Question about Pioneer TS-W307D2 12" 1200 Watt Champion Series Subwoofer - 2Ohm Car Subwoofer
Speaker works but smokes - Pioneer TS-W307D2 12" 1200 Watt Champion Series Subwoofer - 2Ohm Car Subwoofer
    Scholar:
  • 127 Answers
Need more info . what i know is this a subwoofer voice coil gets red hot in color its like the flame on a blowtorch when being played at high volume from the electrical current running through it . when the speaker is brand new you notice the smells like its on fire or burning up . this is normal it just breaking in the speaker . it goes aways few minutes later ...
give me more info into what is happening i can help you
Posted on Oct 14, 2010
Im having the problem with my mtx tc6001 amp smoking my speakers I hook up everything and when I turn on radilo speakers jump pop and smoke.
MAKE SURE THE SPEAKERS ARE CONNECTED TO THE AUDIO OUTPUT OF THE AMP AND NOT TO SOME WIRES SENDING DC POWER ........ IF THE AMPLIFIER HAS AN INTERNAL PROBLEM AND IS SENDING DC CURRENT TO THE SPEAKERS THIS WILL MAKE THEM SMOKE ALSO ...... HAVE THE AMP TESTED ON A BENCH IN A SHOP ...
MY GUESS IS IF THE SPEAKERS SMOKED THEY ARE DESTROYED AND CANNOT BE FIXED....... COIL ON THE BACK OF SPEAKERS NOW OPEN ---- SORRY TO TELL YOU THIS...
Jun 29, 2011 | Car Audio & Video
Tip
Sump Pump Failure Warning Device A simple inexpensive homemade device to detect...
A simple inexpensive homemade device to detect a sump pump failure in your home can be made for under $15.
You will use this device in your sump pump hole or any other place in the home or business where you want to detect an abnormal level or rise of water that may cause damage due to mechanical failure.
You can make this device with the purchase of a common smoke detector which can be purchased from any home repair retail outlet for between eight to $13, and a length of speaker wire (approximately 10’) for about two dollars. Total cost $10-$15.
The smoke detector will be used to detect the presence of water at a predetermined height using the length of speaker wire as a switch to activate the smoke detector.
To make the water level sensor device do the following:
Remove the cover from the smoke detector.
Strip and separate both wires from each end of the speaker wire. Expose ¼ - ½ inch wire at each end and split the wires to separate them from one another as needed to connect to the detector. (The end of wire leads to detect water level need only about one inch of separation.)
Next, find on the smoke detector where the circuit is made when you push the button on the cover to test the smoke detector device. You will need to attach one lead end to each side of this circuit with the speaker wire leads. No soldering is necessary. Simply just slide one lead under a piece of metal which can be pried up slightly and let the pinching action be used to hold it in place. Place the second lead similarly on the other side of the circuit. Route the speaker wire to the outside of the case in a way to not interfere with the cover. Put a battery in and replace the cover to the smoke detector.
Check that your connections on the smoke detector work by touching the two leads together on the end of the speaker wire. The alarm should go off the same as if you have pushed the test button circuit.
Now you can place the smoke detector in a suitable location next to the sump and also place the exposed wire leads of the speaker wire down into the sump hole at the level you want to detect a “high water level”. Make sure the wire leads do not touch anything that will cause them to short across one another and sound the alarm prematurely.
The level at which the leads should be set, should be a couple inches higher than the level at which the sump pump kicks on to pump the water out. If the pump fails and the water level rises to the wire leads, the smoke alarm will go off, alerting you to the situation.
on Dec 20, 2009 | Hand Tools
Tip
Now you can place the smoke detector in a suitable location next to the sump and also place the exposed wire leads of the speaker wire down into the sump hole at the level you want to detect a “high water level”. Make sure the wire leads do not touch anything that will cause them to short across one another and sound the alarm prematurely. When the water rises to the height of the wire leads, the water will act to short the leads in the same manner as touching them together.
on Dec 20, 2009 | Plumbing
Caused speakers to smoke:(
If it's the speaker cabinet itself that';s smoking, you have most likely burnt some components in the passive crossover. Pull it out and you may see melted parts or scorching on the circuit board. Peavy does repairs on it's own products pretty reasonably if there's no local tech. Call Peavey Customer Srervice at 877-732-8391.
Apr 30, 2009 | Audio Players & Recorders
Gateway- built-in laptop Speakers not working
Heat dissipation from the unit in the same area of the speaker assembly, especially since you stated that the RIGHT speaker was smoked. Similar problems occur with this design flaw with any manufacturer as HP has the same problem with some of their models.
Your heat exhaust is killing the speaker, and I would also bet that your chipset is AMD and not Intel, the latter having solved it's heat dissipationn problems.
A more aggressive heat dissipation solution on the motherboard or redirection of the exhaust past fewer heat sensitive components would be a design goal.
Mar 29, 2009 | Gateway MX6453 Notebook
My subwoofer started smoking-
a usual problem of a subwoofer just like my old sound system. Subwoofer generates a big heat on its device unlike ordinary speakers. better to send that to a technician to change a spare parts. it must be an ic problem got damage by over using.
thank you for using fixya
CHARCOIS
Nov 02, 2008 | Altec Lansing 641 Computer Speakers
Lab l4 bass amp smoked my speakers
If your description is to be taken literally, and smoke did indeed come out of the speakers, your output transistors have shorted out, and put the full power supply voltage and current through your speakers.
The amp and the speakers will need to be serviced. The speakers will need new voice coils at the least.
Sep 30, 2008 | Audio Players & Recorders
Deffective Speakers????
No need to buy a new speaker,
Inside the speaker box there is one TRANSFORMAR with 4 or 2 Diods & capasitor will be there that will connected to your Power cord & another line will go to Speaker ,
smoke has came from the transformar,
If you able to replace that your speaker will start work fine
cheers
Nov 30, 2007 | JBL (JBLONTOUR) Computer Speakers
Smoke coming out of subs
If smoke has come out of the subwoofer, the speaker itself, that means the voice coils have been heated excessively and they are damaged or in this case, I'd say completely blown. Voice coils blow because they've been driven too hard, too much power, too much distortion for too long.
If you can get access to the front of the subwoofer speakers, gently put even pressure with your fingers near the middle of the cone, just around the edge of the centre dust cap and push gently and slightly inwards. If you hear or feel a "scratchy" type sound or feel, or if they dont move in freely, they are blown. And if that's the case, your amp could be damaged as well.
Most modern car amps have circuit protection and will shut down when they detect a load greater than they are used to so the amp MAY be ok. One way to test the amp is to hook another speaker to it, any speaker as a test is ok, and see if sound comes out. Make sure all power is off when connecting and disconnecting speakers!
Oct 17, 2007 | Jensen JX1200 Car Subwoofer
Pioneer TS-W307D2 12" 1200 Watt Champion Series Subwoofer - 2Ohm Car Subwoofer Logo
143 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
