Question about GPS
The wiring diagram for a Valet Car Alarm Model No. 711T
  • 47 Answers
SOURCE: car remote alarm system
THE VALET SWITCH SOULD BE IN THE DRIVERS KICK PANEL OR AROUND THE LOWER SIDE OF THE STEERING WHEEL
Posted on May 13, 2008
DarkmanUK
  • 94 Answers
SOURCE: Audiovox car alarm
You can get the installation and owners manual from here....
http://www.audiovox.com/webapp/wcs/stores/servlet/GenProductListCmd?type=model&catalogId=10001&storeId=10001&categoryId=APS155&langId=-1&page=&urlString=&productId=&brand=
Choose your model either th APS155 or the APS155CH
Then click on find manual, save it to disc for viewing or printing later.
Hope this helps.
Please remember to rate.
Posted on Aug 16, 2008
reynosaelect
  • 165 Answers
SOURCE: I need the diagram of alarm Prestige model: APS95BT3
go to google and write this> audiovoxtechservices press enter,and in that website request a password to get the instalation manual
Posted on May 11, 2009
  • 691 Answers
SOURCE: newly installed car alarm, LED in solid light n horn/siren blares
if you follow instruction properly than the alarm should work properly, Go over your wiring again 2-3 times make sure it make sense to you with the instructions. If it make sense than take the unit back and get another, can be faulty alarm.
Posted on Aug 26, 2009
  • 4350 Answers
SOURCE: I believe that the alarm
This sounds like a factory alarm, so it is unlikely that it is draining the battery. Much more common is alternator diodes. diagnosis is pretty easy for a shop, consider using one for this issue.
Posted on Sep 09, 2010
Reset remote for a Viper 300 alarm 2 button 2 way to start my ignition no valet switch
If you follow this diagram, you should be able to locate your Valet switch. I have seen other questions like this and I believe that they have hidden the function by using an exsisting switch, seldem used(?), in your console. All you should have to do is eith tract the wire that comes from the port on the alarm modules body, or apply +12vdc to one of the leads identified for the valet function.
Best of luck!
Viper 300 ESP Installation Manual Wiring Quick Reference Guide
Feb 12, 2016 | Viper Vehicle Parts & Accessories
Is there another way to program a remote start remote, The way its suppose to work doesnt.:door open, ACC on, push valet then again and hold. I think the door is not hooked up to read open.
563T Your Valet Alarm W/Remote Car Starter - Dr.Detail
www.drdetailshop.com > MAIN > YOUR VALET
Featuring: Viper, Hornet, Directed Amps, Viper Audio, Compx Subs, Your Valet ... 563TYour Valet Alarm With Remote ... A Free Wiring diagram, Installation parts
Sep 24, 2015 | Televison & Video
Excalibur alarm
hi
when you press the off button you have to remove the plastic cover under the steering wheel
remove the fuse from the red wire which is the power wire to the alarm
this will disable the alarm but you will be able to use your car
aries
Sep 15, 2013 | Vehicle Parts & Accessories
I bought my car used with an aftermarket prestige alarm w/ remote start. Battery and alternator went bad. They have been replaced. The car will not turn on and alarm remote is not working.
Locate a black push button switch under the dash or near the drivers side kick panel (older model), or the alarm has a push button LED light(newer model) or the Valet switch is in the antenna(newest model). Turn the ignition on, press and release the switch one time. This should disarm the alarm.
For programming: turn ignition on, press and release the valet switch three times: you will hear one chirp from the alarm, press the lock button on the remote. Press and release the valet one time, you will hear two chirps from the alarm, press the unlock button on the remote. Repeat as necessary. Turn igniton off to exit programming. Test remote for proper functioning.
Jul 16, 2011 | Prestige Appliances Vehicle Parts &...
Alarm is mal- functioning need to by pass alarm made by karr i think orinal equipment car starts sporatacly but have to play with remote to get it t o start help
It is simple just trace the wires - you will notice that installer will have teed in the wires – just cut off the T to the alarm - where you spot wires have been cut and attached with the alarm wires, just remove the alarm wires and rejoin the original wires and you won't face the alarm problem again.
A lot of owners coimment about Karr alarms and are so bad! Do yourself a favor and replace it (they comment like a personal opinnion).
I just got an accord and it came with a paper manual for the 2040. I had to reprogram the remotes though. Here is how Kar said to do it, you will have to fool around with it to figure out which buttons go to which channel, and I only had to press the button 3 times not on off to get it into the mode. So when it beeps once it meets its in channel 1, twice, channel 2:
* First, locate your valet switch. The valet switch is either going to be a small black push button, or a small silver toggle switch. The valet switch is either mounted on the plastic panel on the left side of the vehicle, near your left ankle as your sitting normally in the driver’s seat or directly behind the LED light.
·Turn your ignition key to the “on” position, or start the vehicle.
·Within 10 seconds
+ you have a silver toggle switch:
·Flip the switch “on” and “off” three times. (on-off-on-off-on-off) qIf you have a valet push button:
·Push the push button three times.
* The alarm system will chirp one time, letting you know that the alarm is in programming mode.
·Hold down the arm/disarm (center) button on the transmitter, until the alarm chirps again, confirming that the transmitter has been learned.
·Turn your ignition key off.
* The alarm will give one last chirp, letting you know the alarm has exited programming mode.
* The new transmitter is now programmed to the vehicle, and will arm and disarm the alarm system.
If you have problems programming the transmitter, please feel free to call at (949) 707-4210, or toll free at (800) 395-5277.
Here you can find your wiring diagram for Dodge Intrepid Car Alarm
Good luck.
Apr 20, 2010 | 1999 Dodge Intrepid
Lost my Viper key fob alarm is on and cannot start truck. any solution to disable?
Your alarm should have a button that was installed called a valet. What you want to do is put your key in the ignition turn it to the on position (Don't start it) then with the car in the on position hold down the valet button until the led light on the alarm goes solid and you should here the alarm beep twice. now your alarm will be disabled. To reable the alarm do the same thing.
Feb 12, 2010 | Viper Security and Remote Start System...
I needto know whwt wires go where???
Ok I know I have been bouncing around. My truch wants to start. I have had it in at leist 3 modes.
1. Valet. And didn't start.
2. Out of Valet.
3. Armed
4. Disarmed
still would not start. I can rule out the 95%. EGR, good, Fuel pump,New Fuel filter. New. Relay New. Fuse for cig lighter. New. All fuse at alarm Good .
Oct 07, 2009 | 742T Car Alarm - Keyless 2-4but Rem 4ch...
Need to turn the valet switch off On 1999 Nissan Maxima
Look for alarm Brain box and look for wires coming out black and red going to valet switch. to turn valet on turn ignition in ON position and press-switch or flip depending on the type of switch. If it a basic alarm just disconnect the main wiring harness to alarm box- unplug and the car should start. Good luck and thanks for using FIX YA
Jan 26, 2009 | 1994 Nissan Maxima
Car Alarm
Key on, push the button, if that doesn't work, please post with model #, you can find that by looking under dash and finding system...
Jan 23, 2009 | Vehicle Parts & Accessories
Uniden vs1100xr car alarm will not arm or disarm,have found valet mode button which sets & resets ok but remote just flashes led no chirps or lights flashing
I had the same problem with my vs1100xr. The remotes for these (and other) unidens have a rolling code. Seems to me that either the remote runs out of new codes and cycles back to the beginning, or the alarm base unit somehow loses track of the codes. Either way, the alarm base unit stops accepting the codes of your remote, and so needs to be purged of its code tracking memory - reset, if you like. This is essentially the procedure for training the alarm base unit to recognise new remote (and forgetting old remotes).
This procedure is:-
1) Disarm alarm, or if in valet mode, take it out of valet mode (push valet button 3 times)
2) Turn the ignition on and off 2 times within 15 seconds.
3) Put the alarm into valet mode (push valet button 3 times) within 15 seconds of completing step 2. Alarm should beep, and remote training has started.
4) Within 15 seconds of completing step 3, push the button (#1) of the first remote you wish to use for the alarm. Alarm should beep, indicating acceptance of remote. Repeat for other remotes you wish to use - up to 4 in total. (Once the first remote has been accepted, you have all the time in the world to make the alarm learn other remotes)
5) Turn ignition on and off to end remote learning mode. Alarm should beep 2 times. New remotes have now been learned and previous remotes forgotten.
Some of these details may vary from country to country - who knows. If this doesn't work, I suggest that you contact Uniden in your country to obtain the procedure. Took me a few tries to get the timing right, what with the valet button hard to get at and having only 15 seconds between steps.
Sep 28, 2008 | Car Audio & Video
GPS Logo
134 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
