Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
SONY KDF60-XBR950 SOUND BUT NO VIDEO. SCREEN LIGHTS UP FROM BULB, BUT HAS NO SIGNAL FROM LIGHT ENGINE. ALREADY CHANGED G1 BOARD CHECKED THERMAL FUSES AND ALSO CHANGED QM BOARD. COULD THIS BE A BAD DIGATAL BOARD IN DIC2 BLOCK?
  • dstarnes001 Oct 14, 2010
    are you reffering to digital board? if so is there a check procedure before i order new one. the board that i am refering to is 1-689-269-31
  • Sony Master
  • 6,993 Answers
yes, the problem could be a bad signal board or display board of the TV. Changing this will help the TV show pictures again.
Good luck.
Posted on Oct 14, 2010
  • Walesarumi
    Walesarumi Oct 14, 2010
    the only procedure you can use to test is if you can test it on another TV that is the same as your or test your board on another TV, by so, you will know whether it is defective or not.
Blue clouds on screen, already replaced main bulb still getting worse. Please help.
Light Engine is Bad, Sony had alot of these that went bad. Sony Offers replacement TVs if this is the case. Go to Facebook and then type in I HAVE A DEFECTIVE SONY TV. Sony has a FB account and they will get back to you about a replacement TV. Sometimes they will offer you a 55inch LCD in replacement on the old DLPs.
Oct 08, 2012 | Philips Sony Kdf60 Wf655 New Lamp 1 Yr...
I have a Sony ProjectionTv w/ a rolling screen issue...
Your haveing problems with the signal board just had this problem sometimes its bad connections check board that has all your jacks on it or were it plugs into the main board
Mar 04, 2010 | Sony KDF-50E2000 50" HDTV
My right rear signal is not working i changed the bulb and checked the fuse (i think) cant find manual
Check the relays or fuses to both the signal light, emergency lights, and parking-breaking lights . All of these are tied together. Also try to see if the contacts of the bulb are making contact with the plug at the bottom. Do this by turnining on the signal and pushing down on the bulb. if it lights. replace the plug.
Nov 18, 2009 | 2002 GMC Sonoma Extended Cab
No left turn signal
CHECK ALL BULBS, SOME HAVE A SLIGHT DARK SPOT ON THE BULB AND IS BAD AND FLASHER COULD ALSO BE BAD. CHECK THE FUSES TOO.
Jun 10, 2009 | 2002 Pontiac Bonneville
Brake lights wont turn on.1994 gmc sierra.
This may sound too simple, but first verify that you are getting voltage to the light socket. Use meter on d.c. If you are getting voltage, and your bulb is good, it could be a bad ground. Don't overlook the brake light system goes through the directional signal in the steering column.
Jan 19, 2009 | 1991 GMC Sierra
My flashers do not work and/or light-up
The flasher is in with you fuses under your dash. Turn on the blinker and follow the sound. If it wakes any sound you will be able to find it easy, if not I think it is toward the bottom, in the middle of the fuse panel.
Jan 18, 2009 | 1993 Buick LeSabre
Sony kdf e60a20 - Light is blinking red, blew out the dust on the screens of lampbulb, worked right for a day and a half then started shutting down again, do I need a bulb or the thermal fuse? And if I do...
there could be a few issues.here are a list of things that could go wrong plus part numbers you wanted.
pn# 191002393 thermal fuse
pn# a1085447abarc bulb without housing cheaper
clean fans
other things that cause this:
dmd board or light engine my guess would be bulb and thermal fuse. thanks doctor video
Apr 28, 2008 | Sony KP-53S65 53" Rear Projection...
TV turned off by itself and now blinks red led 6 times
6 blinks means a low B error. Which is no DD 6volt output on G1 board . This will cause no picture and no sound. To fix this yourself you would need the manual to get the correct sequence to test and proper part to order. You can get a service manual for 10.99 at the following link and they will ask if you'd like it emailed to you after purchase. Here is the link,
http://servicemanuals.vstore.ca/
Feb 01, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA 50 or 60 inch, 6 blinking lights
Hi, you can find that info & buy the parts here, www.wehaveparts.com good luck it`s not an easy job take pictures if you have a digital camera, BMW Rider
Jan 14, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
90 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
