Question about Fujitsu fi-5120C
Message that the brake roller in the paper feeder needs to be replaced. How can we correct this issue?
How to fix document feeder on HP Officejet Pro 8500A Plus
Might be a paper size issue, dirt on a paper sensor or drive rollers need a clean.
Mar 16, 2016 | HP OfficeJet Office Equipment & Supplies
Brother mfc8440
yes there was a sensor switch, which can be broken and faulty that needs to be repair or replace.
Sep 07, 2008 | Office Equipment & Supplies
Hp laserjet 1536 dnf MFP. How can I repair document feeder?
how to fix and repair the adf doc feeder Q5997A hp laserjet ...
? 1:36
https://www.youtube.com/watch?v=lpTj4jiLaY8
Dec 12, 2011 - Uploaded by BrokenPrinter1
Parts Available @ BrokenPrinter.com how to fix and replace the rollers on a hp laserjet 4345 mfp and color ...
Fixing Paper Pick-Up Issues - HP LaserJet Pro M1212nf ...
? 5:40
https://www.youtube.com/watch?v=ZXtAhSDYqyU
Jan 23, 2013 - Uploaded by HP Printer Support
Learn what to do if your HP printer does not pick up or feed paper from the ADF when you do have paper loaded, and a Doc feedermispick error message display... ... FIX YOUR PRINTER: ERROR: Printer Does not Grab Paper fromTray ... Kit m3027 mfp- Kit Hp m3027 mfp - Kit Mantenimiento m3027 mfp ...
'Document feeder mispick' Message Displays on the Control ...
Dec 13, 2015 | HP Office Equipment & Supplies
Canon ip1800 is experiencing paper jam.whener tries to print, cannot feed the paper properly
Sometimes a printer just needs some cleaning.
Remove the jammed paper following the procedure below. (1) Slowly pull the paper out, either from the Auto Sheet Feeder or from the Paper Output Slot, whichever is easier.If the paper tears and a piece remains inside the printer, turn the printer off, open the Front Cover, and remove it. Be careful not to touch the components inside the printer. After removing all paper, close the Front Cover and turn it back on.If you cannot pull the paper out, turn the printer off and turn it back on. The paper will be ejected automatically. (2) Reload the paper in the printer, and press the RESUME/CANCEL button on the printer. If you turned off the printer in step 1, all print jobs in queue are canceled. Reprint if necessary.
Make sure to clean the paper feed rollers if paper is not fed properly. Cleaning the Paper Feed Roller of the Auto Sheet Feeder consumes it, so perform this only when necessary. 1. Make sure that the printer is turned on, and then remove any paper from the Auto Sheet Feeder. 2. Open the Printer Properties dialog box. 3. Click the Maintenance tab and then Roller Cleaning. 4. Confirm the message, and then click OK.The Paper Feed Rollers will rotate as they clean. 5. When the message appears, load three or more sheets of A4 or Letter-sized plain paper in the Auto Sheet Feeder.Set the Paper Thickness Lever to the left. 6. Confirm the displayed message and click OK.The paper that is loaded in the printer will feed through the printer and be ejected. 7. When the confirmation message is displayed, click OK. If this procedure does not solve the problem, clean the surface of the roller with applying a slightly moisten cotton swab with water to wipe off dust or stain.
If the problem still persists, contact a Canon service representative.
Mar 28, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
Screen says original loaded when nothing is in the adf
  1. Remove all the paper from the document feeder tray.
  2. Examine the condition of the paper, and then replace any ripped, dusty, curled, wrinkled, or bent paper.
  3. Make sure that the paper is a supported paper type for the product.
    NOTE: The ADF does not accept photo paper.
  4. Make sure that all the paper in the stack is the same size and type. Never load mixed types of paper in the document feeder tray. The product can only process one type of paper at a time.
  5. Tap the edges of a stack of 10 to 25 sheets of paper on a flat surface to make sure that the edges are even.
  6. Load the stack of paper print side up in the document feeder tray.
    NOTE: Do not load more than 25 pages in the document feeder tray. Larger stacks of paper can lead to pick problems. Figure 2: Reload the original document c02081020.gif Illustration of reloading the original document
  7. Press OK to continue the current task.
  • If these steps resolved the issue , you do not need to continue troubleshooting.
  • If the issue persists , continue to the next solution.
Dust or paper residue on the rollers or separator pad inside the ADF can cause paper feed issues.
  1. Gather the following materials:
    • A clean, lint-free cloth, or any cloth that will not come apart or leave fibers
    • Distilled, filtered, or bottled water (tap water might damage the product)
  2. Remove the stack of paper from the document feeder tray.
  3. Press the Power button (c01602202.gif ) to turn off the product.
  4. Disconnect the power cord from the rear of the product.
  5. Lift the cover of the ADF, and then find the rollers and the separator pad. Figure 4: Location of the ADF rollers and separator pad c00228595.gif 1 - ADF rollers 2 - Separator pad Illustration showing locations of the ADF rollers and separator pad
  6. Lightly dampen a clean, lint-free cloth with bottled or distilled water, and then squeeze any excess liquid from the cloth.
  7. Use the damp cloth to wipe any residue off of the rollers and the separator pad. Figure 5: ADF rollers c02081021.gif Photograph of ADF rollers Figure 6: ADF separator pad c02081022.gif Photograph of ADF separator pad
  8. Dry the rollers and separator pad with a dry, clean, lint-free cloth.
  9. Close the cover of the ADF.
  10. Reconnect the power cord to the rear of the product.
  11. Press the Power button (c01602202.gif ) to turn on the product.
  12. Reload the original document print side up in the document feeder tray.
  13. Try to perform the task again.
Perform a partial reset to restore the product settings to the default values.
  1. Write down any fax numbers and country/region and language settings stored in the product memory. CAUTION: A partial reset might remove all speed dials and other settings from the product memory.
  2. Disconnect the power cord from the rear of the product.
  3. Press and hold the # and 3 buttons at the same time while plugging the power cord into the rear of the product.
  4. Release the buttons after 30 seconds or when Part NVM Reset displays on the control panel.
  5. If the product does not turn on, press the Power button (c01602202.gif ) to turn it on.
  6. Press OK to continue the current task.
If you have completed all the steps listed above and are still experiencing a problem, service the product. If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 22, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Alignment issue causing copies to be cutoff
Firstly check are the left i right holder in paper tray in their position accordingly formats eg A4. Then very well clean, if necesarry replace, pick up, feed and separation rollers. Clean the other paper feed rollers on paper way.
Also check the registration roller and clutch.
If nothing of this helps, send another message, then you will get adjustment info.
Jun 15, 2010 | Canon imageRUNNER 210S Copier
Paper jam error message but there is no jam
usual problem is a paper sensor (most likely a small lever) has gotten stuck.. find the paper sensors and reposition them
Jun 10, 2009 | HP J4680 Office Jet All-In-One Printer
DOCUMENT FEEDER IS JAMMING
Try and clean the rubber rollers with Isopropyl alcohol. Do not use any solvents.
S. Mohan, Chennai, India
Dec 30, 2008 | HP Scanjet 5590 Flatbed Scanner
I have just purchased ink cartridge 830 black for canon ip 1800 but the lights are blinking orange please tell me why this is happening
I received this response from canon.com. Hope it helps you.
If the paper feed rollers become dirty, they may not be able to properly
feed paper due to the feed roller's slippage. If paper does not feed
correctly, perform the following to clean the paper feed rollers:
1. Open the Printer properties.
For Windows Vista
a. Click / Select 'Start' from the bottom left of the Windows screen,
'Control Panel', 'Hardware and Sound', and then click on 'Printers'.
Note: If you are in 'Classic' view, Click 'Printers' directly from the
'Control Panel'.
b. Click your right mouse button on the listing for your printer, and
then select 'Preferences' from the menu that appears.
For Windows XP Home Edition
'Control Panel,' 'Printers and Other Hardware,' and 'Printers and
Faxes.'
For Windows XP Professional Edition
a. Click 'Start' from the bottom left of the Windows screen, and
'Printers and Faxes.'
For Windows 2000
and 'Settings,' then 'Printers.'
then select 'Properties' from the menu that appears.
2. Click the 'Maintenance' tab and click 'Roller Cleaning'.
3. Remove all sheets of paper from the auto sheet feeder.
4. Confirm the following message, and click 'OK'.
Note: Clicking 'OK' will activate the paper feed rollers 30 times. This
activation will take about 90 seconds. Do not perform other operations
until this operation has finished.
5. Confirm the following message, and click 'OK'.
6. After the continuous paper feeding operations in step 5 have
finished, load three sheets of plain paper and click 'OK'.
7. Confirm the following message, and click 'OK'.
Note: The following message is displayed when the paper is fed and ejected.
8. Click 'OK'.
Roller Cleaning is completed.
If the issue continues to persist, try fanning the paper before
reseating in the automatic sheet feeder.
Follow these steps to fan the paper in the Auto Sheet Feeder(ASF):
1. Remove all documents from the ASF.
2. Check for any obstructions.
3. Fan out the sheets of paper so that they do not stick together.
4. Align the edges of the paper.
5. Insert the document stack, face up, into the ASF until you hear a
beep.
6. Adjust the document guides to the width of the document.
If fanning the paper does not help resolve the issue then the iP1800
printer will require service.
special toll-free number for email customers with
unresolved issues and speak to a technician* by dialing 1-866-261-9362,
Monday - Friday 10:00 a.m. - 10:00 p.m.
Dec 14, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Not feeding
Have you still getting the problem, have you done cleaning of Cartridge, its nozzle and Contact strip.. then cleaning of Printer roller or carriage rack.. Do a Service of it or get it done by Technician.
Also check the feeder tray.. to grab paper one by one by printer.. Manually
Take all updates for printer and OS.
Oct 31, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Fujitsu fi-5120C Logo
47 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
