How do you adjust the water level for small, medium and large loads of laundry on Kenmore washer model # 29822800? I never had a washer where I couldn't choose how much water entered the tub. We purchased this washer pre-owned and didn't get a manual. I would like a repair and owners manual. Thank You, C. Paton
    President:
  • 2,468 Answers
You will need to order the manual from sears directly,as for the load size there is no manual setting on this unit as the e.c.u. takes care of this automatically
Posted on Oct 14, 2010
How many gallons of water does the Kenmore elite SM9711174 use in each cycle?
Hello Tricia
Ask them direct, but there are a lot of variables in your question like wash size small, medium or large load, programmes, pre-wash or not, and the absorbency of the laundry in the washer.
All new models are energy efficient, so they use as little water as they can which also reduces electricity use. My Whirlpool had a sticker that said it uses about $25 of electricity a year.
http://www.kenmore.com/search=elite
Dec 31, 2015 | Kenmore Washing Machines
My kenmore 29822800 won't fill with water, it works on spin and drain
The last time I moved, my washer/dryer combo (Frigidaire) had the same issue for approximately 7 months before finding out all I needed to do was level the washer, and of course, make sure the faucet connected to the washer is turned to on position. Hope this is helpful.
Praysemema.
Mar 13, 2013 | Kenmore Washing Machines
Were is the level switch hose?
The air dome hose as it is called attaches to the water level switch in the control panel its the one where you selector small, medium or (X) large fill level from there it goes down back panel and attachs to the outer tub
This youtube video will show you how to take apart the washer http://www.youtube.com/watch?v=Puq8jWMY9Iw
Hope this helps
Gene
Aug 03, 2011 | Kenmore 22422 Top Load Washer
I have a Kenmore Elite Total Care System Top Load washer, and for the past two days, the water level will not fill past the medium level even if the setting is on Large level.
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Apr 17, 2011 | Washing Machines
Washer will overfill on small load and large
If this happens only on small load cycle , then it can be a faulty timer board.
however check also the water level switch, when there is overfilling this part is always the first suspect.
May 21, 2009 | Kenmore Elite 21082
Water drains underneath washer
the load could be to small and all the water whats been left after the wash might be because you only need small pressure on a small wash and the pressure wont make the water evaporate. or you might just need a new drainage pipe i would put less water in next time and see if its better if not get a local self employed plumber.
Dec 01, 2008 | Kenmore 46462 Front Load Washer
Kenmore 80 series model# 110.28803890
Hello. Yes there is a fill level pressure switch. It is pressure activated by the pressure of water rising in a tube as the water rises in the tub.It's easy to find and easy to replace. Look for the tube and follow it to the switch. Parts for Kenmore are available at 1-800-516-9625 or at http:\www.sears.com.
Good luck.
barneyluc
Oct 19, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore stackable water level
replace the water pressure switch it is non ajustable for insurance purposes
Apr 06, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
119 people viewed this question
Top Washing Machines Experts
