Question about RCA D52W19 52" Rear Projection Television
Wen i try to turn it on the power button lite will come on for a couple seconds and go off it will do that three times then quit and thats it
  • 998 Answers
One of your convergence ic is shorted try to locate the shorted one and replace it.
Posted on Oct 14, 2010
When I try to send a fax I get a redo message and no pages are sent...i have sent many faxes to this number....a message appeared after one page was scanned that said to prress clear and srop...i could not...
Please reset the Printer by following these steps:
Switch the Canon MX310 off using the "Power" button, then push the "Stop/Reset" button on the control panel. Hold the button down for about five seconds.
Push the "Power" button while holding "Stop/Reset." Hold down both buttons for five seconds.
Release "Stop/Reset" while holding down the "Power" button.
Push "Stop/Reset" twice while continuing to hold the "Power" button. Release the "Power" button. The power light will turn green.
Once the light is steady green, push "Stop/Reset." Wait about three seconds and push it again. Wait three more seconds and push it one final time, for a total of three times. The power light will turn orange.
Push the "Power" button, then lift the MX310 cover open.
Remove both ink cartridges and wait 10 seconds. Replace the cartridges and close the MX310 cover. Wait 30 seconds.
Push the "Power" button. Wait a few seconds to allow the printer to fully power down, then switch the Canon MX310 back on using the "Power" button.
Feb 27, 2011 | Canon MX310 Office All-In-One Printer
Our Cannon ip90 says the waste ink tank is full and will not print. I know there are ways to reset the printer to print but I could not find the right one for this printer
Hi! My name is Mace and I'm here to help.
There are two ways to fix this waste ink tank error.
The first is to clean the waste ink tank. There are absorber foams located under the cartridge carrier when it is resting. You can simply lift up this absorber foams using a tweezer an clean this on running water and soap. Once dry return it back.
Reset the Printer. This is the last and final fix to your problem.
1. Turn off the printer...press and hold the resume/cancel button... then press and hold also the power button..
2. Release the resume/cancel button while holding still the power button.
3.(While still holding the power button)...press three times the resume/cancel button
4. (After pressing the resume/cancel button three times)...release the power button
5. Wait for a couple of seconds.. when the led stops blinking and turn green..Press the resume/cancel button four times.
6. Press the power button...some functions will be perform before the printer return to menu selection mode..
7. Turn off the printer wait for 5 seconds, then turn it on and try printing.
I hope that is the best solution to your problem. Thank you for using Fixya.
Jan 10, 2011 | Canon PIXMA iP90 InkJet Printer
How do I reset the Waste Ink Counter on my Canon iP90 printer?
HelloFollow these steps
7. Turn off the monitor wait for 5 seconds, then turn it on and try printing..
Hope that solve the waste ink absorber in your printer..
If you find this solution helpful..would you be kind to rate this solution and vote for this on the help below..thanks..
Jan 05, 2011 | Office Equipment & Supplies
Waste ink absorber almost full. How do I correct this?
there are two ways you can remove the error message from your printer..
the first is to reset the printer and the second is to replace the waster absorber. If the reset thing did not work for your then you'll be spending money to replace the absorber.
How to reset? follow these steps
Aug 03, 2010 | Canon PIXMA iP90 Mobile Printer
Waste ink absorber full
the first is to reset the printer and the second is to replace the waster absorver. If the reset thing did not work for your then you'll be spending money to replace the absorber.
Jun 02, 2010 | Canon PIXMA iP90 Mobile Printer
My 2nd samsung R519 laptop makes a buzzing noise and freezes wen not connected to power supply. Stops and starts every couple of minutes and lasts for a couple of seconds, very annoying!!
RAM is corrupted...i guess...
do this...
remove the power supply (both the power adaptor and battery)
keep pressing the power on button of the laptop...for some time....
install back the power and start...
let's c if this works...
Dec 21, 2009 | Computers & Internet
Dec 11, 2009 | Canon PIXMA iP90 Mobile Printer
Lcd quit working
There is a 95% chance that your powerboard needs to be upgraded with a few newer-better components.
I repair many gateway boards on ebay and this is a common occurence.
There is also a slight chance that a bulb is weak and is causing that effect.
If you unplug the vga cord while it is on, let it sit about 30 seconds till the power light turns to amber and then plug the vga cord back in you may get the desktop to flash on for a second or two.
It would have to be taken apart and the boards looked at to get a better idea.
If you do take it apart, send me a picture of the board to bammbamm@ptd.net. I may see a problem
Fran
Mar 29, 2009 | Computers & Internet
Hp 4365us will not power up at all-ac adapt ok--removed ans reseated batt/hd ????? Charging lite is on but can't start
Remove battery and power adapter.
Press power button a couple of times and then hold it down for about 6 seconds.
Then just plug in the ac adapter, keep battery removed, and try to turn on the laptop
Mar 20, 2009 | HP Pavilion ze4365us Notebook
RCA D52W19 52" Rear Projection Television Logo
23 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
