Question about Whirlpool Duet GHW9150P Front Load Washer
My controls seem to be locked up. I can't get it to turn on or start a new cycle. It is just stuck on locked.
    President:
  • 2,468 Answers
Try first to unlock it by unplugging the unbit for 5 minutes,then if no dice,remove the top above the door and there is a release cable you can pull to release the lock
Posted on Oct 14, 2010
Can't select cycle and won't start.
you didn't mention the model number , but I can tell you some models wont start if there's no rinse agent in the dispenser , also for stuck controls a trick that works is to find the breaker for washer in your power panel and click it off for one minute then back on this will force a reset of controls
Jan 22, 2016 | Dishwashers
Whirlpool adp 6515ix dishwasher start button is flashing in 4 time cycles-what does this tell me please. None of the manuals indicate what the flashing could be signalling.
Error CodeConditionCheck/RepairShop PartsClean light blinks 7 timesHeater circuit failure. Control didn't detect the expected rise in water temperature.Check the heating element and related components (wiring and control board) in that circuit.
Heating element, Electronic control board, Thermistor, Circuit wiring
Console light blinks rapidlyThe control detects a stuck button on the control panel.A failed control panel or a malfunctioning electronic control board can cause this code. Check the buttons on the control panel using a volt/ohm meter. In most cases, the control panel must be replaced. If that doesn't solve the problem, the electronic control board might be at fault.
Control panel, Electronic control board
Start/Resume light blinks slowlyIf the dishwasher door is opened or power is interrupted during the cycle, the dishwasher won't start again until the door is detected as closed and the Start/Resume button is pressed.Check the door latch and switch assembly. A failure in the Start/Resume button also can cause this problem.
Door switch assembly, Control panel, Electronic control board
Clean light stays onThe dishwasher won't start a new cycle unless it detects that the door opened after the previous cycle.Turn off power to the dishwasher by shutting off the breaker and restarting. If that does not work, the door switch assembly is stuck and must be replaced.
Control lock LED is on but not accepting key pressesAccidentally turned on or control detected keypad problem.Press the Heated Dry key for 5 seconds to turn off control lock feature. If that doesn't work, replace keypad.
Keypad
Sanitized LED blinks at end of cycleControl couldn't confirm that the dishes were sanitized.Check voltage to the dishwasher and the temperature of incoming water. Check the diverter motor, the heater and the OWI/thermistor.
Diverter motor, Heater, Thermistor
May 23, 2015 | Whirlpool Dishwashers
The locking mechanism seems to be stuck on my Frigidaire front loading washing machine. When the door is closed it buzzes and machine won't start.
Hello Craig, thank you for your post!
I understand that the door lock on your washer is stuck and washer will not operate. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately 2 minutes and turn on the washer. Select a normal cycle and verify if the washer will start. If your washer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Thanks for allowing me the opportunity to assist you!
Oct 27, 2013 | Frigidaire Washing Machines
Does this dishwasher have a lock button?
Hello - Yes, it does have a child lock control. It is design to prevent children from accidently change the dishwasher cycle or starting the dishwasher. It locks the dishwasher controls by pressing and releasing the DELAY TIME icon for 3 seconds. Do you see an indication lock light on your dishwasher illuminate? It will usually appear when the controls are locked and no new selections can be made until the lock is released. To unlock the controls, press the DELAY TIME icon under the indicator light goes out.
Oct 13, 2012 | Electrolux EWDW6505GS Fully Integrated...
Control lock light is on - The washer won't work. I unplugged overnight, and the light is still on when I plugged it in this morning. When I press Control On, HOld start, and Pause at the same time, the...
Press and hold the End of Cycle button for 3 seconds or until the Control Locked indicator turns off to unlock the control. You have to check the control for any stuck button and unstuck it if the control still cannot be unlocked with the End of Cycle button. The control needs replacing if no stuck button is found and unlocking it is not possible. Please let us know if that is the case and if you need further help. Just indicate the exact model number of the machine.
Jul 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
EPIC MFW9700S Front Load Washer: washer stuck on control lock...
Press and Hold down the END CYCLE button for 3-5 seconds. Code will turn off and you can start your washing machine.
May 18, 2010 | Maytag EPIC MFW9700S Front Load Washer
Control Locked
look closely at the machine console, the most right set of buttons, the lowest possible one is the control lock button, youll need to hold it in for 3-5 seconds to unlock the control panel(child lock)
May 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Control lock light
someone has enable the child lock feature. One of the buttons should say hold 3 secs for control lock under its normal function description. Hope this helps
Jan 01, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
