Question about Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
I have a husky model WL651004AJ L6/7/06-14998, It will only pump up to 75 lb. What do i do?
4 Suggested Answers
  • 5 Answers
SOURCE: I need a new belt for my Husky air compressor but I don't know
You may be able to find the belt you need on ebay. There is a seller named "Footballcardcellar" who lists these often and they are alot cheaper than buying the kit from Husky. Just search "Air compressor belt husky"
Posted on Mar 28, 2010
  • 41 Answers
SOURCE: I have a Husky air compressor model WL651004AJ.
It sounds like you need to replace the run capacitor , if yours is weak or defective the motor will overheat. Check "Drillspot" for a replacement. Another major cause of overheating is due to a dirty air filter , you should check it first.
Don F
Posted on Sep 09, 2011
SOURCE: I have a husky air compressor model WL651004AJ
You can inspect the check valve by removing it and pulling on the small plastic pin sticking out of the middle of the tank side. It should spring back under fairly light tension. Also visually inspect and clean out with a dry q-tip the brass screen on the inlet site. Seal back with ribbon dope.
If this looks ok, remove the 4 bolts holding the head on. Keep all of the sandwiched plates together in order so they go back in easliy. The cylinder sleeve will come off with this stack. Look at the plastic surround on the piston and the inside of the cylinder. In my case, this was eaten up from too many hot summers and cold winters in the garage. The rubber/plastic had hardened and eaten part of itself away. To replace the entire piston assembly on the WL651004AJ, you'll need to get part number WL211000AJ, which in some books is superseded by WL211000SJ.
If the cylinder is scored (meaning that by scraping your fingernail against the lines in it, you catch the nail) then you're probably better off replacing the whole cylinder unit.
Posted on Oct 02, 2011
My HUSKY air compressor mod # WL651004AJ,will startup but after it reach 150psi,the presure will drop and it will not startup again.
This problem is usually caused by the in-tank check valve. Follow the discharge airline from the pump to the tank. This line will connect to a brass or chrome valve (check valve). Easy to test. With air in the tank, pull power cord for safety, remove the small tube (or larger) at the brass valve. If air is leaking here, replace the valve with generic valve or try removing the valve and clean the seat. Good luck.
Dec 04, 2014 | Air Tools & Compressors
CAN YOU STAND THE Husky WL651004AJ UPRIGHT?
Your compressor will work in the vertical position however you will not be able to properly drain the water from the tank in this position.
Feb 18, 2012 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I have model Husky WL651004AJ it will not run at all. I want to remove the top cover to check the electrics. I can get the cover off. The snaps come loose, that's as far as I can get. How do you remov
I have a Husky WL651004AJ which has not been starting up for family members lately and noticed a 50 ft extension cord was being used because of the distance from the power outlet. I moved the air compressor to the power outlet and plugged in the power cord without any other extension cord and the air compressor works fine. The 50 ft cord was too light duty for the power required.
(12 ga) and min gage of 10 for the distance of 50 ft without disrupting the power breakers.
Dec 08, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I have a Husky air compressor model WL651004AJ. The problem is that it builds pressure initially up to 75 psi then shuts off. I have to turn off the power switch, wait about 5 minutes, turn the switch back...
Don F
Aug 12, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Have mod.# wL651004aj put new piston and ring kit in still does not build air pressure nee help
I would suggest checking the valves . Make sure they are good,no trash ,seating properly. other items to look at include, head gasket,installed correctly? air filter plugged or inlet blocked with something
Aug 08, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
My husky air compressor model is WJ10064AJ. I got this compressor my brother in law. The compressor runs but the pressure is low. It shut off at 75 psi and 75 lbs on air. I have to shut it off for a while...
All of your problems indicate the pressure switch is bad. I don't know which part number to recommend because Campbell Hausfeld (Husky) model numbers have six digits and there aren't any model numbers or part numbers I can find that start with WJ. You need to contact Campbell Hausfeld (1-800-543-6400) to see what part you have to order to fix your compressor.
Mar 21, 2011 | Air Tools & Compressors
I have a husky air compressor model WL651004AJ will only build up to 50 psi and compressor keeps running any advise som one could give me to whats wrong.
Jan 18, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Need bolt torqe specs , rods, mains, oil pump & oil pan for 6.0 vortec engine thanks
Connecting Rods: First pass 15 lb ft. If you have an early first design final pass 60 degrees. Second design 75 degrees.
Main Crank Bolts: Inner bolts first pass 15 lb ft. A final pass additional 80 degrees. Tighten the outer bolts/studs 15 lb ft. Final pass 53 degrees.
Tighten the side cap bolts to 18 lb ft. Tighten the bolt on ones side of the bearing and then tighten the bolt on the opposite side of the same bearing cap.
Oil Pump Bolts: 18 lb ft.
Oil Pump Screen Nut: 18 lb ft
Oil Pump Screen Bolt: 106 lb in
Oil Level Indicator Tube Bolt: 18 lb ft
Oil Level Sensor: 115 lb in
Oil Pan Drain Plug: 18 lb ft
Oil Pan Bolt: 18 lb ft
Oil Pan (to front cover): 18 lb ft
Oil Pan (to rear cover): 106 lb in
Oil Pan Skid Plate Bolt: 15 lb ft
If you need more specs contact: melissapowers75@gmail.com
Feb 02, 2010 | Chevrolet C2500 Cars & Trucks
This is a simple way to replace your belt without the old one for comparison. Use a piece of rope thick enough to fit inside the pulley, (cloths line works well). Simple wind it around the pulleys marking where the two ends meet. Cut and measure it. Take the piece of rope and measurement to a auto parts store and ask them to match it up. An automotive belt will work fine.
If this is a flat belt they should still be able to help you.
Aug 07, 2009 | Air Tools & Compressors
Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor Logo
413 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
