Question about Refrigerators
We want to remove ice dispencer unit from door to install a wood panel on refrigerator and then re-install unit. Don't know how to remove molding around ice unit.
  • 5 more comments
  • jpandpatti Oct 14, 2010
    Frigidare Model # FPCE24VFW
    This is not what I am looking for. On that outer part of the door I want to install a wood panel. I want to remove outer unit so I can install wood panel then re-install ice maker unit on outer part of door.
    Waiting on your reply
    You don't understand my problem. I am installing a wood panel on the outer side of the door. I want to remove the outer electronic panel so I can install the panel,then re-install the electronic panel. This is the outer side of door.
    Come on I am running out of time . URGENT
    I want to remove outside eletronic panel from outer door to install a wood panel. Then I will re-install electronic panel.
    thank you succesful
  • Refrigerators Master
  • 8,220 Answers
Posted on Oct 14, 2010
  • Dan Webster
    Dan Webster Oct 14, 2010
    Aha frigidaire. You know the drip tray? It pulls straight out. Under it is the screws you remove.
    Let me know
  • 17,970 Answers
Send us the brand and model, please.
  • ZJ Limited
    ZJ Limited Oct 14, 2010
    You can un-mount the ice maker by just removing the 2 screws on the left
    side of the interior wall, then you will see a connector plug to
    disconnect it, just un-snap the connector plug, and thats it.
    It will take some time to cut all of the plastic out from the ice maker ejector arm, but thats all you do.
    Keep us updated.
Ge will not dispence water or ice and the light on control panel blinking green cannot change from ice to water.
at the bottom of the door is a grill remove and check the wireing plug for corrosion if it has a lot of green around it you will have to hard wire it wire for wire has bad connection .
Sep 21, 2014 | GE Refrigerators
GE adora side by side French door ice maker keeps freezing up and led light blinks. Have had repairman several times for same problem. Can I removed unit to thaw?
  • Possible solenoid fill valve failure
  • Possible failure of the mold heater, not allowing the ice to be removed from the mold.
  • Possible failure of the mold heater thermostat
Aug 30, 2014 | GE Adora (DSF25KGTBG) Side by Side...
Not dispencing ice
YOU WILL NEED TO CHECK FIRST FOR WATER IN THE MOLD OF ICE MAKER(WHERE CUBES ARE MADE). THEN MAKE SURE THE LEVER THAT TELLS WHE THE ICE MAKER IS IN THE DOWN POSITION
Jul 08, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do i access the ice dispencer door in the door? The door is stuck open and freezes up the dispencer.
1. Disconnect the unit from the electrical
supply and wait for 3 to 4 hrs to get ice melted.
2. Pull out and unclip the drip tray on the ice
and water dispenser compartment.
3. Remove the screws from the ice and water
dispenser compartment front panel and
turn it over. The selector switch pack and
dispenser switches are now accessible for
testing.
Jan 29, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Maytag side by side w/ ice and water dispencer. Have been having intermittent problems with unit not dispencing water and not making ice(water not filling in to ice tray)unit is now making ice but...
YOU COULD HAVE A BAD WATER VALVE OR YOUR TANK IS CLOGGED UP AND STOPPING THE WATER FLOW THROUGH THE LINES. MOST MODELS HAVE A TANK IN THE BACK OF THE SHELVES ON THE REFRIGERATOR SIDE DOWN AT THE BOTTOM. IT WILL BE LOCATED BEHIND A PANEL YOU WOULD HAVE TO REMOVE SHELVES AND SCREWS TO GET TO IT BUT FIRST CHECK VALVE SOME SYSTEMS HAVE MULTI VALVES WHERE ON CONTROLS THE ICE MAKER AND THE OTHER ON THE DISPENSER.
Dec 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
Lcd screen flashing 88 8Y
I have a samsung french door that was also displaying 88 8Y and found out that it's an error code for the ice maker, I removed the wire cover, disconnected the ice dispencer connector, and then removed the ice dispencer, made sure nothing was stuck inside, plugged in the connector, pushed the reset button, and then put everything back. Unplugged the unit for about 20 min, and when I plugged it back in everything worked. I can't take the credit for this, a thread at applianceguru.com/forum1/8630.html helped me out on this one.
Apr 16, 2010 | Samsung RM255LASH Side by Side...
Ice maker will not make ice cubes, only crushed ice.
take out your ice bin the look in the back of the freezer and ytou will see a small hole with a plastic sqaure actuator.hold the door switch closed and make sure the unit is selected for cubed ice then try and dispence ice if the swaure plastic acuator moves up it is working fine it shoeld drop down when you release the dispencer arm.if it dropps back down then make sure that the metal bail arm is properly inserted into the hole in the auger case when that actuator moves up this opens the small plastic door on the ice bin to allow subed ice to come out.make sure there is no ice build up on the ice bin that would stop the trap door from opening.good luck with you fridge i hope this helps you out,let me know how thing s go for you.
Jan 20, 2010 | Frigidaire FRS23H7C Side by Side...
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Ice maker does not work
the lighs are normal if you have no ice then is something else ok remove the cover infron of the ice maker there you should see the the ejector it looks like spikes or forks ok they should be facing you if they are facing down into the mold then you have a broken module in ice maker now there isa fill tube on your right that fills the mold with water squeeze it is hard or soft if hard then is frozen keep it from filling the mold de ice it with hair dryer or unplug unit for a day or so . next if spikes are facing you and there is no ice then you have to trouble shoot the water valve at the back of unit there are 2 selenoid 1 for dispencer and 1 for ice maker locate the one for the ice maker and apply 12o volt directly into selenoid if you get no water replace it. if you get water repl optic board that is the red lights ok
Nov 28, 2008 | Refrigerators
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
