Question about Frigidaire GLTF1040A Front Load Washer
GLTF1040 - Cold water not entering machine. Hot water working fine. No changes in the house plumbing. The machine did not spin on regular wash heard a humming sound.
    President:
  • 2,468 Answers
Either the cold water solenoid isn't operating or the hose inlet screen is plugged by lime build up from hard water,remove the cold water hose and inspect this screen for blockage,as for the non- spinning condition, it should give you an error code to help trace this problem
Posted on Oct 14, 2010
  • Kiernan Flynn Oct 14, 2010
    How do you run a diagnostic to find error code?
  • danny Hendrickson Oct 14, 2010
    the diagnostic code sheet should be under the top cover lid on the left side wall near the top of the machine in an envelope
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
Cold Fill Washing Machine Does Not Get Hot
Do y7ou have 2 hoses at the back of the machine one for cold water and one connected to the hot water tap of the house. If not then you have a cold water in only. If you have 2 hoses have you connected the hoses into the machine correctly Have you checked to see if your machine has a heating element under the bowl for heating the water. As an appliance shop to verify if you have by the model number of the machine. otherwise you have a cold washing machine and unless you can plumb hot water to it that is all you will have.
May 29, 2013 | Siemens Washing Machines
Can we operate our WFS1273BD washing machine on cold water only? We are on instant gas hot water and have gone through a 45kg bottle in 3 weeks. We have lived in this house before and the washer is the...
ABSOLUTELY! Purchase a 'Y' adapter from your local hardware store and attach the hot and cold lines on the washer to the 'Y' attached to the cold faucet. You won't be able to wash in warm or hot without changing the hoses, though.
Aug 17, 2011 | Washing Machines
My daughter has moved into a rental house with a very small Whirlpool front loader. There is no model number or manual, and her email is not working. She would like to wash in cold water as is our...
delicate is typically always only cold
the other 2 are usually warm
if you could reach the faucets where the hoses attach to you could turn off the hot water faucet assuring it would only had cold water going into it
Gene
Aug 11, 2011 | Whirlpool LHW0050PQ Front Load Washer
Washer does not allow hot water to enter machine when you press the heavy duty button. Regular warm cycle or hot works fine. Replaced the water valves, main control panel.
This is a common question we face daily. Certain washing machines allow hot water to enter only during certain cycles. Others allow hot and cold to enter intermittently. Consult your owner's manual to be absolutely sure about this. If you're sure the machine isn't working the way it used to--or should--try these tests:
Is the hot water turned on? If not, turn it on.
Is the washer getting cold water but no hot water? If so, check to see if the control panel
settings are correct.
Thanks for writing to Fixya.com and I am Aparajita. I will be assisting you today.
Mar 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
Hot water on cold washes
To solve this problem simply reverse the water hoses from the way that they are set up currently. Then do a test again to make sure that when you select HOT you are getting HOT.
Nov 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Lg washing machine wft855a top loader
Following up my comment from yesterday, I took the machine apart and discovered that the black rubber cover on the valve that releases the cold water had perished and cracked, and wasn't opening properly.
I tested the hot and cold solenoids and everything checked out ok. Was just the cold valve sticking.
The wash cycle was working because I was using hot/warm water. As the rinse cycle needs cold water to get started, it was not working and the rinse and spin cycles wouldn't complete.
I have swapped the valves over for now (put the working hot one on the cold side and am using cold water only). It's working while I order a replacement...
Sep 07, 2007 | LG WFT1071TP Top Load Washer
Frigidaire GLTF1040A Front Load Washer Logo
66 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
