Question about Car Audio & Video
Hi, I have a new Mitsubishi car radio cassette unit MZ311762 (MEX710RDS) which I propose to use as a replacement in the sound system of an Audio Visual projector. I have connected it up to a 12 volt battery and speakers. The unit plays audio cassettes perfectly but at relatively low volume. The volume control/fader (of the 'click' variety) makes no difference when rotated. Can you advise please? Thanks. Graham Sergeant
silly girl
  • 513 Answers
SOURCE: Can hear crackling or spitting sound when selecting HI-FI
The "crackling" sound you describe sounds suspiciously like mis-tracking. That is: The result of the Hi-Fi heads (which are on the rotating video headwheel or drum) not exactly following the recorded tracks. Have you tried adjusting the tracking slightly? The reason this happens is that the Hi-Fi tracks are MUCH narrower than the thinnest video track (used for 6 hours per T120 tape). Tape stretches and shrinks as it ages. Video recorders wear with normal use in such a way that the tracking changes. The problem is often worse with tapes recorded at the SLP (6 hour) speed because the servo cannot correct errors as fast when the tape is moving slowly (on some machines only). Tape quality also counts...and manufacturers change their formulations without public notice. All these things can lead to "archived" tapes being lost. Solution: Use the best quality tape you can afford, not the cheapest; record at the highest possible speed. Store the tape carefully. Never use a cheap "rewinder" because they can over-tighten the tape causing wrinkles, stretches, and other kinds of damage.
Posted on Mar 14, 2006
Vulfen
  • 5 Answers
SOURCE: Cassette player not working
Cassette players usually have a little rubber band that connects the motor to the spindles. If everything else is fine, I would suggest seeing if it slipped off somehow (or got cracked and snapped)
Posted on Jul 15, 2007
  • 319 Answers
SOURCE: Denon DRW-585 dual-cassette deck makes clicking sound
There is an outside chance your tape cassett has a static charge. Tape in plastic case of cassette can build up significant electrical static which can partially discharge as tape is run. It can sound like random thumps, ticks, pops ect. Wrap cassette in a damp (not dripping wet) cloth, for several hours, then try again. This can also happen to the reels and drive rollers of the deck
Posted on Apr 23, 2008
  • 59 Answers
SOURCE: no radio volume on sony
The radio has a bad tuner. Take it to get repaired or replace the radio.
Posted on May 30, 2008
wdwbusiness1
  • 4 Answers
SOURCE: car stereo installation speakers
Yeah, rewire that.
Posted on Aug 19, 2008
Lost sound on 2005 impala. radio works. seems like amp problem.
Do you have base or up;level system ?
Table 1: Radio Features
Table 2: Cassette Features
Table 3: Compact Disc Features
Table 4: XM Advisory Messages
The radio receives power from the RADIO fuse in the junction block-right I/P. Ground is provided via G201 and G202. The radio is enabled/disabled by class 2 messages from the body control module (BCM). The radio routes audio signals from the digital radio receiver or the vehicle communication interface module (VCIM) to the speakers and/or amplifier when directed by class 2 messages.
The Entertainment System on this vehicle is configured with an AM/FM stereo radio with the radio data system (RDS) and either a cassette player or a CD player or both. CD and cassette. The uplevel system provides the customer with extended range speakers and an audio amplifier. Satellite digital radio (U2K) is available with uplevel systems.
The following list shows the radios available for this vehicle:
• Radio (ULO) - AM/FM Stereo, Cassette with RDS
• Radio (UNO) - AM/FM Stereo, CD and RDS
• Radio (UPO) - AM/FM Stereo, Cassette with CD and RDS .The complexity of the radio systems on these vehicle is mind blowing .
Your best bet take it to a GM dealer , has features you are unawear of .
DTC B1025, B1035, B1045, or B1055
When the radio is powered up, the radio supplies low level audio signals to the speakers. If the vehicle is equipped with an audio amplifier, the amplifier will boost the signal sent to the speakers.
DTC B1025 Audio Output Circuit
Install a scan tool.
Turn ON the ignition, with the engine OFF.
With the scan tool, monitor the DTC Information for DTC B1025.
Does the scan tool indicate that DTC B1025 is current?
Jan 31, 2017 | Cars & Trucks
Have delco radio head unit model #1618995. has 7 wire plug 2 white wires on end one on end has small plug where do plug it too? has power checked with meter
Hi Steve,
I'm going to need a little more information. That looks like the serial number. I can't find any info on #1618995. What kind of car did it come out of? Sounds like some kind of Chevy. Is it an aftermarket radio? Delco is a bad choice, unless your replacing your radio with an other factory radio. What kind of car are you putting it in?
Let me know if your just trying to put an aftermarket stereo in, radio kits and wiring harnesses are available for most cars. Ray
Jun 11, 2015 | Ac Delco AM-FM Radio Cassette
My mits I replace all the suspencion but still some ruarling nise on the front of the car
If it changes with speed and you didn't replace the wheel bearings, that is probably what it is. Torque on new bearings is crucial.
Dec 05, 2013 | Mitsubishi 1990 MIRAGE Radio a1z102506...
I bought a DVD player for my 2006 Mitsubishi Lancer. Thr new unit came with wiring diagram, however there is no information on the original Mitsubishi harness to match wires. The unit has a Fujitsy sticker...
Hi, please check the colors below for a match. If these are not your colors, please get back to me.
2006 Mitsubishi Lancer Car Stereo Installation Diagram
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Accessory Switched 12v+ Wire: Blue/Yellow
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Red/White
Left Front Speaker Negative Wire (-): Red/Blue
Right Front Speaker Positive Wire (+): Red
Right Front Speaker Negative Wire (-): Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Blue
Left Rear Speaker Negative Wire (-): Yellow/Red
Right Rear Speaker Positive Wire (+): Light Green
Right Rear Speaker Negative Wire (-): Yellow/Green
Mar 20, 2011 | Mitsubishi Raider 2006-2007 Car Radio...
Need master code for radio in a 2000 ml320
Regretfully due to reasons of theft or piracy we do not pass the radio codes here at FixYa. If you contact your local Mercedes-Benz dealer they will give you the 5 digit code. (You must have your registration and know the complete serial number of the radio)
Kelly
May 05, 2010 | 2007 Mercedes-Benz ML320 CDI
Securrity code needed for radio/cassette player in 1990 Mitsubshi
Hi PJ, Is this the original sound system for the vehicle? if it is then contact your local Mitsubishi dealer with your Vin Number and Registration Document/title they will have it on file.
Good Luck!
Paul 'W'
Jan 06, 2009 | 1987 Mitsubishi Passenger
AM/FM is silent. Cassette works but sound is somewhat scratchy.
This is a common problem with this stereo. The problem is all the electrolytic capacitors in the stereo leak and change value. This is a major repair job. There are several companies that still repair this stereo. However, I suggest a replacement. There are aftermarket stereos that will work in place of the original while updating you to CD. There is wire harness adaptor needed for the installation and can be purchased from many on line stores.
Nov 11, 2008 | Car Audio & Video
Car radio
remove radio unscrew front of radio to expose circuit board and desolder and resolder a new led onto circuit board then replace unit
Oct 03, 2008 | Car Audio & Video
Car stereo installation speakers
Your old unit was a common ground unit meaning all speaker grounds as well a radio ground were the same. The new unit should NOT be connected to this wire configuration. Newer units change the potential difference of the speaker power meaning that the - wire of the unit may have negative 24v on it so IT CANNOT BE REFERENCED TO EARTH OR CHASSIS GROUND.
I would recommend rewiring the speakers to the radio for best reliability and sound quality.
Dec 31, 2007 | Jl Audio 12W3 Car Subwoofer
Car Audio & Video Logo
90 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
