Question about Black & Decker Toaster Ovens
Top heating element burned out and broke infrawave oven
4 Suggested Answers
cactus bob
  • 267 Answers
SOURCE: Quartz heating elements problem in Krups toaster oven
you can touch the element but be carefull the glass is thin .... so scrape it and do what you can . THEN USE A COTTON BALL AND ALCOHOL and clean the element that will get rid of the oil you left behind ,you will be fine ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Posted on Mar 02, 2009
  • 22 Answers
SOURCE: i have a Black & Decker Infrawave counter top toaster oven
Free manual download:
http://kitchen.manualsonline.com/manuals/mfg/black_decker/fc350.html
Posted on Apr 26, 2010
  • 10865 Answers
SOURCE: One of my GE toaster oven's 2 top elements burned out
Hello. It is very difficult finding parts for and appliance over ten years old. I recommend that you shop a bit for a new toaster oven. They are much less costly than they used to be and work better. Plus they have a warranty. J.
Posted on Jul 21, 2010
Can I get parts for a Bravetti convection toaster oven, specifically upper elements?
Fixya does not sell replacement heating elements. Try checking with a local appliance parts supplier.
Aug 22, 2016 | Euro-Pro EP278 Bravetti Platinum 1500...
Oven works but is not heating up what can I do or check for to restore heat
Check for correct power at the heating elements, if its there, the elements are burned or shorted.
Mar 07, 2015 | Lincoln 1301/1346 50" Electric Impinger...
My bread burned on top before it was done ,using convection oven
I would say that it sounds like the bottom element isn't working. I am assuming that you can tell that the fan for the convection feature is running. You should be able to see through the glass door to see if the element is heating up.
<a href="http://www.toasterandconvectionovens.com">ToasterandConvectionOvens.com</a>
Feb 17, 2011 | Hamilton Beach Toaster Ovens
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    Heating units bottom stopped working. Then the top heating bars stopped working. It's a radiant oven.
    it is several prosibilites for your problem:
    1) the wire of the oven is damaged;
    2) the thermostat is decalibrated or damaged;
    3) one or more heating element is intrerupted or burned.
    solution's:
    1) check the wire an replace or repair where is posible whit similar heat resistant wire;
    2) replace the thermostat whit similar one;
    3) replace the heating element
    Feb 21, 2010 | Oster 6239 Toaster Oven with Convection...
    I have a Black & Decker Infrawave counter top toaster oven
    Oct 06, 2009 | Black & Decker Toaster Ovens
    Pizza is soggy
    Not working properly accordiing to the manufacturer.  Not fixable.
    Jan 27, 2009 | Toastmaster TOV200 Toaster Oven with...
    Toaster does not work!!!
    I investigated further (took it apart again to satisfy my curiosity) and it appears that one of the top heating elements (the front one) is open (burnt out). I cannot see an easy way to replace it (contacts are spot welded) and I can't find a place to buy the element. If I could it probably won't be worth it since a new oven costs $25 at Target (B&D TR0490W). Too bad since the oven looks like new. I assume the upper elements burn out more frequently because heat rises from the lower elements and adds extra heat at the top.
    Jul 02, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
    Top element not heating
    I found that the heating element in the top front was burned off at the end. I removed the side cover and the ceramic insulator from the broken end. I then grabbed the broken end of the spring inside the glass tube and stretched it to where I could re-attach it to the connector. It now works after getting it back together.
    If you attempt this repair, UNPLUG THE OVEN FIRST!
    There is also a security screw at the bottom of the side cover.
    Dec 26, 2007 | Black & Decker CTO649 Toaster Oven with...
    Toaster Ovens Logo
    315 people viewed this question
    Top Black & Decker Toaster Ovens Experts
    Dave
    Dave
    Steve
    Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
