Question about GE WSXH208A Front Load Washer
Washer is not draining properly. I cleaned out trap in front and cleaned out drain tube in rear of machine. Still wont drain. Clothes are soaking wet after cycle ends. Any suggestions?
    President:
  • 2,468 Answers
Have you checked the tub to pump inlet for blockage,as it may be before the pump itself,or [poissibly a weak pump
Posted on Oct 14, 2010
Washer leaking from bottom
If this is a front loader, you can take the front panel off under the door and inspect the bottom of the machine, there is a drain and trap with a large plug and the pump. Both need to be inspected and the drain should be cleaned and the debris removed from the trap. Get ready for lots of water though if you take the cap off the drain.
Feb 17, 2014 | Haier Washing Machines
Not spinning clothes properly.clothes coming out all soaking
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jan 23, 2011 | Hotpoint Aquarius WF220 Front Load Washer
De comes on the front and wont drain wm1814cw
the machine is clogged is th hose kinked,try to push the start buton again,you should hear the pump come on and try to drain.when it stops,push the button again,when the door unlocks take cloths out.And put 1/2c of bleach in drum and let it soak a few hrs.Now start washer no clothes this may do it,after cycle put clothes back in and run clothes through full cycle.When ther done.Put in Draino-Drain opener gell only and let it set over nite,then run heavy duty cycle this well clean washes and clean pump.
Jul 26, 2010 | LG WM1814CW Front Load Washer
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
My washer spins but doesnt spin on the final spin and leaves the clothes all soaked. it stops at 6 minutes on the final spin
is the machine draining correctly?
the machine will oftin stop if not doing so.
you can try cleaning out the coin trap/drain pump hose.
Jan 12, 2010 | Frigidaire Affinity ATF7000E Front Load...
My kenmore front loader wont spin fast. it will spin when the clothes are washing slowly but wont spin fast to get rid of the water so clothes stay soaking wet.
Check your drain and make sure it isn't plugged. If ok then remove the bottom panel on the front of the machine. Under it is the washer pump. The pump is either clogged or bad. The washer will not go into a full spin when the water isn't draining properly.
Sep 16, 2009 | Washing Machines
Draining issue
Mine is doing the same thing, and a new pump was put on it last month.
Nov 06, 2008 | Kenmore 4292x Front Load Washer
Cleaned trap; but still won't drain...
Surely your pump is clogged, which you should dismantle to check or replace.
A very important thing for all front loaders, all pockets should be checked before dumping in machine, small items should be placed in pillow case or special plastfc bag - so they don't slip into inner drum by accident, and clog pipes, etc.
Apr 27, 2008 | GE Energy Star WCVH6260F Front Load Washer
Clothes wet, doesnt spin fast
Check the drain spigot, where the drain hose attaches to the drain trap under the sink/tub.There may be a blockage in the spigot which is causing the water to drain very slowly and therefor not allowing the machine to spin at normal fast speed.
Oct 22, 2007 | GE Energy Star WCVH6260F Front Load Washer
Bad odor
This is the fix for the HE3T Sears front loading washing machine with a bad odor problem. We HAD this same problem but now it is fixed. You don't need to call the repair man, it's just a waste of time, money and endless frustration. Tools: 9/32 socket or T-20 torx head bit. Bunch of rags you don't want when you're all finished. *****UN-PLUG THE WASHER****** Lay on the floor in front of the washer and look under the lower panel. You will see three silver colored torx head screws, one on the left, right and center. Loosen these up with your socket or torx head wrench. Remove the lower front cover and set it aside. See all the wires? Did you make sure to UN-PLUG the washer? Good. Now look at the center of the bottom of the washer. You will notice a white cylindrical contraption. This is a drain trap where all of the junk from your washer gets hung up so it won't clog up the water pump that discharges the water from your washer. On the front of this drain trap is an access cap. BEFORE you open this place the rags under the trap, along the sides and under the washer. Trust me, you'll thank me later. Now open the drain trap access cap by turning it counter clockwise. Be prepared for some smelly water to come out, probably 1-2 cups worth. Once the water is drained, pull the trap completely out. You'll find the reason your washer stinks in the trap. We had a blob of black goo and a security label from an article of clothing we bought. That was the culprit. The drain trap was "trapping" all of this junk and getting real funky. Now clean the drain trap out with hot soapy water and a little bleach. Clean out the cylinder where the drain was. Wipe it out with a rag soaked in bleach and soap. Once everything is clean, replace the drain trap and tighten it down. Do not over tighten this or the seal may leak. Replace the front cover and the three torx head screws. Plug the washer back in. Run the washer through the SANITARY CYCLE with bleach. Your problem is solved
Feb 20, 2007 | Kenmore Elite 45986 Front Load Washer
GE WSXH208A Front Load Washer Logo
71 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
