Question about Frigidaire FRT21P5A Top Freezer Refrigerator
I purchased a stove and fridge from frigidaire in june and am having a hard time to fix the temperature in the freezer. Ice cream is so cold that you would have to use a hack saw to get some. Please tell me where I should set the temperature in the freezer. Also it runs so long all the time. Sometimes even when I open the door and close it it starts to run sometimes it runs for 3-4 hrs. Please help me as this is very annoying. Thank you.
  • Frigidaire Master
  • 1,830 Answers
Make sure you set the temperature on or a little past normal.
We have a fridgidaire also.
Posted on Jun 26, 2017
fridgetech
  • 473 Answers
SOURCE: New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Posted on Oct 07, 2007
TheMobilian
  • 8220 Answers
SOURCE: freezer not keeping ice cream cold
One thing you can do is clean out the area under the ice box where the condenser coils are located. Make sure the fan motor is blowing under there. Clean the kickplate. Get the air restrictions out of the fins and that may bring the freezer temp back up to par.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 08, 2009
tborn6
  • 700 Answers
SOURCE: Freezer door not sealing well (Frigidaire side-by-side)
your house may be settling and now the refrigerator needs to be tiloted back slightly. take run the adjusters on the front in a little until the doo closes by it self.
Posted on Mar 29, 2009
  • 323 Answers
SOURCE: We have a FRS28XGCW. The freezer started freezing
unplug unit to do a reboot, have the settings where you are happy
Posted on Nov 27, 2009
heatman101
  • 43501 Answers
SOURCE: Freezer and Fridge are both not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
hhsg
Posted on Sep 29, 2010
Ice maker makes very little to no ice.
If the freezer temp isn't cold enough it won't make ice if you can check temp it should be close to 0deg f. . if you don't have a temp guage us you ice cream hard it probably cold enough. The frigidaire ice makers fail often
Oct 19, 2015 | Frigidaire Refrigerators
Hi. My fridge is about a month old. Although we have the freezer set at 8 degrees (the warmest it will set to), the freezer is extremely cold. Ice cream becomes rock hard (we can't even cut it with a...
This is not an adjustment issue, this is a malfunction issue. If you have a thermometer that you can place in the freezer, as opposed to any temperature readings from the freezer itself, your temps would normally be around 0 degrees F. At the warmest freezer settings, you should be around 10 degrees, which would make your ice cream very scoopable. I would contact the store you purchased it at or Samsung for a refrigerator repair service as soon as possible before they tell you its no longer covered under warranty.
Oct 04, 2010 | Samsung RF265AA Bottom Freezer French Door...
It runs to much
1) Are the temperature readings you give measured with a thermometer, or just the temperature settings you set the freezer and refrigerator for?
2) Ice cream "stays frozen, but not hard", I'm not quite sure I understand you point. Ice cream will usually stay solid enough in a refrigerator/freezer to be easily dip able. Frozen hard is not normally good as you can't dip it. Please confirm what yu are wanting.
Dec 10, 2009 | Frigidaire Refrigerators
The temperature is set on high in both the refridgeerator and the freezer but it will not freeze things like ice cream its not cold enough and in the fridge things are not as cold as they used to get. Is...
Make sure the compressor fan is not rubbing against anything and there is proper air flow to cool the compressor. Remove all dust. Also make sure you don't keep too much food in the freezer to inhibit the circulation of cold air.
Jul 13, 2009 | Frigidaire FRT17G4B Top Freezer...
I have a Roper RT21LMXKQ00 Freezer wont freeze
The problem is a defrost problem. The freezer coil has frost on it and thus restricts the cold air from flowing. This affects the refrigerator as it gets its cold air from the freezer. The ice will not make if the temperature is above 12*F and this also is why ice cream is like mush.
Apr 23, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
heatman101
hhsg
Jan 30, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Freezing problem
I think you mean that milk freezes, etc.
Probably bad thermocouple. In the refrigerators I'm familiar with, there is a thermocouple thermostat in the freezer. There is no measuring of refrigerator temperature; it just gets a portion of the cold freezer air.
If the thermostat is bad, then ice cream should be rock hard too, for it never quits cooling except on defrost cycle, three times per day.
Jun 16, 2008 | Candy CPCA270FFK Bottom Freezer...
Appliance: Frigidaire 3.1 Cu. Ft. Compact Refrigerator Problem: How do I adjust freezer temp in my mini-fridge with top frost free freezer, has turn dial for refrigerator but no turn dial for freezer and...
The turn dial that controls your fridge temp also controls the freezer temp. The freezer air is directly forced into the freezer compartment and then sent to the reigerator. Adjust the dial for the fridge not to be so cold and it will adjust the feezer also. Allow about 24 hours for any noticeable change.
Apr 19, 2008 | Refrigerators
Frigidaire FRT21P5A Top Freezer Refrigerator Logo
37 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
