Question about Sony PlayStation Portable (PSP) Console
Hellllppppp....plzzzzzzz...... my psp works slowly..especially when i navigate it.. what should i do?? should i try changing the memory stick?
  • frozenchen Jun 02, 2008
    ok thanks..
    but it started when it fell,,
    huhuhu..
  • frozenchen Jun 05, 2008
    ok thanks a lot..
    weeeeeEEE
    ^_^
    President:
  • 2,712 Answers
Looks like you have too many programs on. One of two options:
1. Remove unnecessary stuff.
2. Increase memory.
Posted on Jun 02, 2008
  • Swilin Sampson
    Swilin Sampson Jun 02, 2008
    Then it looks like the hard drive may be an issue.I am not really an expert in these things. You'd probably be better contacting dahaka
    who is the resident expert on PSP's...
  • Swilin Sampson
    Swilin Sampson Jun 05, 2008
    Hope you'd rate this a fixya, since your issue is resolved?
Hi My PSP's orange ligth won't turn off just always lightning when turn on my psp it's lightning with green light
Hi khangal74,
If you dont have issues playing your usual psp games, you dont have to worry about the orange light. That is normal. It means that your PSP is saving the data to your memory stick. Also make sure that your WLan switch is turned off ( that also causes a blinking orange light ). However, if you are experiencing a flickering orange light and your screen remains black ( and you cannot play any games), it means that your PSP is having issues reading you memory card.
Do these:
Remove the memory card and turn your PSP on without the memory card (it should turn on with no problems) Now, slowly re-insert your Memory stick. (You may need to do this several times until your PSP recognizes your memory card) If this still does not work, your Memory stick is busted or may be infected with a virus and therefore needs to be replaced.
Wishing you with positive results. All the best to you.
Jul 23, 2011 | Sony PlayStation Portable (PSP) Console
Hey there, please help me out. I have downloaded the psp version 6.30 but when i put it on my psp through my laptop and disconnected the usb the version did not show in the psp.... im confused..
If you have wifi, i would download the update straight with the psp.
If you do it via pc, then i think you have to copy the file in games folder of the memory stick. Navigate to it and load it.
Hope it helped
Jul 01, 2010 | Sony Memory Stick PRO Duo (2GB) for PSP
No source will read my memory stick pro duo mark 2
  1. Try re-formatting your memory stick from your PSP console. A memory stick that is formatted from a PC or other hand held console sometimes cause incompatibility problem with the PSP.
  2. If your PSP still can not read the memory stick, try checking your memory stick by using your friends PSP and see if they can access the memory stick.
  3. If the memory stick can be accessed by your friends PSP then there is a problem with the memory slot of your PSP.
  4. The only way to check the contacts of the memory slot of your PSP is to disassemble you PSP and take out the mother board.
Jan 23, 2010 | Sony PlayStation Portable (PSP) Console
I HAVE 2004 SILVER PSP CFW 5.50. HOW DO I PLAY DOWNLOADED GAMES ON IT. WHAT SOFTWARE TO INSTALL AND HOW?
Hi. First, you have to format your memory card so that the required folders will be automatically created.
On your PSP, go to Settings>>System Settings>>Format Memory Stick. Select YES when asked if you really want to format your memory stick. Wait for a few seconds & once prompted that it's done, you can now grab your USB cable and plug your PSP to a computer.
Go to Settings>>USB Connection. Your computer will detect the memory stick as an external drive. Once connected, navigate to your PSP's memory card directory via Windows Explorer. You should see an "ISO" folder. Open this and copy your downloaded games here (.iso or .cso file).
Safely remove the USB connection once done. Navigate to your "Games" on the PSP and the copied game will appear.
Hope this helps.
Aug 24, 2009 | Video Game Consoles & Games
Memory stick unreadable by psp
try formatting the memory card via a card reader..
thats all i can think of
good luck!
May 30, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
Psp illiterate
Yes there is a way. What you will need is a PC, Some form of Memory stick Duo card Reader, And a PSP Compatible Memory stick Duo/Pro Duo.
If you havent already used the memory stick inside the PSP it will not have the correct Formatted file System for use in the PSP. but you can create the file system using your computer.
heres how to do it ! :
1) plug your Memory stick Duo/Pro Duo into the card reader on your computer.
2) open my computer, locate the Memory stick usually found under the "devices with removable storage" area.
3) once inside the memory stick, create 2 seperate folders. One called "PSP" and the other one called "MP_ROOT".
4) Navigate into the "PSP" Folder and create 3 Folders, "MUSIC", "PICTURE" & "VIDEO"
5) Copy & Paste the Necessary files into each Subsequent Sub-Folder within the "PSP" Folder.
Note : The PSP Can only handle Certain File types for Pictures, Music, And Video. i would suggest Navigating to http://psp.about.com/od/hardwarefirmware/p/compformat.htm before you transfer your files to ensure that you are adding files which are Viewable/Readable by The PSP's software.
Hope this helps !?
Oct 27, 2008 | Sony PlayStation Portable (PSP) Console
PSP SCREEN FLICKERS AND GOES SLOW IN MAIN MENU
Go to psp recovery menu and set the CPU speed in XMD to default, it should work
Aug 23, 2008 | Sony PlayStation Portable (PSP) Console
Up loading music, Vids, Pics, Themes
get a memory stick duo of any Gigabyte size you want, Turn on the psp and insert the memory stick duo.Navigate to SETTINGS, under SETTINGS scroll to the SYSTEM SETTINGS and press the X buttom. system settings will appear, then scroll to the FORMAT MEMORY STICK and press the X buttom.
a message will appear and select yes, this will format the memory stick duo and create folders like MUSIC, VIDEO ,PICTURES etc. required by the psp.
restart the psp system and you are good to go. remember to save MP3 songs you want to play on your psp to the MUSIC Folder on the memory stick duo when you connect it to your computer in USB mode. if you want to play WMA format songs, navigate to system settings and select the ACTIVATE WINDOWS MEDIA AUDIO(WMA), make sure you are in a wireless hotspot to connect to the internet to activate WMA playback.
online manual for psp: click on the link. http://manuals.playstation.net/document/en/psp/current/index.html
Good Luck.
if you need more help comment me back.
Aug 08, 2008 | Sony PlayStation Portable (PSP) Console
PSP videos
The problem can be the memory stick or within the PSP system itself. Try inserting another memory stick into the non functioning psp. If the problem still persist that means the memory card reader cannot read the files try formatting the whole psp system. If that doesn't work you will need to get it repaired take to an electronics store that sells video game systems preferably game stop they will swap out the memory card reader
Apr 28, 2008 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
