Question about Camping, Backpacking & Hiking
Trying to find replacement VEC 191 batteries.
This page on the Black-Decker website has parts for the VEC117FS Spotlight. http://servicenet.blackanddecker.com/Products/Detail/VEC117FS
Posted on May 29, 2012
2 Suggested Answers
CarlGlas
  • 283 Answers
SOURCE: My Vector model #VEC117FS has a battery that is
There are many companies on the Internet that offer Sealed Lead Acid Batteries, which may be less expensive than replacing the light. I would suggest identifying the particular battery your light has and then check what's available on the Internet to make a decision on whether it is cheaper to replace the battery or the light.
http://www.batterywholesale.com/battery-store/SLA-batteries
http://www.batterymart.com/c-sealed-lead-acid-batteries.html
http://www.atbatt.com/sealed-lead-acid-batteries.asp
http://www.zbattery.com/Batteries/Sealed-Lead-Acid
http://www.planetbattery.com/product.asp?id=10
Posted on Nov 13, 2010
Where can I order a replacement charger for vector trailtracker sport lantern/weather radio model VEC 1198POB
If charger can be taken apart and the battery removed, try Batteryspec.com for a replacement battery. Worked for my Vector.
Aug 15, 2013 | Black & Decker 50 Watt Electromate with...
Alarm #191 open cell voltage powerware 9130
Remove the front panel plastic cover where the batteries are located, then plug the two connectors together, restart the UPS, and it should be fine.
Aug 13, 2013 | Powerware Series 9 9170 UPS System
Alarm error #191 comes from a battery test, where batteries are put under load for 25 seconds. (If the alarm is unexpected, you might have enabled the periodic 30-day battery test.)
#191 is test failure for battery internal resistance. So, need to locate and replace the bad battery, then run the battery test manually. If batteries are good, make sure no battery connector is corroded or loose.
Feb 04, 2013 | Powerware Series 9 9170 UPS System
Alarm #191 Battery test failed
Shut down the UPS and replace the batteries.
Jan 15, 2013 | Eaton Powerware 9135 UPS (700465495) UPS...
Vec 1097 A battery charger always give cod F03 with any battery
The battery in question so bad it wouldn't even register on the charger unit to any degree. I know this makes no sense, and kinda negates the whole point of even having a battery charger to begin with, but I learned of the battery it's attached to is too bad it won't even allow you to do ANYTHING with it.
Dec 06, 2012 | JUMP START SYSTEM
No work is done by gravity on a bowling ball that is rolled along a bowling alley because why?
If the bowling alley is perfectly horizontal, the center of gravity of the ball will remain at the same height measured in a fixed system of reference. As you know the gravity force is directed vertically downward. To calculate the elementary work of that force you evaluate the inner product dW= vec(g).differential of vec(5). However since the displacement vector vec(r) remains in a horizontal plane ( Prependicular to the direction of vec(g), and the ball does not bounce and leave the horizontal plane) the angle between vec(g) and vec(r) is equal to 90 degrees. the inner (scalar product is =0).
A simpler way to remember it is that the work is equal to g*(difference in height)
Jan 07, 2012 | iPhone Apps
I need to replace the fan. Where do I find one.
you may find that walmart has those for under 20.00 and a fan is 25.00 and you take a huge risk of electric shock and damage to your car or equipment trying to do a stupid pos inverter, get my drift?
walmart.com
Dec 02, 2010 | Vector VEC 024 400-Watt Power Inverter...
My Vector model #VEC117FS has a battery that is dead and will not recharge. The replacement battery is VEC 191 according to the owner's manual. Where can I buy this battery or is it best to just buy a new...
Nov 10, 2010 | Vector 1 Million Rechargeable Spotlight
I have not been able to find a store who handles the vec 142 in our area I have questions like battery battery life and how much are replacement batteries if available what is life of bulbs and how are...
In March, 2006, Black & Decker purchased Vector Products, Inc. Since the acquisition, Black & Decker has assumed the manufacturing of all Vector products. For customer service and warranty information for Vector products, please contact Black & Decker Customer Service.
Nov 01, 2010 | Vector VEC 142 Rechargeable High Intensity...
I need to find replacement ground (thumb screw) for vector 024
ground it off on the case...any grounding method should work. Unless you are talking about the main connection terminals... then just replace the missing thumb screw with a short screw and an eyelette type connecter.
Nov 18, 2008 | Vector VEC 024 400-Watt Power Inverter...
Camping, Backpacking & Hiking Logo
1,051 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
