Question about Nintendo Wii Console
How do I reset my Wii gmaes so there is no information on them?
  • 104 Answers
When you turn your wii on and get to white screen go to the bottom right hand corner (or left depending on make) then look for memory go in there and boom it schould show you your data then just delete whatever
Posted on Oct 15, 2010
Wii nintendo bought used how do i reset it
Method One: The Soft Reset The soft reset is the easiest way to reset the Wii, and the least intrusive. There are two ways to perform the soft reset, either using the Wii remote or the button on the console.
To reset the Wii using the Wii remote, begin by pressing the home button (the small button with a house on it). This will bring up a menu screen. Next, move the cursor to the button labeled "Reset" on the screen. Press the "A" button on the remote to select the reset option. This will reset the system.
If the Wii remote is not responding, users can also reset the Wii using the button on the main console. First, locate the button labeled "Reset"--it's on the front of the console, beneath the "Power" button. Press and hold the "Reset" button for two seconds, then release the button. This should reset the system. Users should remember that resetting the Wii will shut down any running programs immediately and destroy any unsaved data, so only reset the Wii if it is causing problems. However, resetting the Wii will not alter any information stored on SD cards.
Method Two: The Hard Reset If the soft reset doesn't fix the Wii, users can also perform what's known as a "hard reset." A hard reset involves disconnecting the Wii's power supply and must be done manually--there are no pre-programmed buttons on the Wii that will perform the hard reset.
To begin the hard reset, find the "Reset" button on the front of the console. Press it for two seconds, then release (this performs a soft reset on the device). Next, press and hold the "Power" button. Continue holding this button until the light in the button switches from green to red--this means that the Wii console has shut down. Now, unplug the AC power adapter cord from the wall outlet or surge protector as well as from the console itself. Allow the Wii to remain like this for five minutes.
Once five minutes have passed, plug the AC power adapter cord back into the console, then connect the other end of the cord to an AC outlet. Press the "Power" button to turn the Wii on. The system should now be running smoothly.
Method Three: Reset Factory Controls Sometimes, Wii users might want to return the system to its original, factory-shipped status and remove any personal data. Nintendo especially recommends doing this before selling or gifting a used Wii to someone else. To perform a factory reset, also known as formatting the system memory, go to the Wii menu and select the "Wii" button, then select "Wii settings." Click on the blue arrow on the right-hand side--this will bring users to a page called "Wii System Settings 3." Select the option labeled "Format Wii System Memory," entering the parental controls PIN if requested. Finally, select "Format" to complete the factory reset. This will remove all hard-drive data from the Wii, and such data cannot be recovered, so users should only perform a factory reset if they're sure they want to do so.
Jan 30, 2017 | Nintendo Video Game Consoles & Games
How do you bypass the wii update to play the gmaes
The simplest thing to do is to use StartPatch, if your Wii is running System Menu 4 or higher, or StarFall if you're running System Menu 3.2. (To check your system menu version, go to you Wii Settings; the version number will be on the upper right.)
These applications can apply various modifications to your Wii, including one that will allow you to play import games and another that turns off the annoyingly repetitive system menu background music. There is also a modification that prevents the Wii from checking to see whether a game disk includes a system update. If you use StartPatch/StarFall to install this modification, you will no longer have game disks insisting on updating before you can play them.
It should be noted that these applications, since they rewrite your system flash memory, can be considered somewhat dangerous.
You can play it safer with Gecko OS, which lets you play import and update-insistent games without altering flash memory. It has been found that at least one game, Prince of Persia: The Forgotten Sands, Gecko fails on.
Jan 06, 2014 | Nintendo Video Game Consoles & Games
Cannot remember old password ,How do I reset so as to use with info that I have entered.in system
Here is how to reset your Nintendo Wii:
1. First, the easy way. A soft reset of the Ninetendo Wii. If you Nintendo Wii has just started acting up and there is no reason to perform a hard reset then follow this instruction. Simply press the reset button and hold down for 2 seconds on your Nintendo Wii Console.
2. Now, for the more advanced hard reset. Interestingly, the Nintendo Wii has NO hard reset facility to be accessed through the machine or via buttons. The ONLY way to hard reset your Nintendo Wii is to UNPLUG it for 5 minutes. Once it is unplugged it resets itself and your badly behaving Nintendo Wii should be restored.
Note: By hard resetting the Nintendo Wii, it will not delete any information on the SD Card that is used for storage. If you wish to delete this data, stick it into a computer with a multi-media card device or a digital camera and reformat it.
May 30, 2011 | Nintendo Wii Console
Wii will not progress past the initial menu page
Give me thumbs!
Aug 22, 2010 | Video Game Consoles & Games
Wii console will not power on. is there anyway to
Hi there, you could try the following:
  1. Try unplugging Wii from the power for a full 2 minutes, plug back in and power up and test (This resets the Power Adapter).
  2. If this does not resolve it then it may need to be repaired so contact Nintendo here.
Please see here for for information on Power issues with the Wii.
Cheers
Apr 03, 2010 | Nintendo Wii Console
Game will not eject
Try unplug the AC adapter from power cord then wait 30 min and plug it again.If problem persist your Wii need service.
Nov 23, 2009 | Nintendo Wii Console
How do i factory reset ?
Another option to try is to go to the following:
Wii settings and press reformat wii system memory.
The last part of wii settings and press reformat wii system memory.
The last part of wii settings and press reformat wii settings and press reformat wii system memory.
If all else fails you can ask nintendo, you can call them at 1800-255-3700
I hope this helps and good luck.
Oct 28, 2009 | Nintendo Wii Console
I need to know how to reset my wii system?
there are 3 ways to reset,1.press the reset button on the console.2.go to the last page of settings and press system reformat.3.eeek.pull the plug out for 5 minutes.and plug it in again.
Apr 08, 2009 | Nintendo Wii Console
Wii not reading discs
try cleaning the disks and make sure your inserting the disks with the wii on. you can also try resetting it there is a soft and hard way to reset it.
to soft reset your wii with the power on press and hold the reset button for 2 seconds( the second button from the top of the console)
The way to hard reset your Nintendo Wii is to UNPLUG it for 5 minutes.
if that doesn't cure your problem then i suggest taking it to a store and getting it fixed or if its still under warranty to return it to the manufacturer
May 12, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
32 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
