Question about Siemens Euroset 2015 Corded Phone
How do I store numbers on the phone - Siemens Euroset 2015 Corded Phone
  • 410 Answers
Type the number on the screen & go to the option menu and save it,,,,,,,,,,,
Posted on Oct 14, 2010
I have a Sanyo Compander plus mode; CLT-1861 bouth 15 years ago. I lost the instructions on how to program phone numbers into it. Will it be possible to get them back................ Thanks. Carole
to store numbers.
1 press memory.
the talk indicator flashes.
the dialing buttons light for approximately 10 seconds.
2 dial the phone number you want to store.
3 press memory.
4 press a number ( 0-9 ) to assign a memory location number to the phone number.
a beep sound. the dialing button light goes off.the phone number is now stored in the hanset memory.
5 repeat step 1-4 to store other numbers or to change previosly stored numbers.
my name is jean( french for john) e-mail is morin.j2@videotron.ca
Sep 18, 2011 | Cell Phones
Lost the manual how do I store phone numbers
Press STORE button, LOCATION? shows in display, press the memory location (0 to 9 or quick buttons A to C) then press STORE button again. Dial the number you wish to store and then press STORE again. Use the number keys to enter the name of the person you have just stored and press STORE again. I hope this was useful.
May 13, 2010 | General Electric 29581GE1 1-Line Corded...
Store a number in memory of Cable and Wireless CWP220
One-touch memory buttons (M1, M2, M3):-
-Lift handset.
-Press STORE button.
-Enter phone number to be stored (up to 16 digits).
-Press STORE button again.
-Press either M1, M2 or M3 button, depending on where you want to store number.
-Replace handset.
Two-touch memory buttons:-
-Lift handset.
-Press a keypad number 0-9, depending on where you want to store number.
-Replace handset.
Apr 12, 2009 | Lands Phones
Cable & Wireles cwp 500 phone, how to store numbers
To Store a number in the upper memory:
1.Press STORE/IN button (the STORE/IN indicator light turns on).
2.Dial the number to be stored.
3.Press the STORE/IN button again (the STORE/IN indicator light blinks).
4.Press a Memory Location button to store the number.
5.Record whose phone number it is on the memory directory (located under the plastic cover on the front of the unit).
TIP: If you make a mistake while entering a number into memory, wait 15 seconds for the feature to turn off, or press STORE/IN twice.
Mar 28, 2009 | GE 2-9438C Corded Phone
How to set up Speed Dial on a Uniden phone?
My Mom had this same problem.   I found these instructions on Uniden's website (uniden.com) under the "Owner Manuel" section.
Here you go - good luck!
Using the Speed Dial Memory
Storing Numbers in Speed Dial Memory
Your cordless phone can store up to ten numbers (up to 20 digits each) in the speed dial
memory. To store number in memory:
1) When the phone is in standby, press [memory]. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number.
 (To enter a 2-second pause between numbers, press [redial/
pause]. Each pause counts as a digit. )
3) Press [memory] again.
4) Select the speed dial location where you would like to store the
number ( [0] to [9] ). You will hear a confirmation tone indicating
that the number has been stored.
NOTE:
• Storing a number to a speed dial location will
overwrite the any previously stored number without
warning.
• When storing numbers into memory and the handset is idle (i.e., no key is
pressed) for more than 0 seconds, it will beep rapidly, and then the phone
will return to standby.
Dialing a Stored Number
1) When the phone is in standby, press [talk], and listen for a dial tone.
2) Press [memory] and enter the speed dial entry ([0] – [9]) that has the stored number
you want to dial. (If you enter a digit that does not contain a stored number, the
handset will beep rapidly, and the phone will not dial.)
Chain Dialing
The speed dial memory is not limited to phone numbers. You can store any number (up
to 20 digits) that you need to enter once your call connects. This is referred to as Chain
Dialing. An example is a frequently refilled prescription number. Store your pharmacy
phone number in one speed dial and your most frequently refilled prescription number
as another speed dial. To use, once you ring your pharmacy's automated prescription
line, simply press [memory] and the speed dial number where you stored your account
number.
Erasing a Stored Number from Memory
1) With the phone in standby, press [memory] twice.
2) Press the number of the speed dial entry. A tone indicates that the stored number is
erased from memory.
Jan 11, 2009 | Uniden Cordless Phone
Uniden 900MHz phone model EX17960A
Your cordless phone can store up to ten numbers in the speed dial memory.
1) When the phone is in standby mode, press the memory key. The talk/batt low LED flashes.
2) Use the keypad to enter the phone number; each number can be up to 20 digits.
7
3) If you need the phone to pause during the dialing sequence, press
the redial/p key to insert a two-second delay between the
numbers. You can enter multiple pauses to increase the delay.
4) Press the memory key again.
5) To store this number as one of the ten speed dial numbers, enter a
digit from 0 to 9. If there is already a number in that speed dial
setting, it will overwrite the previously stored number without
warning. You will hear a confirmation tone indicating that the
NOTE: When storing numbers into memory, if the handset is idle
(i.e., no key is pressed) for more than 30 seconds, it will beep rapidly, and the phone
will return to standby mode.
1) When the phone is in standby mode, press the talk key, and listen for a dial tone.
2) Press the memory key and enter the speed dial entry (0-9) that has the stored number you
want to dial. (If you enter a digit that does not contain a stored number, the handset will
Nov 13, 2007 | Lands Phones
Storing numbers in memory
1) Pick up the handset and press the STORE button
2) Dial in the number you wish to store
3) Press the STORE button again to indicate that you have completed the number
4) Press the location where you want to store the number (i.e. 1, 2, …9, or 0)
Oct 21, 2007 | Uniden EXP4241 (050633300466) Cordless...
Storing memory numbers
1 - Lift the receiver and get the dial tone.
2 - Hit 'Store'
3 - Enter the number you wish to store in the phone
4 - Hit the store button again
5 - Hit the memory button you wish to store the number into
6 - Hang up!
This should store the number wherever you want to put it. Remember if you want to store it in one of the 'lower' positions (second line of the memory index card) push the 'Shift' button before you push the memory button for that location.
Oct 06, 2007 | GE 2-9438C Corded Phone
ConairPhone SW324WCS
I just had same problem and went conairphone site and found model sw322 that looked about the same. I downloaded the manuel and it worked for my phone. Here it is. MEMORY FEATURE To Program Your CONAIRPHONETM telephone is equipped with 10 memories for programming your most frequently dialed telephone numbers. You can store up to 16 digits in each of the numeric keys (0 through 9), by following the steps outlined below: 1. Lift handset (releasing hook switch). 2. Press and release STORE key. 3. Press the keys for the telephone number you wish to store. 4. Press and release the STORE key again. 5. Press the keypad number (0-9) you want that telephone number stored in. 6. Your number is now stored. 7. To change a stored number, repeat the same process. The new number will store over the old stored number. A Memory Index card is provided for your use in writing down the person?s name. To Retrieve Memory Numbers Keypad Memories: To retrieve numbers stored in the keypad, pick up the handset and press the MEM (Memory) key. Then press the keypad number (0-9) which stores the telephone number you want to dial. Your call will be automatically dialed.
Jul 12, 2007 | Conair SW324WCS Corded Phone
Storing Speed Dial Phone Nmbers
Emergency/quick dial numbers: Pick up handset, push store, enter the phone number (it will not call the number), push store again, Push A,B or C. hand up handset. Frequently called numbers, pick up the handset, push store, enter the phone number, push store again, push key pad 1, or 2, etc. for memory location. Hang up handset. How to change a stored number. just repeat the sequence. How to clear a stored number, repeat the storage skip step 3 (do not enter the phone number). How to correct an error while storing, just hang up and repeat.
Feb 26, 2007 | GE Telephone pr521w
Siemens Euroset 2015 Corded Phone Logo
490 people viewed this question
Top Siemens Lands Phones Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
