Question about Sport & Outdoor - Others
Looking for parts diagram for falco over and under 410 shotgun
What is the value of a Iver Johnson .44 cal. single barrel shotgun, serial no.07??
sorry but fixya does not know gun values . try a gunshop
Oct 03, 2017 | The Optics
Barrel for 410 shotgun
See if this site has what you need. If they don't, it's probably not available. Not saying it can't be fixed by a gunsmith, just it won't be easy or cheap if a ready made replacement is not available.
Firearm Parts Accessories Military Surplus Numrich Gun Parts
Sep 22, 2017 | Optics
What size 410 ammo 2.5" or 3"
Depends on your shotgun. If it will chamber a 3" shell, then it is probably OK to use them. Obtain a used 410 cartridge and see if it fits.
If you are concerned, using 2.5" shells in a 3" chambered gun is OK.
Apr 08, 2016 | Optics
Where can I find parts for a Harringston & Richards 410 with exposed hammers?
You may try Numrich (gunpartscorp.com), but you'll first need to determine your exact model, besides just the caliber/bore:
Harrington Richardson
If you cannot find the part you are looking for, you may want to go to a small shop near you that can help.
Sep 02, 2014 | Drills
How to take the forend and barrel off a Winchester M37 410?
The old 37 has a screw about half way up the forend. Remove the screw and gently and carefully remove the forend by pulling the top down.Lay a towel or something similar down under the forend to catch any loose parts such as the forend shoe and the forend shoe retainer. Pay close attention as to how they fit together so as to make it easier to put your shotgun back together.
To remove the barrel, hold the barrel with one hand and push the barrel release on top the receiver with the other hand. This should let the barrel fall forward, allowing you to lift the rear of the barrel off of its hinge.
Good luck with your old classic shotgun and take good care of her.
Dec 26, 2010 | Rock & Ice Climbing
Falco fairing question.
and need the small black plastic panels that bolt onto the bottom of the fairings I tried http://www.apriliayorkshire.co.uk but cant find any diagram with these panels ....! What are they called and where can I buy them ? ,Its called Lower fairing, black You can find it under Genuine Aprilia Front body - Front mudguard spare parts for SL 1000 Falco . Look up part number 5 Here it is at AF1 listing . Part number AP8158773. Aprilia Yorkshire list its for 47.18 pounds __________________ ,,,
Nov 10, 2008 | 2002 Aprilia SL Mille Falco R
Sport & Outdoor - Others Logo
65 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
