How do I load paper in the hp officejet j4680 all-in-one printe
SOURCE: HP officejet/HP officejet pro J4680
What do I do to ron Faxs from the top instead of the window?
Posted on Jan 14, 2009
SOURCE: hp officejet j4580 will not load paper
i hav no idea and that is a stupid quesion.. what you do is call a mechanic and not let somone on the internet give you false information
Posted on Apr 16, 2009
nalin_elliot
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
Riztech
  • 731 Answers
SOURCE: how to scan with hp officejet j4680
Please install the printer software and try to scan via the installed software from the computer. Or, start scan using scan button from printer; after installing software.
Regards,
Rizwan
Posted on Mar 03, 2010
  • 46 Answers
SOURCE: incompatible print cartridge tri color error
There may be debris that is blocking the communication between the cartridge and the printer. Remove the cartridge and unplug the printer from the power supply. Take a little bit of rubbing alcohol on a cotton swab and wipe off the contacts on the cartridge as well as the contacts inside of the printer. Allow both to dry for a few minutes before plugging the printer back in and re-installing the cartridge. This should clear up any miscommunication between the two.
http://swapink.com/Merchant5/merchant.mvc?Screen=cp_faq&Store_Code=SI
Posted on Mar 26, 2010
Fails to print after paper jam fix
If you are still seeking assistance with your Officejet J4680 printer rosemarie gogarty I would be happy to help. Have you tried a hard reset? To do so, leave the printer on and unplug the power cable for 1 minute. While it is unplugged, hold down the power button on the printer for 10-15 seconds to release any built up power, then after the minute has passed, plug the printer back in.
If the issue persists, let me know, I will happily do all I can to help,
Thanks,
I work on behalf of HP.
Jun 02, 2015 | HP Officejet J4680 All-in-one Printer...
Can i over ride the color cartridge on an officejet j4680
you can to print in option click b.w but if the color is empty then clever little hp made there printers to hault printing there fore making you have to buy another cartridge
hmmmm greedy much
have a great day
sonic boom electronics australia
Jan 03, 2011 | HP Officejet J4680 InkJet Printer
Print Cartridge Problem: (Tri-Color) See
Top three solutions to this query at HP support are close to your described problem: (not exact) Try the closest match to your error.
http://h10061.www1.hp.com/ccsearch/search?pname=HP+Officejet+J4680+All-in-One+Printer&qry=print+cartridge+problem+tri-color&submit.x=0&submit.y=0&ctry=us&lc=en&dlc=en&mode=lz&tmv=0&method=prodFinder&pid=3692887&productBigSeriesOid=3645080&spid=3692888&opname=HP+Officejet+J4680+All-in-One+Printer&pname_desc=HP+Officejet+J4680+All-in-One+Print%2FFax%2FScan%2FCopy&ptype=consumer&stype=pn&contextual_lname=&spname=HP+Officejet+J4680+All-in-One+Printer&temp_hql=s-001%2Cs-002%2Cs-004%2Cs-003%2Cs-007%2Cs-005%2Cs-006%2Cs-017%2Cz-001%2Cc-002%2Cc-001&product_line_code=DU&search=0
Nov 28, 2009 | HP Officejet J4680 InkJet Printer
Paper jam light is on is it really a paper jamon hp J4680 multifunction printer
If it is a paper jam, here's how to solve it on that printer.
(do not delete)
Oct 21, 2009 | HP Officejet J4680 InkJet Printer
Streaky printing HP OfficeJet J4680
this could also be as simple as going in to your device manager and refreshing the driver first, unplug the printer from power and PC, reboot pc and then power up printer let it go threw its motions and then once the pc is completely booted connect the the usb cord and try again, you may also have a bad cord
Sep 21, 2009 | HP Officejet J4680 InkJet Printer
Hi, i have a HP officejet J4680 all-in-one. The
Clean every moving part with suitable substance. It will be better that you get a support.
Aug 12, 2009 | HP J4680 Office Jet All-In-One Printer
Officejet J4680 won't printer after router reset
) You might not have to do this step, but if all else fails reset the HP Officejet J4680 network by pressing the setup button (the wrench) go to Wireless Menu and Press OK then go to Reset Wireless select YES and press OK. If that doesn't work then there is another reset that I found in the setup menu (the wrench) under Tools and then Restore Defaults. I wound up doing both resets on my Officejet J4680
2) Power the HP Officejet off and on for good luck (again optional but might help).
3) Make sure the the wireless on the printer is enabled by pushing the button on the left side front under the 802.11g so that the blue wireless light turns on. (again optional, but make sure the blue antennae light is on)
4) Connect to the HP Officejet J4680 wireless printer directly from the MAC (this is pretty cool stuff) Click on the Airport icon at the top bar of your mac screen, if you see the hpsetup listed then click on it, if it is not listed then click on join other network and type in hpsetup and click Join. This will join the mac to the Ad Hoc HPSetup network and you can now setup the printer from the mac!
5) Important: Print a network settings report on the HP Officejet by pressing the setup button again (the wrench) go to Print Report and press OK, go to Network config and press OK. If you try and print this before you connect (step 4) you will not get the info you need in the report, so connect first from Mac to HP then print this report.
6) fire up safari or Firefox or chrome browser on the Mac and type in the URL that is listed on the report you just printed out. It starts with http:// type in the http:// and the 4 numbers all together with no spaces into the address bar in your browser and press return.
7) you are now connected to the HP Officejet J4680 via the web browser interface. Click on Networking, then Advanced, click the infrastructure tab and fill in the passphrase info for your router type it again to confirm, then click apply. It should now connect and print from the router. But below is a good video with even more detailed info:
8) More Officejet J4680 setup via the mac using this very thorough guide: http://www.youtube.com/watch?v=Rjd1ZqJ89N4
Jul 15, 2009 | HP J4680 Office Jet All-In-One Printer
Computers & Internet Logo
221 people viewed this question
David Payne
David Payne
