Question about LG LHD45EL Dehumidifier
CH 01 Code and it will not work. Is it broken for good? Thanks!
    President:
  • 2,468 Answers
If it still runs,but collects no water,its low on refrigerant R-134a this is very common on units 2 to 3 years old,but to get a top off of refrigerant(which is LEGAL) it can be very expensive,I usually just install a bullet piercing valve on the hi and low side and top it off,as this is a cheaper way than pulling it completely down and finding the leak because it most likely will need it again in a year or two
Posted on Oct 14, 2010
I have a code on the screen CH 01... What do i need to do to get it to run again???
CH 01 Indicates that water collection tank is full and needs to be removed & emptied. Turn the unit OFF and unplug it, before removing the bucket.
Sep 21, 2011 | LG LHD45EL Dehumidifier
The dehudifier won't come on in and in the digital display the message CH 01 comes up. Any idea what the problem is?
CH 01 usually indicates that the filter is dirty and needs to be removed and cleaned. Turn the unit OFF and unplug it, before removing the filter. Never operate the unit without the filter in place.
Thanks for choosing FixYa.
Sep 07, 2011 | LG LHD659EBL Dehumidifier
I have a lg dehumidifier ld650eal. it has a code of ch 01. the bucket full light flashes. if it is off and i turn it on it will start for a second or two and shut down and display the ch 01 code.bought 13...
Unplug power cable,then take of front panel (2 screws).Then on left side on pipe se cliped sensor on pipe ,unclip then put in hot wather for 5 sec. Then put all back together and plug cable power and turn ON.That works on my Dehumidifier LG LD650EAL.
Jun 14, 2011 | LG LD65EL Dehumidifier
Hi, When I tried to start my dehumidifier, it won't work and indicate CH 01. The bucket is totally empty and in good place. What this CH 01 means?
Your model is no longer in manufacture or available. However, I was able to locate the Owners Manual for you. It does not list a CH 01 Error Code, but does list other reasons why your unit want turn ON.
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=LHD45EL&matchedModelCode=1000001989&searchEngineModelCode=LHD45EL&targetPage=support-product-profile&initialTab=documents#
In the past, I have recommended turning the Master ON/OFF Switch to OFF and unplugging the unit for 12-15 minutes. This will give the unit time to hopefully, reset itself. Then Plug the unit back in and turn the Master ON/OFF Switch to ON. Set the humidity control as you normally would. If it successfully reset itself, it should operate normally.
If you continue to have problems, contact LG Customer Support at 800-243-0000.
Hope this helped you to solve the problem.
Apr 14, 2011 | LG LHD45EL Dehumidifier
What is a code CH 01
Had same erroe code in 2008. CH 01. Bucket Full light was flashing, but it was empty. Would not start. Called customer service and was advised it was most likely a compresser problem. In that compressoe was still in warranty took it to a lacal service center. Compressor was Ok, but had to replace Evap Thermister Board and Sensor. $120.00 in parts and $50.00 labor.
I am not an expert.
Good luck.
Oct 26, 2010 | Comfort-Aire BHD-501 Dehumidifier
Code CH 01 is showing where the humidity level is suppose to be. The machine turns on & shuts off immediately
Had same problem in 2008. Had to replace Evap Thermister board and sensor. Parts $120 Labor $50.00.
I am not an expert. Good Luck!
Aug 30, 2010 | Comfort-Aire BHD-651 Dehumidifier
Error Code CH 01
I have a Comfortaire BHD501 dehumidifier. A couple weeks ago I noticed ice building up on top of the unit,so I unplugged it to defrost. I plugged it back in and it worked until I noticed the "CH" "01" code. It would run a few seconds then shut off with that code showing. I took off the front of the unit and noticed rust on some of the metal parts. Then I took the cover off the circuit board for the front read out. I noticed corrosion on some of the solder points. When I looked closer at the plastic cover for the circuit board I noticed a small burn mark. The water from the melting ice must have run behind the cover and shorted out the circuitboard. At this point I don't know if new boards are available.
Jun 26, 2009 | Comfort-Aire BHD-501 Dehumidifier
LHD65EBL Code CH 01
I had the same problem, and I wound up calling LG's customer support line. The rep I spoke with says that the "CH" code means that the internal thermostat is not able to accurately read the air temperature, and the unit will require servicing.
She gave me a couple of numbers for local folks, and I'll call them in the next day or so, but I'm thinking that this may not be worth the repair, unless it's pretty cheap: I bought the unit for under $100 less than 9 months ago, and I'm not eager to shell out a bunch of money to get it repaired.
Nov 02, 2008 | LG LHD65EBL Dehumidifier
Tank full light flashes & unit will not operate, but is attached to a hose
If you get a fault code CH 01, check the posting for that solution and see if it helps.
Sep 07, 2008 | Comfort-Aire BHD-501 Dehumidifier
Stopped Running - Control Panel CH 01
All, I had this same problem as well. I called the LG Support Line and they told me the unit needed to be serviced. I went through the motions of getting the service providers and what have you, but I wasn't going to go through with it because the closes service provider was a 45 minute drive. I posted how disappointed I was because I had only had the unit for a year, but could not find my earlier post.
Anyay, I am glad I went through the motions, because a few days later LG called and told me they would be shipping me a refurbished replacement. Wow. That was a treat. They shipped me a refurbished unit and had me send the old one back. I did not have to pay a dime. The sent me the Fedex shipping label via email and I called Fedex and they came by and picked it up.
I cannot remember if I had registered the unit when I initially purchased it. Sometimes I won't do that because it seems only to serve as a license to sell me stuff. They took down all my contact information and sent me the unit so I don't know. I would simply encourage everyone with the CH 01 error code to give LG a call via the support number from their website at lgappliances.com. Good luck!
Jul 22, 2008 | LG Dehumidifiers
LG LHD45EL Dehumidifier Logo
235 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
