Elektrotanya for electronics experts
you can find the service manual for free here.
SOURCE: Kyocera Printer FS-1800 plus
Hi, first of all,pull out paper tray and check any paper,or scrap jammed.When paper tray is pulled out,open paper transport unit-You have green handle on the right side of machine,in the place of right side of paper tray.Pull out paper transport and remove paper.Just close paper transport unit and paper tray,open and close top cover.
SOURCE: Problems with Kyocera Mita FS-1920
Make sure that your paper sizes match in the control panel of the printer in Windows. It will not only cause the duplex not to work but could cause jamming problems as well. When printing in duplex mode, make sure it is turned on.
SOURCE: Kyocera fs 1750
First check the neck of the bottle and clean it if dirty
secondly if this does not cure the fault then the sensor in the drum assembly is probably dirty. You will ether have to strip off the end of the drum and clean the led and photo sensor or replace the drum unit.
SOURCE: Kyocera printer driver not enabling duplex
You can find your driver here: http://usa.kyoceramita.com/americas/jsp/Kyocera/download_center.jsp?pid=10156&pcat=10563&rcid=10009&rscid=10007
SOURCE: Kyocera FS-2020D won't print
You have to go to setting to change the cassette paper size , what happen is : in the setting that cassette has different size value, so when you try to print A4 it ask you to load it in the bypass or the Mp. all what you have to do is: go to cassette setting or comon setting and change the cassette siz to A4, and it will fix your problem.
Thanks for using Fixya
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
