Question about Maytag 24 in. MDB4000 Built-in Dishwasher
Not cleaning leaving residue - top sprayer doesn't spin
    President:
  • 2,468 Answers
Check spray arm for food residue build-up,if its clean then it may be the water feed conduit from the bottom tub up to the arm on top that leaking by and losing water pressure
Posted on Oct 14, 2010
3 Suggested Answers
  • 401 Answers
SOURCE: leaving residue in glasses in top rack mostly
check the filter down in the pump. if that is clear you probebly have a bad water intake valve
Posted on Feb 27, 2010
heatman101
  • 43501 Answers
SOURCE: My dishwasher leaves white residue on cups of the
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Posted on Mar 04, 2011
Top Rack doesn't get clean
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 12, 2011 | KitchenAid Dishwashers
MY DISHWASHER DOES NOT APPEAR TO BE CLEANING MY DISHES
Your sprayer arms may be clogged.
Finally, the bottom of the door INSIDE the washer often get covered with gunk. Be sure and gently wash the bottom of the door INSIDE. You can open the door, spray some window cleaner on the bottom and then gently brush away the 'gunk.' Rinse with hot water from a pitcher or your sink sprayer and this can eliminate some of the residue that is showing on your dishes.
Jun 11, 2011 | Kenmore PRO 24 in BuiltIn Dishwasher with...
2 MONTH OLD bosch DISWASHER. WATER WILL COME OUT BUT TOP SPRAYER ARM WONT SPIN??? LEAVING DISHES ON TOP DIRTY??? LOTS OF WATER PRESSURE THATS NOT THE PROBLEM HELP!!!!!
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker
Mar 31, 2011 | Dishwashers
heatman101
Feb 15, 2010 | Kenmore 24 in. 17033 Built-in Dishwasher
My dishwasher is leaving a lot of residue on dishes
I had the same problem and fixed it by disassembling the lower spray arm and return filter, and cleaning all the junk out.
Most dishwashers have 'risers' that bring the water up to the top sprayer or arm located under the top rack. If the recirculating pump is plugged even a little there won't be enough volume or pressure to get the water up there.
Test this by putting a dry muffin pan in the top rack, flat, and running the dishwasher for a bit. If there is no water on the top (or the bottom) either the top sprayer or the sprayer arm underneath the top rack is not getting enough volume.
To fix this you need to clean out the screen and filter, where the water returns to be recirculated. If you don't have any confidence to remove the parts and clean it out yourself, get an appliance repair person to do the job.
Aug 26, 2009 | Dishwashers
Residue inside dishwasher sprayer arms
What it is called is calcium deposits, your water is high in calcium. You may have to clean the part occasionally with CLR or something similar.
You should look into flushing your hot water tank occasionally as well, calcium deposit biuld up after awhile and your water tank has to work extra hard to heat your water, which cost you more money in the long run.
Hope this helps you .
Aug 15, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Top sprayer wont spin . dishwasher goes through cycles and only partially cleans. bottom sprayer does spin.
The sprayers are not powered but rely on the water pressure to spin them. If it's not spinning it could be
the spinner isn't engaging in the top rack as you slide it in
blocked jets on the spray arm
blocked feedpipe to the spray arm
faulty pump
Most dishwashers are fairly easy to dismantle to check the first few
Jul 02, 2009 | Maytag Dishwashers
My 6 yr old Kitchen Aid dishwasher is leaving food residue
After checking all sprayer arms for clearance, and checking heating element and discharge pump, the problem was solved by replacing the small sprayer arm at the top of the washer. This small arm had popped off some time ago - obviously the water pressure was excessive for the small and unimpressive fastener. Luckily we had saved this piece, which I refastened with a strong aluminum non-corroding small bolt. Presto - now the water distribution is back to design specs, with sufficient water coming out under pressure from the mid level arm. Lesson: always look for the simplest cause first with the simplest solution. TCA
Jun 20, 2009 | KitchenAid Dishwashers
Dishwasher
Most dishwashers have a little filter basket in the bottom. Depending on the brand, you can slide out the bottom rack, and in the bottom underneath the sprayer (the propeller thing) there should be some sort of basket that can be removed and cleaned. You also may have some water quality issues, or some detergents will leave residue. Also, make sure most of the large food is removed before loading.
Nov 05, 2007 | Baumatic 24 in. BFD60SS Free-standing...
Dishwashers Logo
123 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
