Question about Akai LCT3701AD 37 in. LCD Television
Im looking to wall mount my tv but have noticed the 4 wholes in the rear dont look like they take screws. That cant be right? Inside the 4 whole are 2 further holes that have screws in, Which do I use and what is the solution. Kind regards Ben
  • 998 Answers
Try to look for the other parts look for metal bracket the one you mount in the wall.
Posted on Oct 14, 2010
Size of wall mount for GPX LED HDTV
Not sure what you are asking. Are you looking for the screw for the attaching the mount to the TV or the mount to the wall.
If you are looking for the screw size for the back of the TV, it could be metric size M6 or M8. Just be careful of the length. Too long and you will ruin the TV. Maybe google the TV model and it might show in the owner manual the exact screw to use.
Apr 18, 2014 | LG 42LG50 42 in. LCD HDTV
Do you know how to put this tv bracket on the wall?
Yes you will need a stud finder and a drill . Find you're studs in the wall. Mark them. Then you're gonna want to locate we're you're gonna want you're tv. The height. Put you're mount up to the wall making sure the whole that will holding the screws that go into the wall are over you're studs. Get a marker mark the wholes. Then get you're drill and drill in you're screws. If the screw are real thick then I would juggest drilling pre holes this way you're studs do not crack
Nov 01, 2012 | Televison & Video
How do I remove the base from the TV so it can be wall mounted without leaving the stand attachment attached to the TV
depends on what TV you have. Most TV models i've dealt with, you need to remove the whole back of the TV and take the base out. Some smaller LCD monitor bases like Dells are attached only by a latch. Some bases are held together by 4 screws where the VESA mount would go.
Mar 22, 2011 | Computers & Internet
Having difficulty getting old spacemaker oven out in order to install new.
There are two screws coming into the top front accessed inside the cabinet it is mounted to. the rear of the unit is hung on clips on the bracket screwed to the wall behind it. Take out the two screws ( sometimes hidden under paint or shelf liner) and have someone hold the front up. Then push up on the whole oven and pull it out towards you. ( get help it is kind of heavy). dont forget to unplug it, and feed the cord down as you pull the microwave out. sometimes you have to pull hard, as the pins on the bracket get bent during installation.
Nov 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I am trying to mount my LG 37" on the wall and cannot figure out how to remove the stand that came with the tv
37LG30 - loosened the 4 screws on the back of the TV but base mount wouldn't come off. Found that had to remove the screws even though already loose so that doesn't bind in the holes. Did this by making the loose screws bind in the wholes. Using twisers in the whole would have done the same thing. o
Dec 27, 2009 | LG 37LG30 37 in. LCD HDTV
Cant find how to remove the stand on our newly purchased Soniq QSL323CT1 anywhere in the manual. We are trying to mount it on the wall.
1. Disconnect all cables.
2. Cover a level and stable surface with a thick and soft cloth.
3. Gently lay the TV, face down, onto the cloth. Make sure the Table-Top stand is hanging over the edge.
4. Rotate the cable holder 90 degrees, and pull it out completely.
5. Remove the screws (3 or 4 in rear next to cable holder, depending on which model wall-mount kit you have) being sure to hold the Table-Top-Stand firmly while removing the last screw.
6. Do not remove any other screws from the TV.
They also say not to remove the stand for any reason other than wall-mounting the TV. Their should be instructions with the wall-mount kit.
Hope this helps!
Thanks
Smith.
Sep 07, 2009 | Televison & Video
Just bought a insignia ns ltdvd26-09 will it mount to wall
I took 8 screws out from back of set just above stand, the bracket fell off.
Be sure to put the screws back in
Feb 08, 2009 | Insignia LCDTV26 26 in. Television
Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Jun 29, 2008 | Insignia LCDTV26 26 in. Television
How do i attach a Wall Mount to the TV?
Hi, Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side. these are for universal mount. http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp I think this clears your problem regards sreejith "Please use caution if wall mounting this product. Follow all directions from the manufacturer of the wall mount and be sure to securely fasten the product to the mount. While the TV can be wall mounted, improper wall installation may void the warranty."
Jul 16, 2007 | Akai LCT3285TA 32 in. LCD Television
Akai LCT3701AD 37 in. LCD Television Logo
125 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
