Question about MicroBoards PF-2 InkJet Printer
PF-2 "singulator problem.
My PF-2 began to drop several disk at once tonight. The "singulator" I guess that is what it is called, moves rapidly back and forth several times each time a disk about to print. I now have to feed one disk at the time. After printing the disk the singulator will rapidly move back & forth maybe 4-5-6 times so if you have several disk loaded it will begin droping 3-4- or 5 very quickly. I don't know if there is an adjustment I can make or if it is a problem withthe board?
    Problem Solver:
  • 30 Answers
That issue typically is caused by a defective spring that can be easily replaced. Microboards sells these springs. Microboards techsupport number is 952-556-1639.
Posted on Jun 17, 2008
You need to replace that part. My company had to do it last year, and we need to do it again soon. It breaks down easily and will work like that.
Call Microboards. They'll send you a part (you'll probably have to pay for it - ours was under warranty) and show you how to install it.
Posted on Jun 03, 2008
Why does my PAC unit continuously flash PF at random and simultaneous intervals?
Wild guess this is a portable air machine? with a tube out a window? Wild guess, there's a condensate "leak" where it shouldn't be. The tank drain might be blocked for some reason. or level of the machine or coils are dirty in spite of the filter.
Dec 22, 2014 | Filter Heating & Cooling
What is a PF kit
This is a "Paper Feed" kit and comprises several small pieces including rollers, springs and friction separator pad. Some models have several of these and will be named "PF1 kit", "PF2 kit" etc normally one for the manual feed tray and one for the paper drawer.
If you look at the front of the paper drawer, you will see a spring loaded friction pad in the centre used to hold back all but one sheet of paper. Directly above this in the printer chassis will be a loose rubber roller assembly which grabs the sheet of paper. together, this collection of parts is called a "PF kit".
The printer memory counts the number of pages fed and will count down an estimated useful life of these parts but this is at best a "guess". When they will no longer reliably feed fresh new paper without jamming, they probably need replacing.
May 30, 2014 | Brother MFC-8460N Laser Printer
Soap pump won't work...fill it, pump a thousand times, no soap
Common problem with PF faucets. Have read elsewhere that soaking the pump mechanism in water or other solution may fix. PF offers new pump mechanism for less than $8 but shipping is equal to that. That is a non-starter for me.
Stopped by Lowes this afternoon and when I told them the part I was looking for, they handed me the 931-0020 pump replacement saying that PF rep had dropped off a ton of them because they were having problems with the dispensers across thier line. And, get this, they gave it to me gratis!
I'll see how easy it is to pop out and replace tonight (instructions elsewhere on this site)
Jan 15, 2011 | Price Pfister Marielle Kitchen Faucet with...
My Lacrosse radio controlled clock (IECLR6) has begun performing erratically. First it set itself 35 minutes slow. A few days later it began advancing the time rapidly and continually. I removed the...
Mine does the same thing. I contacted the manufacturer and they told me there's nothing I can do to fix it. They suggested I return it if it's under warranty (which it isn't). With no warranty they said there is no way to repair it.
Aug 24, 2010 | La Crosse Radio Controlled Atomic Clock
Just moved, dryer won't tumble with a load. Error code PF
Did it get tipped in the move? I don't know about the specific model of Maytag, but on my old Kenmore the belt that ran the drum also had a wheel and kind of like a pulley that it had to seated on in order for the belt to stay centered on the drum and turn properly.I don't know how you get the shell off the front to get at the drum, the Kenmore had screws that you had to take out and lift the control panel off and then back to get at the inside. Sorry
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
2002 Chevy Venture - Wipers stopped in mid swipe and won't work. When placed in original position, they bounce slightly and won't wipe. The driver's blade had been loose several times and I tightened it a...
There should be a circuit breaker which shuts down the wipers when they are frozen. Sounds like the breaker didn't do its job and the wiper motor fried. My guess is it needs replacing.
Apr 29, 2009 | 1997 Chevrolet Venture
Microboards PF-2 won't load several cd´s in array
make sure the cartridge reader is no more then 1mm away from the cartridge as it slides past! also check the microswich which is ont he print head slider
Feb 09, 2009 | MicroBoards PF-2 InkJet Printer
Strange behavior
Initially, pls try disabling the hibernation feature of your computer.
Other than that, would appreciate if you can post back the make and model of your computer.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 04, 2008 | Computers & Internet
Panasonic SA-HT680 Home theater problem
Try these steps to reset the unit. I got these from the Panasonic Cust. Service # 1800-211-7262
1. Unplug the unit power.
2. Wait 2-3 mins before replugging the unit.
3. Turn it on.
4. If the display shows INIT / PLEASE WAIT, Press and HOLD the Tune Mode (STOP) button on the main unit. At the same time press #10 (Channel button) in the remote control. They have to be pressed & held simultaneously for atleast 5 seconds. Wait till the INIT / Please Wait display disappears.
5. Once the message disappears, RESTART the main unit by pressing the POWER button OFF / ON.
6. If it does not work, try several times. If it does not work, contact a local repair shop (call them to find out a repair shop near you). If the repair shop wont do it for you, call them back - thats what they told me.
Jan 19, 2008 | Panasonic SC-HT680 System
Iomega Firewire Hard Drive
There is an arm in a harddisk that holds the read-write heads. This arm can move the heads to tracks near the hub or near the edge of the disk. A normal hard disk is 5 inches (12.5 cm) or so in diameter. This arm, therefore, can move about 2 inches (5 cm) across the face of the disk. The speed at which this arm can move is astonishing. The arm is very light, and its actuator is powerful and precise. The arm can slide across the face of the disk hundreds of times per second if it needs to.
As the hard-disk arm moves back and forth rapidly, it sets up vibrations that our ears hear as sounds.
Dec 03, 2007 | Iomega 33089 250 GB Hard Drive
MicroBoards PF-2 InkJet Printer Logo
163 people viewed this question
Top MicroBoards Office Equipment & Supplies Experts
Starnley Johnwells
Starnley Johnwells
Don  Farrell
Don Farrell
Are you a MicroBoards Office Equipment and Supply Expert? Answer questions, earn points and help others
