My rogers hd box the picture keeps flickering i've tried to reboot but it does not fix the problem
    Problem Solver:
Have you tried a signal booster, i really do think that will help. Your reception can be to do with a few thing's, i.e. Position of your tv, Faulty receiver on your main (outside) aerial, A breakage or fault with the aerial cable coming from outside aerial to tv, or your outside aerial can just simply have a bad signal.
Posted on Oct 14, 2010
I have a 40inch Samsung le40r88bd that keeps flickering and is getting worse is there an easy fix?
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY most common way MODEL ...
Flickering picture
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 13, 2013 - A flickering picture on your TV can be caused by the following conditions: Television settings; Incoming signal issues; Electronic interference ...
How to fix Samsung LN46C630 screen flickering issue
Jan 16, 2016 | Samsung Televison & Video
Rca 42in full hd lcd picture flickers
If the picture on your TV flickers, there may be a simple fix. Here are some possible answers and suggested solutions:
1. Your set-top box may need a simple reboot. Unplug the power connection to the set-top box for about 30 seconds. Reconnect the power and turn the set-top box back on.
2. Check all of your cables for a loose connection by tightening each one with your fingers.Flickers can sometimes be caused by bends in rigid cables, too.
3. If your picture flickers to a black or blue screen, you could have a bad set-top box. Contact your cable or satellite service provider about installing a new one.
4. If you still have audio, the flickering could also mean that you have a failing backlight.
For additional troubleshooting information, check out the chart at TV flickering for more solutions. I hope this helps!
Sep 14, 2012 | RCA Televison & Video
Samsung le40f71bx picture flickers on and off with hd source
I've had similar for a long time, now the picture only lasts a few minutes or seconds. Have to turn the TV off, wait 5 minutes, turn it back on. That's with Sky HD. Used to be the same with SCART but I don't use that any more, and I get it with the Wii on Component. However HD DVD and Blu Ray players are no problem!
See my post here - http://www.avforums.com/forums/lcd-led-lcd-tvs/1622157-samsung-f71-flashing-pattern-fault.html
Way out of warranty but really just need some repair expert to tell me what needs fixing. Taking the cover off there are very few components and look easy to replace, and seen some on ebay. A fix from Samsung would be vastly in excess of the value of the TV.
Apr 21, 2012 | Video Game Consoles & Games
Yellow tv colour tint
PLEASE CLERIFY ARE YOU USING COMPONENT CABLE OR COMPOSITE .DID YOU TRYED TO CONNECT TO DIFFERENT TV WAS IT FINE .
Dec 17, 2011 | Panasonic TX-32LM70 32 in. LCD TV TV/HD...
Samsung HDTV model HLR5067W screen flickers when some commercials play other commercials are ok when viewing. Could this be my HD set top box or a cable?
If the TV works well with your dvd and regular programs there are no issues and the flickers due to commercials can be due to excess signal strength or even poor control from the set top box.
Try with another set top box to confirm as some of them can process noise which can cause this issue.
Nov 15, 2011 | Televison & Video
I have a samsung 1080i 52" floor model tv. I don't have a remote or the instructions,. I have hd box from rogers and my picture doesn't fill the screen, Rogers said I have to do it either with a remote or...
you will need a remote to change the picture setting to make it fill the screen! try a cheap universeal remote that you can get at any wall mart
Dec 07, 2008 | Televison & Video
PC keeps on restarting
Power supply can be your issue , when windows boots from CD it a mear dos-mode boot , If it was motherbaord problem it wouldn't boot at all . If you move power supply to test the motherboard issue just make sure it enough power to boot the other motherboard ( some pwer supplies can boot all motherboards )
Jul 31, 2008 | ASUS P5S800-VM Motherboard
Need codes for electrohome lcd tv so i can program it with my rogers hd box
i'm thinking you want to control your tv with the rogers hd box remote.
here is the link please click on the Remote Control Code-Finder
link on it and find your remote.
http://www.rogershelp.com/DigitalCable-Ontario/category.php?id=YY-24
Apr 15, 2008 | Televison & Video
Certain HD settings won't work
no the set uses only two settings in the Y, Pb,Pr which it swithes back and forth. when a 480i,480p SD singal is detected it will switch to 480p, when an HD signal is detected it swiches to 1080i. when it swiches the picture scrambles for a second or two. to correct this in your cable box (if it's a motorola box) leave the tv on, press the power button on the box to shut down the box. next press the menu button on the box and the internal menu will show. use the cursor buttons on the box to select "480i overide" use the arrow to the right to select "streached" them hit menu to get out. hit the power button to turn the box back on.
Dec 16, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Televison & Video Logo
412 people viewed this question
Top Televison & Video Experts
Electro Med Services...
