Question about Cameras
I have connected the camera to my USB port and turned on the camera with the dial turned to PC setting, but my computer wont recognise the connection!! Help?
    President:
  • 2,185 Answers
Try to plug it to another USB port on the computer and then turn the camera on and set it to play mode. Also, try to restart the computer and then try plugging it again.
Posted on Oct 14, 2010
2 Suggested Answers
  • 11967 Answers
SOURCE: USB is connected to camera and PC but the
Use a card reader instead of your camera.
Posted on Nov 23, 2009
How do I get picture from my camera to my computer?
Check your memory card is installed in the camera take the camera usb cable connect the smaller plug end into your usb camera port, connect the other end (the larger of the two ) into the usb port on side of your computer Turn computer on wait for computer to boot up . then turn your camera on your pc will recognise the device you have connected (the camera) it will then give you options as to where on your computer you want it copied to keep it simple opt for my pictures or a similar file that's easy to access, you can also choose to copy and keep the original images on the cameras memory card or remove them automaticly after copying has finished, input your options and click on copy When the computer indicates the task has finished turn your camera off and unplug the leads
Sep 04, 2015 | Apple iPhone 5c
Computer not recognising camera
You could try another USB port. I've had USB ports get loosened up on me without me realizing it. If nothing else has changed, I'd suggest trying to connect with a different USB port, OR swapping out your camera connection cable. The cable might be bad, usually from being pulled on so much.
Nov 28, 2013 | Panasonic SDR-S50A Std-Def SD Camcorder...
Cannot import pictures from camera to computer
If your computer is having poor earthing the currant leakage spoils the IC inside the USB port of camera. try in another laptop and confirm the same.
May be we can supply the manuals for servicing and spares
Sep 29, 2013 | Sony Cyber-Shot DSC-H1 Digital Camera
Aiptek camera transfer to cumputer
Using the PC Camera Function
1. Installing the AF Cam driver
You need to install the AF Cam driver before using PC Camera
or video conferencing function.
* If you have already installed the AF Cam driver, skip step 1. "Installing the AF Cam driver" and go to step 2. "Connecting your camera to your computer".
2. Connecting your camera to your computer
2.1 Turn on your computer
2.3 Insert the USB cable to the USB port on your computer
2.4 Insert the other end of the USB cable to the USB port on your camera.
* Then you can see the camera as removable disk. You can transfer the pictures from your camera to your computer like transfering files from one folder to another.
1. Go to camera folder
2. Select the file/pictures you want to transfer then right click and choose move option (if you want the files to be moved on your computer) then choose the desired target folder or drive.
*you can just copy the files form the camera to your computer too.
select the files that you want to copy then right click, choose copy then paste on the desired folder or drive.
Apr 09, 2010 | Aiptek PocketCam 3M Digital Camera
Canon 450D is not being recognised by my computer (I run xp 32-bit). When I turn on the camera, windows comes up with a "install new hardware" option. I have installed the EOS utility etc. but still the...
Both the Canon XT 350D and the XTi 400D are recognized by any PC with XP windows operative system. It seems you have to check your USB port or USB cable used to connect your cameras to the PC. Sometimes, the PC does not recognize a specific device connected to an USB port. Yopu can get into the System -device manager screen, and uninstall the USB port, and run the utility to recognize changes in the device manager. This will install the USB port driver again, and if it is a software issue the reason of the problem, then it will be fixed.
Also, you can check your cameras and USB cable in a different PC so you can confirm if they both work has should be.
Regards,
Mar 26, 2009 | Canon EOS 450D Digital Camera
Wont connect from lg pc suite
Happened to me a few times. Try restarting your computer but leaving it plugged in so your computer already recognises what it is.
If you plug it in your computer takes 10 minutes or so figuring out what it is and whether you need to download anything additional for it to work. If you restart your computer by the time you click LG PC Suite it will have already recognised what it is and will work. If your computer has wireless settings you could try connection through bluetooth!
Mar 20, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
My computer wont recognise my FinePix A610 camera
Suggest that you go tp my computer as the answer above has suggested and attempt to open drive(memory chip) in the camera and download. If not suggest removing the memory chip from the camera and try accessing via Walmart or other stores photo Kiosk.
Suggest opening Fin-pix first before connecting camera.
Through fine-pix search for camera as if it was an external drive. Hope this helps?
May 24, 2017 | Fuji Finepix A610 Digital Camera
More upload problems
Most if not all digital cameras would be read as an "external mass storage device". Based on your description, it is possible that it is the USB port of the PC that has an issue and not the camera. A couple of things that you can try:
  • verify that the PC's USB ports work by plugging in other USB devices such as a printer, flashdrive, MP3 player;
  • try the Vivitar in another PC;
  • double click on "My Computer". The camera would show as another drive, perhaps an "E";
  • rollback your USB drivers;
  • uninstall latest Microsoft updates (USB);
  • update your USB drivers not with Microsoft but with the motherboard's manufacturer's website;
  • try the digicam's memory card in a memory card reader.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 07, 2008 | Cameras
FE-280 Olympus
u did see this after pic below, and you have tried deleted usb controllers in device manager then reboot c5374dd.jpg can u tell me if, cam lights up/does windows make a connection sound, when usb from cam is connected? posted by Jordiane on Nov 18, 2007 Report abuse
It says it is unable to find a camera connected to the USB ports. Any idea where I could find a driver to help this or is it another problem?
Have the same problem? Click Here
6 Other Users Have The Same Problem Comment by Emilie, posted on Nov 21, 2007 The display doesn't turn on when the camera is turned on unless I switch the mode on the dial. The camera turns off when I toggle the zoom.
Comment by Guest, posted on Nov 29, 2007 Zoom does not work
Comment by Guest, posted on Dec 27, 2007 I receive the message the software was unable to find an Olympus digital camera conected to a USB port on your computer.
Comment by petedrum, posted on Dec 23, 2007 Same Problem. Tried it on two XP computers, can't find camera on either. Camera lights up when plugged in.
Comment by Kellib, posted on Jan 01, 2008 I'm having the exact same problem with my camera. i can't figure anything out with it and if i plug the usb into the computer, i hit ok for PC and then my computer freezes. someone please please help me figure this out
noavatar_s.png Mickoolz
Rank:nonexpert_s.gif Apprentice
Rating: 70%, 3 votes
I had this same problem, I'm using Vista on my HP laptop and I managed to correct it. Apparently HP like to customize Vista and when connecting some USB device's they don't recognise them as what they should. A USB mass storage device. You will need to connect the camera to the computer, the camera will come on then click the ok button so it selects PC. Wait until it finishes its search click cancel and open device manager, scroll down and below Network Adaptors you should see an expandable tree with an yellow exclamation mark named Portable Device's --> FE-280/X820/C520 you will need to right click on the FE-280/X820/C520 icon and select "Update driver software". Then select "Browse my computer for driver software" then select "Let me pick from a list of device driver's on my computer" Scroll down till you see "Universal serial bus controllers" then select "USB Mass storage device" in the next window. It should all work fine now! If it still doesn't work try selecting "Portable devices" then select "WPD File system device" --> "Microsoft WPD filesystem Volume Driver".
Hope it helps.
Cheers, Mick
Was this solution helpful? Show your Appreciation by rating it:
Jan 04, 2008 | Olympus FE-280 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
