Question about Frigidaire Dishwashers
Dishwaser when it cycles from prewash to wash a cl apears on display and then washer kicks in pf power failure
  • davidquast4 Oct 14, 2010
    W
    WFrigidare dishwasher when you select a wash cycle unit operates properly in prewash when it cycles to wash unit kicks off and a pf appears on the display.opening up the unit several inches of water remains on the bottom.hitting the cancel button will pump off standing water their is no obstrucktion.sometimes unit will pop off
    Frigidare dishwasher model gld4355rfb2 new 08/o8.select cycle and unit goes thru prewash.when unit cycles to wash a pf appears in display and unit shuts down.standing water at the bottom of unit will drain if you press the cancel button so their is no obstruction.unit on occations trip wall socket circiut breaker.
  • 10,865 Answers
Hello David. There are two possibilities here.
The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
The timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Joe
Posted on Oct 14, 2010
  • 11,896 Answers
The cl code is the latch code under normal operation of the dishwasher. In some cases when the door latch is good and isnot faulty which commonly is; The micro processor starts to fail and the unit thinks the door is open but just continues to run. That is when you need a new circuit board
  • Nate Stansfield
    Nate Stansfield Oct 14, 2010
    if pressing the cancel button doesn't get rid of the power failure error "PF" then you have a bad control board. So you will need to replace the control board itself.
    Press and hold the Clear/Off button for three seconds . A beep wil sound and Door Loc will flash until the door unlocks
    "PF" indicates the electronic control detected a Power Failure.
    This could have been caused a brief power outage OR may be an indication that the connections at the plug are loose
  • Nate Stansfield
    Check the lid switch. Check the thermal fuse. Check power from power inverter to main control board.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. CL means child lock, it might have got locked. To resolve this issue press and hold the AIR DRY/RINSE ONLY button for 10-15 seconds. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
  • Rylee Smith
    Rylee Smith Oct 14, 2010
    PF error indicates power failure which means that the control has failed and should be replaced.
Kenmore he4t washer codes
The control for the washer likely detected a problem. The failure code will not be displayed on all models of washers. You can recall the error code by using this procedure:
  1. Select the "Drain/Spin" cycle.
  2. Select No Spin.
  3. Press the "Prewash" options and hold this button for 5 seconds.
  • Immediately after those 5 seconds the last stored failure code is displayed for 4 seconds.
  • After those 4 seconds the display switches automatically back to the selection mode
NOTE: If your washer does not have the Pre-Wash option. Then use the 2nd Rinse button (called Extra Rinse). The failure code should stay in the memory so that it can be recalled as often as necessary and as long as it is the youngest failure Code.
Nov 30, 2012 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
My LG comes up with the error code PF
PF - Power Failure - PF error code indicates a power failure during the washer's cycle.
Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks
Oct 23, 2011 | LG WM-2277HW Front Load Washer
Machine will not spin and displays FP fault
Hi There
I have this for you and i hope this will get you in the right direction. Let me know how this goes. By the way Merry X-Mass and a Happy New Year.
PF Power Failure PF flashes if the washer loses power during a running cycle. The washer does not flash PF when it is first plugged in.
Press START to continue the cycle from the moment that power was lost -OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle. Thank you for writing to fix ya.
Best Regards Richard
Dec 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
What is the kenmore washer model # 21086 water pump failure error code
PF - Power Failure - PF error code indicates a power failure during the dryer's cycle. Press and HOLD start to continue the cycle, or press off/pause to clear display.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 16, 2009 | Kenmore Elite 21086
Code pf came up and the washer does nothing
PF Power failure "PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost.
OR
Apr 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool duet gas dryer PF error will not reset as per manuals
Mar 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washer stops washing and gives a p5 trouble code
Mar 12, 2009 | Kenmore Elite 45986 Front Load Washer
Pf and of codes comming up on screen
Feb 11, 2009 | Kenmore 22422 Top Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Dishwashers Logo
55 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
