Question about Canon PIXMA iP1800 InkJet Photo Printer
Printer is not printing the right colors.....what should be green is yellow and purple is dark pink. I installed a new black cartridge. I had also been using special effects recently but I changed them all back to the default.
I think you have problem with the Blue Ink. Try to deep clean a few times (+- 10 times) then do print test.
Posted on Oct 15, 2010
Hi people, so i want to install a aftermarket stereo in my 83 caddy sedan deville but i dont get the wires can somebody tell me do i need to use all the wires that the caddy has to put a after market...
Hi, please check to see if your colors match the ones below. If yes, then connect them to the aftermarket colors shown next. Assuming your factory installation has only four speakers, there should not be a lot of wires left over.
1983 Cadillac De Ville Stereo Wiring, aftermarket stereo wire
Car Radio Battery Constant 12v+ Wire: Orange, yellow
Car Radio Accessory Switched 12v+ Wire: Yellow, red
Car Radio Ground Wire: Black, black
Car Radio Illumination Wire: Gray (tape off), none
Car Stereo Dimmer Wire: Brown (tape off), none
Car Stereo Antenna Trigger Wire: Pink, blue
Left Front Speaker Positive Wire (+): Tan, white
Left Front Speaker Negative Wire (-): Gray, white/black
Right Front Speaker Positive Wire (+): Light Green, gray
Right Front Speaker Negative Wire (-): Dark Green, gray/black
Left Rear Speaker Positive Wire (+): Brown, green
Left Rear Speaker Negative Wire (-): Yellow, green/black
Right Rear Speaker Positive Wire (+): Dark Blue, purple
Right Rear Speaker Negative Wire (-): Light Blue, purple/black
Jun 25, 2011 | Car Audio & Video
I need to know what each color means on the existing radio stereo wires please... 1999 chev silverado.
I think this is the right table, but I don't know if it will display right. If not, go to http://www.installdr.com/InstallDocs/GM/PDF/460005.pdf
Typical GM Factory Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown Green
Sep 06, 2010 | 1999 Chevrolet Silverado 1500
I have an HP Phototsmart C4280 that is printing everything in pink. Any idea why?
This is the cartridge color problem, if you've refilled the cartridge, there must be proportion problem (magenta/yellow/cyan), or if you print dark colors like green or blue (which uses cyan and yellow mostly) and never use the red or other color (magenta and black), cyan and yellow might have finished up. If you can refill it proportionately, go ahead, but i would suggest you to purchase new cartridges and install.
Good luck. Thanks for using FixYa.
Jun 04, 2010 | HP PhotoSmart C4280 Laser Printer
What is the color code for the wires to the factory radio for a chevy malibu 2004
1989-1990 And Newer
AS VIEWED FROM MATING END OF CONNECTOR
A B C D E F G H I J
K L M N
F Not Used
H Power Antenna Turn On Pink (if available) Blue
Smaller sized
Mar 07, 2010 | 2004 Chevrolet Malibu
I need a factory radio wiring diagram for a 2006 chevy 1 ton just a am/fm cd player
1989-1990 And Newer
A B C D E F G H I J
K L M N
F Not Used
Smaller sized
Feb 01, 2010 | 2004 Mazda 3
Cd player installation
CAR WIRING
Constant 12V+ Orange To Radio Yellow
Switched 12V+ Yellow To Radio Red
Ground Black To Chassis Ground
Illumination Gray Orange/White on radio
Dimmer Brown n/a on radio
Antenna Trigger Pink Blue/White on radio
Left Front (+) Tan White on radio
Left Front (-) Gray White/black on radio
Right Front (+) Light Green Grey on radio
Right Front (-) Dark Green Grey/black on radio
Left Rear (+) Brown Green on radio
Left Rear (-) Yellow Green/Black on radio
Right Rear (+) Dark Blue Purple on radio
Right Rear (-) Light Blue Purple/Black on radio
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 29, 2009 | Clarion M235-RET CD Player
Printer is printing wrong colors
Make sure it's the right ink cartridge for that model printer.
Check if any of the colors is out
Try running a calibration on the printer to make sure heads are lined up properly.
Link to the manual - Aligning print cartridges is on Page 70.
http://h10032.www1.hp.com/ctg/Manual/c00905552.pdf
Apr 06, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
1998 dodge ram 1500 4x4 stereo wiring
glad you posted what colors you do have , cause 2 resources didn't match ,actually 3 , i did find a match to your colors was a 97 year model premium radio, so we have a match .....
black/ light green = ground
dark green = left front spkr +
purple = right front spkr +
blue/white = right rear spkr -
brown/blue = left rear spkr -
brown/yellow = left rear spkr +
blue/orange = right rear spkr +
black/yellow = park lamps
brown/red = left front spkr -
orange = dimmer signal
pink = fused battery +
green/red = radio choke relay
red/white = fused ignition
blue/red = right front spkr -
cheers
djmac62 is also an excellent answer
Jan 10, 2009 | 1998 Dodge Ram 1500 4WD
Oem Radio installation
*** 91 park ave with delco bose =
black = ground
dark green = lights on input
grey = panel lights
pink = on input
yellow = power input
orange = battery power input
nca = shield ground
tan = left fr spkr +
orange/black = left & right spkr -neg
lite green = right fr spkr +
nca = shield ground
dark blue = right rear spkr +
dark green/yellow = right & left spkr - neg
brown = left rear spkr +
purple/white = display dim output
pink = vehicle speed input
**** 91 park ave without delco bose =
grey = left front - neg
tan = left front + pos
dark green = right front - neg
light green = right front + pos
black = ground
dark green = display dim signal
grey = panel lights
pink = power antanna
yellow = ign input
light blue = right rear - neg
dark blue = right rear + pos
yellow = left rear - neg
brown = left rear + pos .
there YA go
Dec 27, 2008 | 1991 Buick Park Avenue
PROBLEMS WITH COLOR NOT PRINTING
pictures are coming out with a green tint
Aug 01, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Canon PIXMA  iP1800 InkJet Photo Printer Logo
172 people viewed this question
old marine
old marine
