Question about Optoma HD65 DLP Projector
The projector turns on to a blue screen for about 5 seconds and then switches to the red light bulb dot. i heard there could be a problem with the color wheel from someone?
  • 20 Answers
When the color wheel starts to go out, what happens is the picture will usually be very faint and pulsate with no color (just black and white). This will last for about 10 to 20 secs then the projector will shut off. If you have a clear picture then it could be your lamp. Need more info. Does the projector shut off after the red light appears? Also you can pull the lamp out and clean the contacts with electrical contact cleaner which can be bought online or at your local radio shack. Pick up some denatured alcohol while you are there. While your lamp is out, use compressed air to blow out dust and debris from the fans and color wheel. You can clean one side of the color wheel very easily while the lamp is out. Use a q-tip with the denatured alcohol. Wipe from the middle towards the outer part gently. If you do it at a slight angle you can turn the wheel while you clean it. To clean the other side requires removal of the outer casing. Make sure your lens is clean as well. Use the compressed air to remove dust/debris from it. If you notice smudges on the lens, you can clean it with the denatured alcohol. Do not use any other type of cleaner on it and use a very soft cloth, preferably one made for cleaning plastic eye glasses. Be very gentle as the lens can easily be scratched. A build up on the lens can cause the error you described as well. If you are able to get into the menu, check and make sure your lamp hours are not maxed out. If they are reset the counter.
Posted on Oct 23, 2010
Lamp replace light is still one even though i replaced the bulb
I'm having this same problem. The Ready light is on Green and the LAMP light is on Red. Replace Lamp light is also on. The device turns on, displays the blue SANYO boot screen for a few seconds, then shuts off.
Jul 14, 2010 | Sanyo PLC XP41 Multimedia Projector
Hi there,there is a ring of blue dots
clean the lense of your projector, dirt or moist of water may be possible reason
Feb 18, 2010 | Canon LV-S3 Multimedia Projector
Optoma hd65 projector new bulb wont turn on...cant reset timer!
I think it's a lamp driver issue from what I've seen others have gone through. I also read that if you go through the sequence of unplugging, plug back in, wait 20 seconds and try to turn on, multiple times, it will finally kick on and work. I just got mine to turn back on by doing this and waiting through the fan cycling without the light turning on. After the 4th sequence the light flickered. After the 7th sequence it finally turned on and is working. Now I can watch the Super Bowl and will look into replacing soon.
Jan 31, 2010 | Optoma HD65 DLP Projector
Large dot in the middle of the projected display
there is a burned-in spot on the polerizer light filter for the blue lcd. it makes sure the light is blue coming through, that's why it is black on a blue screen, and yellow when the red and green are the only light showing through. it needs to be replaced. pat # PFiLW0213CEZZ.
May 21, 2009 | Sharp XG-E3500 Multimedia Projector
Bulb Shattered...After replacement does nothing!!!!!
Did you get any anwsers as I'm having the exact same problem with my projector, the noise for few seconds, the light flashing...
Thanks
Dec 19, 2007 | InFocus ScreenPlay 4805 Multimedia...
Growing blue patch
you have to replace prism it has 3 small lcd screens Green Red Blue one of them is beginning to burn they are very expensive strip projector down with no power connected and take damaged screen of then block that area so no light can pass through it with fire resistent material you will get some more life out of it
Aug 11, 2007 | Hitachi PJTX100 Multimedia Projector
Sony KF50we610 blue dots and blue cloud
Check the optical block repair at sony's warranty website...
Could be the problem they have been covering it under a recall of sorts. $1250 for the optical block and they are only doing it until the end of the year so don't waste any time
May 03, 2007 | Sony XL-2100U Projector Lamp for...
Optoma HD65 DLP Projector Logo
279 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Electro Med Services...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
