Question about NEC-Mitsubishi PX-42VM5HA 42 in. EDTV-Ready Plasma Television
NEC Plasma PX-42VM5HA - turns on but shows vertical black and white bars across the screen with no other response from buttons on display or remote. Powered off for a while but still remains,
  • 998 Answers
One of the module in the main board has a problem try to contact the service center.
Posted on Oct 14, 2010
  • 2 more comments
  • fixya554 Oct 14, 2010
    how can i find out ON MY OWN which "module" is at fault? this would have to be a universal error image indicating a specific problem, or no? I purchased the service manual, but does not describe this particular problem or anything close to it.
  • Noel Jucutan
    Noel Jucutan Oct 14, 2010
    still if you locate the defective module you cannot purchased it in the electronic shop its better to ask the service center about that because that module is very sensitive in the service center they will give a warranty.
    Sounds like you are a service center yourself...
    Service center closest to me is almost 2 hours away and they want to charge $150 to look at it. I would really like to fix it myself or know that it is fixable or trash. I assume fixable because the panel is still lighting up and displaying colors - the black and white bars have pixel wide rainbow colors bordering them. Why can I not purchase the module on-line? I'm sure it would be available somewhere in the world...
  • Noel Jucutan
    no im not from the service center as a technician we have limitation to bec if you have purchased a module and connect to your plasma and it work we are not sure how long it will take in the service center they have all the tools and gadgets to test those defective parts before they will give it to you.
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
My nec 42" px-42vr5w plasma
Despite the fact that you have posted this as a question about a kitchen range, I can tell you waht the problem is anyway!
The plasma screen is controlled by hundreds of seperate connections at the top, bottom and sides of the screen which use electrical pulses to signal the pixels on the screen what colour they should be. If the connection to a bank of these connectors fails (in this case either at the top or the bottom of the screen) then they will usually die and that portion of the screen most commonly goes black. Next most common is that they go white as yours has.
This is absolutely NOT a DIY fix. You will need to get it to your local TV shop. If you're lucky, they will find and fix the poor connections. If you're unlucky, the plasma panel has had it and they won't be able to repair it. A replacement panel supplied and fitted is probably about the same price as a nice new, updated plasma TV, so if the issue goes that way, consider scrapping and buying a new one
Jun 23, 2011 | Kitchen Ranges
Black line in the middle of the screen
check for vertical ic it is faulty, replace and try again
May 23, 2009 | NEC PlasmaSync PX-61XM1A 61 in. Television
Plasma shows half screen
Have a technician come and replace the display drivers or buffers boards they are some times called.
May 15, 2009 | NEC PlasmaSync PX-61XM1A 61 in. Television
NEC px-42vp4g/s 42in.plasma monitor PDP:np42b3mf01...
I have the same problem with vertical coloured lines on my NEC PX-42VP4G/S. The photo only shows a black background just so it's easier to see the lines in the photo but normally the picture is OK except for the vertical lines which aren't always in the same place.
If anyone can advise on exactly what I need to replace then I would be very grateful.
Regards, Simon.
Apr 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Problem with my NEC PX-42VP4PA
it goes on for a while and then shuts off after then the colour show not good i need help for this problem
Sep 12, 2008 | NEC PX-42VP4PA 42 in. EDTV-Ready Plasma...
I have just purchased a nec px-42vr5g plasma monitor and intend to use it as a tv connected to my sky plus, dvd and wii the guy i bought it from cant find the manual it has lots of sockets etc whats the...
Get the Wii "COMPONENT" cable set. This set has white-red (sound) connectors plus the red-green-blue (component - video) connectors. You can get this cable where they sell the Wii. It will give you the best possible picture with this device.
Plug the Red-Green-Blue connector in their respective sockets on the NEC display (upeer right-hand side). Switch the NEC display to the DTV/HD input (upper right button on the remote).
Please note that this setup does not provide sound since the display does not have speakers.
Use the white-red connectors and plug them into your amplifier or other sound device.
Good luck.
Sep 03, 2008 | NEC Televison & Video
Nec plasma tv 42MP4
these plasma vertical black lines are notorious. there's a video of a fix on this plasma tv repair site. good luck!
Jul 29, 2008 | Samsung PPM42S3 42 in. Plasma Television
I need a Remote for NEC Plasma TV Model PX-50VP2G
www.replacementremotes.com should have the remote. Just enter the model number of your set in the search box
Apr 01, 2008 | Televison & Video
NEC-Mitsubishi PX-42VM5HA 42 in. EDTV-Ready Plasma Television Logo
205 people viewed this question
Top NEC-Mitsubishi Televison & Video Experts
Are you a NEC-Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
