Question about HP PSC 950 All-In-One InkJet Printer
Dosen't pick up paper
My hp 950 series all in 1 dosen't pick up the paper to print can anyone help me?
  • 3 Answers
Please check on the right side of your printer when the printer is open for a smooth rubber like thing the size of the thumb and try wiping it with a wet cloth severally. its the separation pad. Once cleaned it will allow the paper to pick up well.
Posted on Jun 02, 2008
Paper not pick up
Hi Akhtar Siddiqui
I would be happy to help you with your Laserjet 1020. I understand the printer will not pick up paper when you try to print. Please use the following document to troubleshoot the issue:
HP LaserJet 1018 1020 and 1022 Series Printers Printer Does Not Pull Paper...
I hope this helps, but if the issue persists, what you can do, is use the following link to create yourself a case number, then call and it may help speed up the call process:
Step 1. Open link: h22207 www2 hp com
Step 2. Enter Product number or select to auto detect
Step 3. Scroll down to "Still need help? Complete the form to select your contact options"
Step 4. Scroll down and click on: HP contact options - click on Get phone number
Case number and phone number appear.
Best of luck.
I work on behalf of HP.
Jul 27, 2015 | HP LaserJet 1020 Printer
How do I print postcards on HP PSC 950
Hello!
Here is your solution to print postcards size.. 1. Select your image and press mouse right . 2. Select print and select your printer. 3. There may be many sizes indicate there... but you must select 4x6 or 5x7 as it is postcard size. 4. Now select your paper quality (eg. Photo paper plus glossy ) 5. Press print.... That is it .... good luck
Sep 08, 2011 | HP PSC 950 All-In-One InkJet Printer
My HP laser printer 1300 had a paper jam
When printing or copying, paper will not pick up or feed into the HP LaserJet 1000, 1200 or 1300 series product causing paper jams or wrinkled output. Symptoms are as follows:
  • The pickup roller will spin and try to pick paper.
  • The paper will partially feed into the product accompanied by a crackling, crunching noise then jamming.
  • The paper may feed all the way through the paper path accompanied by a crackling, crunching noise. The output will be skewed and wrinkled.
SOLUTION: Reposition the black Mylar light shields back into the proper position.
  1. Unplug the power cord from the product.
  2. Remove the paper and paper input tray.
  3. Slide hands, palms side up, into the paper input tray cavity (see Figure 1) until the fingertips reach the end of the cavity. Figure 1: Paper input tray cavityc00068598.jpg
  4. Bend fingers up to push the black Mylar light shields back into place. The proper position of the black Mylar light shield will be flat.
  5. Reconnect the power cord.
  6. Print a self-test/configuration page to verify product is functioning correctly.
Feb 24, 2011 | HP LaserJet 1300 Printer
My HP PSC 950 printer copies and scans in color but prints in black
normally when the color tank runs out 2 things happen.
1] not all the colors run out at the same time.
2] the printer complains the tank needs to ne replaced.
If the tank isn't dry, it could simply be clogged. I like to use rubbing alcohol or distilled water and a cotton swab.
Dip the swab, & then gently apply pressure in the nozzles.
I would expect to see the clog before the cleaning process, some color to come off & when pressed on a paper towel, hopefully 3 bands.
Jul 05, 2008 | HP PSC 950 All-In-One InkJet Printer
HP PSC 950 problem
Look in the printer software on the computer for paper size settings. If that doesn't help go into the settings menu on the printer it self. If you have HP Setup Assistant on your computer, use that to reset up your printer to your computer.
May 30, 2008 | HP PSC 950 All-In-One InkJet Printer
HP 950 PHOTO PRINTING PROBLEM
try to check the paper size from the printer and be sure that the paper with the same size...
the check out if the printer pick up the paper correctly
Regards...,
Feb 17, 2008 | HP PSC 950 All-In-One InkJet Printer
Hp psc 950
Reinstall the driver. There is a possibility that the divice driver is corrupt.
Jan 08, 2008 | HP PSC 950 All-In-One InkJet Printer
Print 5x7 invitations on my 950?
Change the size of the document on word to a standard sized document - such as 8-1/2 x 11. Then when you go to print the documents, set the printing preferences to print on 5x7 paper. That should do the trick.
Oct 04, 2007 | HP PSC 950 All-In-One InkJet Printer
HP PSC 950 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
