I cleaned the exit hose (yes, it was full of **** ...) and the filter but still the same problem (End LED blinks 5 times and nothing else happens) remains. Any idea?
something has to come out the other end. where do you think the water is going? it has got to go outside, if not it will end up in the condensate tray and shut off your unit if you have a float switch.
PLEASE TRY THIS, Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once. 1. Start with printer OFF 2. Hold down RESUME and then hold down POWER 3. Release RESUME 4. press RESUME twice, then release POWER 5. let green light blink until printhead has finished moving. 6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960) 1 press - orange light - EEPROM info print 2 presses - green light - EEPROM initialise 3 presses - orange light - reset waste ink counter
Pressure switch error code, Check the air filter for blockage, check the vent pipes for blockage or water, make sure the condensate drains are working and that there is no water in the hose(s) that go to the pressure switch(s).
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 5 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped.
Check your drain with a good pour of water from a bucket, it must clear fast. It it doesn't snake it out; the prob lies there 99%. And don't push your exit hose too deep into the standpipe, 4 to 5 inches & not air tight.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped. Click on 'thanks for trying' if not helped, your prob will be back for someone else to solve. (Companies just want you to dump the machine & buy another, its keeps them in business)
Press "end of cycle" button to clear the screen.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Press "end of cycle" to get machine to normal. Then plug off the wall.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. To open door, press "end of cycle", wait for 2 minutes or till you hear distinct click; do not force door.
Press "end of cycle" for 5 seconds or more to clear the screen.
