Question about Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver
The chuck on my Dewalt 18v hammer drill will not stay tight. it loosens whether I am in forward or reverse
The chuck on my dewalt 18 volts hammer drill will not stay tight it loosenss whether i am in forward or reverse
Posted on Dec 05, 2010
  • nowell velasco Dec 05, 2010
    how can i repair or replace if ever
Why does my chuck keep loosening
First check whether you have the correct transmission setting for the bit you are using. This may affect the range over which the chuck operates and how it locks onto the bit. A conventional small-diameter drill bit may not work with a hammer drill setting. If the setting is correct, then either your hands aren't as strong as they used to be and you're not getting the chuck tight, or the chuck is worn and no longer has enough friction to hold.
Try this diagnostic: when you put a bit in, use a fine-tip felt marker to draw a line from the chuck collar (the part you turn to tighten or loosen) to the chuck baseplate. If the bit comes loose, check to see if the collar is still lined up at the same place relative to the baseplate. If it is, the chuck pieces are slipping inside; perhaps the transmission setting is incorrect for the bit chosen. If the collar has worked loose (the marks didn't stay lined up), the threading on the collar or the parts it engages could be worn.
May 23, 2014 | Dewalt 18v Battery Hammer Drill Dcd950...
Dewalt dc925 drill, the chuck jaws appear to be jammed tight shut and will not open. any ideas?
Hi, soak the chuck in crc overnight then put the drill in low speed and reverse. Hold the chuck by hand or with multi grips and pull the trigger. Hope this helps, regards Phil.
Jul 23, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
How do I take a bit out?
It is a keyless chuck. Put the drill in reverse (chuck should spin to the left when viewed from the back) and hold the main body area of the chuck with your hand while slowly running the drill. The chuck will open (unless it is broke) and release the bit. You do the opposite (slowing running the drill in forward) for tightening a bit in the chuck.
Jul 16, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
When in reverse chuck will not stay tight. (when removing screws or whatever chuck will loosen and let bit fall out)
I would start out blowing out the chuck with high pressure air because you might have some saw dust or other item causing friction that is allowing the chuck to move. Then I would spray a lot of WD-40 down the chuck to float any contaiminents up.
Jul 06, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
How do I change the drill bits and then tighten so the bits stay in the drill?
The chuck will not turn. So to loosen just turn the black plastic counter clockwise. The chuck will loosen. Or you can hold the black part on the chuck tight and put the drill in reverse and slowly squeeze the trigger and the chuck will loosen also. Do the opposite to put a new bit in. Put the drill in forward and hold the black part of the chuck and squeeze the trigger with the bit in place and it will tighten down on the bit.
Dec 16, 2010 | Dewalt 18 Volt Compact Drill Kit
Dc926 xrp hammer drill
ya its a chuck problem wont hold in reverse
Aug 10, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Chuck will not release bit
the Chuck should be 2 Part.
Use 2 pair of stillsons Or pipe wrenches, Tight On the 2 Chuck Parts, Crack in opposite Directions.
Alternative, Use Wrench On Chuck Jaw, Short sharp Blow With Hammer.
Mike @ compurepair.
Feb 28, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Chuck loosens
Chucks ARE meant to stay tight.
You also use drill to UNSCREW THINGS.
Nov 27, 2007 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Dewalt DC920KA Heavy Duty Xrp 18V Cordless Drill/Driver Logo
737 people viewed this question
Top Dewalt Drills Experts
Jim Thurston
Are you a Dewalt Drill Expert? Answer questions, earn points and help others
