Question about Sony Cyber-Shot DSC-W220/B Digital Camera
I have a message on my screen that shows ' USB Mode Connecting....switch on (MENU) How do I get rid of this, please ?
Hi, I have the same problem. so did you find any solution?
Posted on Mar 16, 2011
When I switch on my camera (sony rx100) the screen says usb mode connecting even though there is no usb cable attached. The message stays on the screen and the camera cannot be be used to take a pictu
if you can get to the menu on the camera see if there is an operations menu that says to disconnect the usb or to close the usb. It might just be on and not closed.
Apr 11, 2014 | Sony Cyber-shot DSC-RX100 Digital Camera...
Keeps turning off
Try and reset the player. Reset the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly. Then try this Connect the player to your computer. The screen on your player should turn on, show 'Connected' and indicate the battery charging or full. - If the player does not turn on try other USB ports or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub. - If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the players screen is just not working. If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. <<<<< BUT TRY THIS ALSO >>>>> Check the Device Manager 1. Right-click My Computer, and select -- > Manage. Click Device Manager on the left pane. NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. MTP mode is the recommended and default method for Sansa Players when used with Windows OS. *** See This Tip Posted here **** --> http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem <-- Copy this address into a new window. The Sansa player will show up on Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode) If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes. NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem. >>>> BUT TRY THIS <<<<<<< Connect using MSC mode Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC. Verifying and changing the USB mode of the device to MSC or MTP From the Main Menu, select Settings > USB Mode.
Mar 05, 2010 | SanDisk Sansa Fuze MP3 Player
Sandisk Fuze 4GB locked lights on will not do anything what do I do ?
Mar 05, 2010 | SanDisk Sansa e260 MP3 Player
I don't know how to reset my Sandick Sansa e260 4g?
Mar 05, 2010 | SanDisk Sansa e250 MP3 Player
Sandisk mp3 freezes
Mar 04, 2010 | SanDisk Sansa e200 MP3 Player
Fuse is completely frozen. no functions work. will not turn off, screen says "disconnected" . just charged it.
Feb 27, 2010 | SanDisk Sansa Fuse MP3 Player
My sansa won't turn on
Feb 23, 2010 | SanDisk Sansa e250 MP3 Player
My MP3 player is frozen and it dosent show up on the computer?
Reset the player:
Then try this
<<<<< BUT TRY THIS FIRST >>>>>
Solve your MP3 Player Connection Problem.
Refresh the drivers
Feb 22, 2010 | SanDisk Sansa e250 MP3 Player
My mp3 was on but now it won't come back on or charge.
Reset the player:
Then try this
- If the player does not turn on try other USB ports2_bing.gif or on another computer if one is available. Make sure you are connecting directly to the computer USB port and not to a USB hub2_bing.gif.
If you receive the error "USB Device2_bing.gif Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
MTP mode is the recommended and default method for Sansa Players when used with Windows OS2_bing.gif.
Refresh the drivers
Feb 21, 2010 | SanDisk Sansa Clip MP3 Player
Have ablackberry 9630 dual sim china cannot
"not allowed to dial" problem
--> SOLVED :dance2:
Hello everybody, after playing arround for a while, collecting a lot of other information from the net, I got the problem solved with my phone:
01. Make sure two SIMs are online with good coverage, WLAN switched off.
02. Press the "call"-button and type in *#9646633#
03. The phone shows "Engineer mode" with a menu of 10 different items.
04. Go to No. 10 "RF test tool", using the up/down button at the left side of the mobile.
05. Choose "GSM"
06. A message shows up "Wifi....blabla", just confirm with OK
07. Choose "Power Scan"
08. Select your local GSM frequency (in my case DSC 1800 for Germany) and press OK.
09. The mobile will freeze now, because its adjusting itself. Leave it like this for about 2-3 minutes and wait !!!
10. Connect your mobile via USB cable to a PC, DO NOT CONFIRM any connection mode at your mobile, just and ONLY connect the cable!!!
11. Press the Menu button (second from the left, the one with the seven small dots on it) until you are at the main menu with the 12 icons on the display.
12. Go to "Settings" --> "Network Setup" --> "SIM1 network setup"
13. Go to "Preferred mode" and choose "GSM preferred" or "GSM only"
14. The mobile will switch to your selection, but the message that it will stays on display. Do not press anything else, just wait for about 10 - 15 seconds.
15. Disconnect the USB cable from the phone, it will show you that it has switched to your selection.
16. Get back to main menu, switch off and restart the mobile --> DONE. :smoke:
I hope my "weekend job" is helping a lot of other people to get rid of this annoying problem. Please bomb your supplier with emails, so maybe we do get a general solution to this problem. Next I will check why I do not get the "Opera Mini 3" working, maybe an update is necessary first.
Nov 17, 2009 | Cell Phones
Sony Cyber-Shot DSC-W220/B Digital Camera Logo
94 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
