I have a LG lcd television. The TV is mounted rather tight to the wall.The optical cable that goes from the direct dish reciever to the TV has to be severly bent in order to plug it in. Could this cause intermittent signal lose, where the screen goes black and LG icon comes up on screen?
  • 998 Answers
Possible. if your optical cable is damage. to check it if broken try to look for the light in the optic cable you must see a bright light if weak it is defective.
Posted on Oct 14, 2010
Lg tv says no signal
1) check the cabling with a tester to ensure both ends works at connected.
2) check the tv signal out from the wall mount outlet with a tester to ensure tv signalling is at acceptable level of strength;
3) if both works, then direct connect the TV to the wallmount tv signal outlet. If still not working, then ask the technicans to come in for fixing.
Jul 24, 2014 | LG 42LG50 42 in. LCD HDTV
Today, while watching tv on the Dish, tv suddenly started powercycling. I unplugged it, waited, and then tried a DVD -- worked fine. Tried Dish again, power cycled again -- on off on off, 1/2 second of...
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | LG 47LD520 47 in. HD-Ready LCD TV
I want to connect external speakers to LG LD400 LCD TV . Please tell me the type of wire used to connect the same to LG LCD
You can use stantard audio cables or a optical audio cable either way you must have a reciever
Dec 03, 2010 | LG 42LC2D 42 in. LCD HDTV
We have no instructions for the wall mount on the entertainment system that we are using with the lg47le5400 tv. I would like to know what hole we use and what screws to mount it. we recieved no...
the wall mount should have came with the proper screws to fit the back of your tv, if the screws fit the mounting holes on your wall mount, fit the larger screws that came with your tv through and make sure its tight, if so it should work.
Jun 26, 2010 | LG 47LE5400 47 in. TV
Just brought aamsung home theatre and cant get tv channels to play through it
the LG has optical audio out put. If the samsung has the same optical input,then use an optical toslink cable to connect and select that input. Other wise Gefen(co) makes optical to analog adaptors available on ebay. You may also be able to run the audio out of you sat reciever or cable box directly to the "aux" inputs of your samsung via reg rca stlye cables and select that input!
Jun 04, 2010 | LG 42LG50 42 in. LCD HDTV
5.1 sound from Sky hd through LG TV
link your optical cable from your HD box to your surround sound.
Then if you go into your HD services menu, press 4 then go to sound make sure its set to Dobly D
That should sort your problem out
Cheers
Little Dish Fitter
Feb 24, 2009 | LG 37LC7D 37 in. LCD HDTV
Lg lcd tv screen goes black but the sound still works 52lg70 screen goes blank, sound still works. i can change settings but cannot see the menu so the tv is still working there is just no picture.
This sounds like a mainboard problem. Unless you do not see a back light flash when you turn on the TV, which may mean it is an inverter board problem, this is most likely fixable by replacing the mainboard.
Jan 20, 2009 | LG 52LG70 52 in. LCD HDTV
Hook up sylvania lc370ss8 LCD TV to a lg lht734 DVD home theater system
Hook a digital optic cable from the Tv's digital ouput to the Recievers digital sound in. This should fix it. You might have to switch the input of the reciever.
Mar 21, 2008 | LG LHT734 System
How do i attach a Wall Mount to the TV?
Hi, Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side. these are for universal mount. http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp I think this clears your problem regards sreejith "Please use caution if wall mounting this product. Follow all directions from the manufacturer of the wall mount and be sure to securely fasten the product to the mount. While the TV can be wall mounted, improper wall installation may void the warranty."
Jul 16, 2007 | Akai LCT3285TA 32 in. LCD Television
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
