Question about Loewe Concept L32 Platinum 32 in. LCD TV
Loewe Concept L32, sometimes tv wont switch on, standby light just flashes in response to the remote but doesnt come on (intermittant)
  • 998 Answers
Your power supply is defective try to check the regulator.
Posted on Oct 14, 2010
  • Hartley hare Nov 27, 2010
    Hi, I have the same Loewe Concept 32 and have experienced exactly the same problem intermittantly since I bought the tv 3 years ago. Yesterday, however, despite trying everything, it just refused to change from standby mode. Not wanting to pay for an expensive repair bill for something that might be quite simple to fix, I decided to do some research online. I figured it was probably the power supply board so this morning I removed the back panel to take a look (obviously unplugging the tv first!). There was no obvious componant damage on the board that I could see so I very gently pushed each componant in turn to make sure they were all tight in place. Switched it on again at the plug and with a flick of the remote the standby changed to amber then green.........yippee!
  • unittunited Jul 08, 2011
    Hi there, I have the same problem as you had with your Loewe Concept L32. Has yours been working since you pressed your components or did the problem come back? Thanks, Jennifer jenniferunitt@tiscali.co.uk
I get problem with my loewe television concept L26 that remains stand by even you switch it on using remote. at the power supply circuit only 5V can be seen at connectorW652 and connector W651 no vol
Just understand, that the 5V supply you measure comes from the power supply is used for standby and power On switching purpose. As far as this supply voltage is OK, the fault must be to its main board, because, from the main board comes the power up start voltage back to power board to initialize its whole working.
Check the main board. The power supply regulator board is now Ok; otherwise, you can't get this 5V supply line active. Contact any service technician.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jun 25, 2014 | Loewe Concept L26 26 in. LCD TV
I get problem with my tv that remain stand by even you switch on by remote control
And you are sure the remote is working? You can check the remote is working, by using a digital camera (even from your phone) where you point the remote to the lens of the camera and look on the monitor of the camera is you see a flashing light on the remote when pressing a button.
I hav a loewe concept l32 tv whn u turn on by remote or manually tv turns on then switches off just b4 picture comes on
It sounds that the back-light ivnerter has the fault. Contact any service technician before confirmation.
Dec 02, 2013 | Olevia LT32HVE 32 in. LCD Television
Watching the tv (Concept L32) and it just went off and will now not turn on again. Mains plug fuse good ???
Good day!!!
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Sep 10, 2011 | Loewe Concept L32 Platinum 32 in. LCD TV
I need the service manual of TV LOEWE CONCEPT L32. The image is running horizontally, how do adjust or reset of system software?
I can supply the service manual, but I'm only go to do so when I know that you have returned to FixYa for an answer. I regularly waste time posting all the information for people only to find they never return and I would need to upload this to a filesharing site for you to download. I trust you can understand my reasoning here.
Regards,
BElectric
Jan 29, 2011 | Loewe Concept L32 Platinum 32 in. LCD TV
What cords do i need to up a DVD Player with my Loewe Concept tv?
Check ur DVD player and read ur instructional manual find out if ur DVD player have a HDMI port hub?Tries websites like Amazon.com,Ebay.com to buy a HDMI cable.That the esiest way to hookup a DVD player to a LCD or a Plama tvs.Just one HDMI cable to the DVD player HDMI hub and the other side of the HDMI cable to the tv HDMI hub.
Nov 27, 2010 | Loewe Concept L32 Platinum 32 in. LCD TV
Remote no longer puts TV in standby
I found an original replacement remote for a Loewe ARC332PB at remotes.com
Sep 30, 2009 | Loewe CAL232 TV
No signal!
Hi Rabia,
It seems as if the Picture-in-Picture feature of your television is activated. Please take a look at the remote control and find the PIP button and press it, this should bring the picture into full-screen and allow you to hear the audio.
-SHG
Jan 14, 2009 | Loewe Televison & Video
Loewe Concept L32 Platinum 32 in. LCD TV Logo
1,304 people viewed this question
Top Loewe Televison & Video Experts
Jerry Umali
Grantec 2000
Level 1 Expert
Are you a Loewe Televison and Video Expert? Answer questions, earn points and help others
