Question about LG L1730S 17" LCD Monitor
I have lg flatron l1730s lcd black color monitor. I have problem with this. Power not come. some time when i connect it power LED blinking once then no display. Some time when i connect it power LED blinking long time (minimum 10 mins). then display coming when i get long blink in power LED then only moniter working. I bring with me this moniter to service center when they connect it , its working properly. After that i bring it to home then i connect it same problem is comming. i re-assembled my CPU. one time i got display after long blink in power LED. then i properly connected my system then started it not working please give me a solution where is problem my CPU or my MONITER (but service man told moniter no problem). please give me immediate solution....
Posted on Nov 11, 2010
I also experenced same issue...but i replaced all electrolytic capacitors in power output section...then it work normally..but after few days same fault come agian.
any one know solution for this fault..
Dumi
Posted on Oct 06, 2011
I dont have driver flatron l1730s lcd monitor . usb driver monitor
You may be able to download the driver from these WEB sites.
http://totallydrivers.com/device.php?id=74496&show_devs=a
http://www.bravofiles.com/driver-LG-FLATRON-L1730S.html
Apr 06, 2011 | LG L1730SF 17" LCD Monitor
Lg FLATRON LCD L1730S (L1730SSNTM-AL**E power
Here are the service manuals, please look through them. Please note that if the power supply is not made by LG, it will not show the information in the service manuals.
http://elektrotanya.com/?q=showresult&megnev=LG&megnev2=L1730&kategoria=&kat2=schematics
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Please leave rating if it helps.
Jan 19, 2011 | LG L1730SF 17" LCD Monitor
I didn't get disply on my lg flatron l1730s lcd monitor
Connect it to a different computer, to see if the monitor works at all.
Connect a different monitor to your computer, to see if your computer's video-adapter is working.
Nov 06, 2010 | LG L1730S 17" LCD Monitor
LG Flatron L193ST. Relatively old model. The monitor screen stays dark upon connecting with a power socket and the power LED blinks rapidly in a yellowish amber colour. A quiet pulsating sound emits from...
L193ST common problem!! solution is only by replacing 2 capacitors 470uf 25v located on the power supply pcb inside the lcd they are neer the long cable connector
remove the 8 screws from the lcd back panel including the holder screws,
use a thin metal stick like a knife and insert it between the back pannel and the front black panel but slowly remove the black panel not to scratch it
remove the metal protection panel 4 screws
the power pcb becomes visible
remove all connected plugs and the 3 screws
desolder the 2 capacitors and replace them
assemble back your lcd and enjoy
30min time of work 5$ cost
Sep 06, 2010 | LG FLATRON L1950B-SF 19" LCD Monitor
LG Flatron - green power led blinks twice
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.badcaps.net
May 21, 2010 | LG Flatron L1750S 17" LCD Monitor
How can I restore factory settings on our LG Flatron LCD Monitor?
press menu button it is in middele of lcd.
Ten go to setigns and u can fine reset buton press ok.
Jun 13, 2009 | LG L1730S 17" LCD Monitor
My lg flatron L1730S, the screen shows some different color
1. Solder the neck board dry points (cromo IC )
2. display cable connector.
Dec 20, 2008 | LG Flatron 915FT 19" CRT Monitor
L1750s 17"
This problem is showing when the main PCB of the monitor failed. contact the LG service provider in your area. Here is the link to get the service center info
http://www.lgservice.com/
Dec 31, 2007 | LG Flatron L1750S 17" LCD Monitor
LG L1730S 17" LCD Monitor Logo
1,136 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
