far before realising they should only be used for microwave cooking.
Aug 15, 2010 | Microwave Ovens
The glass plate in my microwave shattered and I need to get a new one.
Go to "sears.com", click on "Parts Direct", another page will be displayed, enter you model number (usually found just inside door of microwave), select cabinet and you should see your glass plate listed, scroll down to required number and then you will see the part number. Copy and paste that number into search engine and look for best price or just buy from sears
Oct 17, 2009 | Microwave Ovens
I have samsung DLP, when i turn it on it makes a lound continous sound from the back of the tv, no pic
This set uses a color wheel, part number is:
BP96-00674AYou can remove the lamp and look where it faces--it is a round plastic wheel with segments that are different colors---if you remove the lamp and look in the direction it faces(you may need a small mirror to look) if it is shattered or missing segments of the round wheel---it is your problem.
If it is shattered or damaged you are lucky--Samsung sells this part separate---it is located in the optical light engine--you can find instructions for replacing it on the internet--if you decide to do this let me know--I know a few tricks to a good replacement of this kind of part. From Samsung it is about 125 dollar part---You can search on Ebay with your model number(or the part number) and find it for much less---search the part number I gave you there and you will find it. This wheel turns at 14,000 rpm and they eventually lock up and or shatter. The set will detect no motion or improper motion of the wheel and may shut the set off.
I do this here for free, so if this helps you give me a vote here---IF you have any questions or need more help--contact me here.
SD TECH (San Diego)
Aug 28, 2009 | Samsung DLP HL-P5663W 56" TV
Shattered glass top for Hotpoint range/ how to replace
Hi there!
There are two basic types, Flush fitting and framed.
The framed versions are a bit like a picture frame, with the fixings around the edge and back. The flush ones rely on adhesives to the base edge around the plate, but may have a metal fixing frame attatched already.
Check the new plate you have to see if there are any keyhole shaped slots on a subframe (indicating a drop on, and push forward to lock arrangement) or if it looks different to the one that is broken.
The old saying - "If in doubt- ask" is true here, and you should telephone the manufacturer for any specific fitting instructions. You may need additional parts - fixing plates, screws, seals or adhesives, so I would advise calling their service department to ask if additional parts are required for fitting.They should be happy to supply them if needed.
This is not a cheap item, so don't risk poor fitting or damage by lack of correct parts.
Jun 15, 2008 | Kitchen Ranges
Russell Hobbs HOB CTS34 - Faulty glass plate
Door glass broken on russel hobbs 28lt micro wave. Any idea where I can have this replaced. thank you
Mar 15, 2008 | Microwave Ovens
Televison & Video Logo
29 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
