Question about Sony FD Trinitron WEGA KV-24FS120 24" TV
I accidentally plug in my 100 volts Sony Trinitron T.V to 220 volts
  • 998 Answers
It has a varistor it is the protection of your tv against high voltage if over voltage is apply it will blow following the fuse. varistor is connected parallel to the ac supply replace it but dont forget to replace the fuse replace it to.
Posted on Oct 14, 2010
  • nina_begelfo Jun 14, 2011
    What kind of varistor I need to solve this problem?
How to fix couple of DELL desktops where I plugged them into 220 volts Power supply when they were set for 110 volts? More details below.
you could try replacing the power supply. if it still does not work, you probably fried the processor or motherboard. (or both). just make sure the replacement power supply has the same type of connectors on the power leads to the motherboard, hard drive, etc.
Aug 15, 2015 | Dell OptiPlex Computers & Internet
110 volts, rated TV was plugged into 220 volts power supply. Now when it was plugged into an 110 volts supply its not getting on? What could be the causes? and please suggest solutions.
It probably fried the power supply in the TV unfortunately. If the electrical surge stopped there then it should just be a matter of swapping out the power supply. Provide a make and model of television and I will see if I can help find one with instructions on how to change it.
Nov 24, 2012 | Office Equipment & Supplies
I plugged 110 volts xbox 360 into 220 volts outlet. and it's dead. what will i do?
Unless the item has internal fuse, it is burned up.
Look for product manual.
Many times, there is a glass fuse rated for unit voltage.
Replace fuse.
Each fuse has specific markings.
Oct 17, 2012 | Microsoft Xbox 360 with Kinect
I accidentally plug my aiwa excelia cd player model xc-003 to 220 volts instead of 100 volts. Iheard a small popping sound when i plug the unit to 220 volts.
If you're lucky you'll have just blown the internal fuse.
You need to remove the cover and look for the little glass fuse on the PCB where the power cord comes in. If it has blown then look at the metal cap on the end of the fuse and is should tell you what rating it is (2A etc). You should also check to see if any other components appear damaged before replacing the fuse.
May 03, 2011 | Aiwa Audio Players & Recorders
My drier 110 volts was accidentally plugged to 220
The least of your problems would be a burnt out relay or internal switch which can be replaced at reasonable expense. In a worst case the motor or heating element "fried" and it'll be cheaper to buy a new dryer.
BTW 110 and 220 plugs are entirely different and a 110 plug cannot be plugged into a 220 outlet.
Apr 16, 2010 | Whirlpool LGR5636L Gas Dryer
120 volt to 220 volt plug
it is sorry that the clock has been damged by high voltage so , it can not be repaired but you can replace the entire set
thank you
May 15, 2009 | Sony ICF-C318 AM/FM Clock Radio ( White )
110 sony flat tv was plugged in 220
change the regulator of your tv and check also the resistor value 2.2 5 watts or lower value.
May 09, 2009 | Sony FD Trinitron WEGA KV-21CL10 21" TV
The power supply of my pioner dvd was burn
Hi
check all semiconductor in the power board and look for a shorted and open parts! then replaced the defective parts.
Thanks!
Dec 05, 2008 | Televison & Video
BOSE DOESNT TURN ON AFTER PLUGGING TO A 220-240V PLUG AND ITS ONLY 120 VOLTS
It sounds like you hav blown a fuse. Hopefully just a fuse, connecting a 110 to a 240 will hurt.
Most equipment survives short term high voltage but sometimes it just can't take it.
if it's not the fuse then it's very likely damaged the power supply which will require the expert help of a technician..
good luck !
Ps the 321 is a very nice bit of kit..
Mar 30, 2017 | Bose (321GS) System
Sony FD Trinitron WEGA KV-24FS120 24" TV Logo
98 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
