Question about Westinghouse Electric LCM-22W2 Monitor
I turn on computer, there is no boot up indication given on the monitor. Have to constantly adjust the video type required.
I NEED YOU ANSWER ME, HOW I FIX MY MONITOR, MY MONITOR IT DOESNT POWER ON
Posted on Oct 30, 2010
Computer monitor cycles on and off when the computer boots up but seems to have constant power when just turned on
The boot process goes through various display modes. Each time it switches, the monitor has to set itself for that mode. This causes the monitor to flicker while it's adjusting. Perfectly normal operation.
Sep 02, 2014 | Acer Computers & Internet
Why does my monitor have a white screen
First, it could be out of adjustment--turn the brightness and contrast controls up and down to see if it makes a difference.
You could have a bad video card in the computer. Do you have another monitor to try to see if the actual video output is good? This is the easiest way of troubleshooting.
When you start the computer, can you see any white printing on the screen indicating it is booting? Does the problem start once Windows starts? If so, try starting in safe mode. If you can do this, then I'd suspect video driver problems.
Dec 27, 2011 | BenQ FP791 17" LCD Monitor
My monitor is HANNS G JC 171 D and I have a problem with it. Constantly includes automatic adjustment of monitor and menu buttons on the monitor does not react. This problem was gone until yesterday.
Click Start - Run - Type temp - Try to delete most of the temp files from the folder
Click Stat - Run - Type %temp% - Try to delete most of the temp files
Click Start - Run - msconfig - services - hide all microsoft services - disable rest of the services - apply - ok - restart computer
This should resolve the issue, else restart computer and start tapping F8 o keybaord. You will get a black window Advanced Boot Menu. Select Last Known Good Configuration and hiot Enter.
It must restart the computer.
Please share the result.
Regards,
Anirban Mazumdar
May 11, 2011 | Computers & Internet
When turned on all i get is fans constantly running and nothing else was working fine up till then
Sometimes the best answers are the simplest. First, make sure the video monitor is switched ON, securely connected to the computer video port and the "brightness" control set to at least mid-point. Before focusing suspicion on the computer itself, try a different "known to be working" monitor AND CABLE. Failing all the above you should carefully observe a manual re-start of the computer noting the presence or absence of 1.) pilot or drive indicator lights on or flashing, 2.) A beep tone or series of beeps emanating from the computer ( one beep is good - more than one is an indication of trouble requiring a technician ). 3.) Fan(s) running. If you have lights, fans, and a beep but no video, ( not even a blinking cursor in the upper left of the screen ), replace the video or graphics card in the P.C. with one known to be working. This should solve the problem.
Jan 29, 2010 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Monitor won't start when I boot up - without a lot of fiddling!
First try to do monitor self test.Disconnected the blue cable VGA or white colour connector from monitor to the computer. Turn on the monitor and check if you are able to see colours or line on the monitor.Indicating self test monitor is working fine. If you are using Video card on computer connect monitor directly to onboard video and check. Good Luck.
Aug 19, 2009 | Computers & Internet
Monitor turns black and with a not optimum mode pop-up
Press F8 when you boot your PC, Then boot on SAFE Mode...
Right Click on Desktop>>Properties>>>Settings>>>Advance>>>Check the Apply the New Setting without restarting.
Click Apply then OK
Rebbot the computer to a Normal Boot
Oct 09, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Viewsonic E53 monitor
Base on the information given to me.
I think your computer is on sleeping mode.
first thing check if the video cable is not loose connecting the pc.
because what would happend, if it is loos it would turn on and off at times.
The other thing you can do.
right click on the desktop.
go to properties
go to screen saver
click on power
adjust the time you want your monitor to shut off.
Dec 06, 2007 | ViewSonic G90fb 19" CRT Monitor
"BLANK SCREEN, CLICKING SOUND, & NO LED INDICATED".
some electronic components on the circuit was shorted.
clicking indicates this type of problems.
Dec 03, 2007 | Compaq FS7600 17" Flat Glass Monitor
'Input Format Not Supported' (please help me!)
OK try booting up in "Safe Mode" Press F8 just after Turn on, when and if ya boot into safe mode then adjust your Video settings to say 1024x768x32bit and then reboot, if all good then when you are at the desktop, then adjust the settings to whatever you require... maybe 1280x1024x32bit.. Ya all good. If this doesn't work.. try the Monitor on another PC.. see if it works... if it does.. then maybe ya Video card is going/gone "Toes up" if not, then ya got a fault in your monitor, usually some sort of Power Supply problem or the like.
Jul 23, 2007 | Acer AL1916B 19" LCD Monitor
Westinghouse Electric LCM-22W2 Monitor Logo
97 people viewed this question
Top Westinghouse Electric Computers & Internet Experts
greg benton
pankaj rautela
pankaj rautela
Vernon Taylor
Are you a Westinghouse Electric Computer and Internet Expert? Answer questions, earn points and help others
