Question about Cameras
I have a 1 year old Tamron 18-250mm lens attached to Canon eos 400d. Have been using with no problems untial last few days. The auto focus only works intermittently - causing me to miss several shots. If I twist the manual focus ring a couple of times - this restarts the auto focus for several shots but I then might have to repeat process later.
    Brigadier General:
  • 11,967 Answers
Try cleaning the contacts on the camera body and lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Posted on Oct 14, 2010
I have a canon 100mm macro EF 2.8 lens. When I attached it today to my camera (EOS 400d) it will not auto focus correctly. The working sound it makes is even a different sound to the normal focusing...
Your 100mm lens autofocus not working.it may be due to autofocus flex cable inside the lens damaged. It is replaceable part. You may have to contact service technician. However when you switch to manual mode it should focus & click. Try it.
Sep 29, 2017 | Canon 75-300mm f/4-5.6 III USM EF Lens
Canon rebel xti focus issues
this does not seem to be like a problem in settings
please use a different lens and try the same
Aug 15, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
My Canon 400D camera keeps coming up with error 99 I have cleaned the contacts on both my camera and my Tamron 28-200 lens.At first i thought it was my camera but I tried it with another lens and it...
Hi turn on the camera with the lens on set to tv and a iris of f22 and use the stopdown button if the lens stops down the lens is ok if not the lens is faulty may need a intuper replaced
Jan 11, 2010 | Tamron 28-200mm F3.8-5.6 for EOS
Have a two month old 18-270 Tamron lens. Used it a
If it's only two months old then it's still under the manufacturer's warranty so send it back to Tamron. I can't tell you where to send it as you haven't said which country you're in. Tamron value their reputation and usually provide excellent after-sales care.
If you're in the UK you additionally have Sale of Goods Act protection for up to six years in England and Wales and five years in Scotland. Either way, the Act allows you to demand a full refund or replacement from the retailer; I'd suggest a refund as bad lenses often come in batches and a different supplier is less likely to have one from the same production batch.
Note that any attempt to fix the lens other than by normal use of the lens and camera controls may completely remove your warranty benefits or consumer protection.
Oct 26, 2009 | Cameras
Need Help, the auto focus of my canon 400D won't work.(I can still shot with manual focus)
Try cleaning the contacts on the camera body and the lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Oct 14, 2009 | Canon EOS 400D / Rebel XTi Digital Camera...
Sometimes when i'm taking picture my flash wont stop blinking for a few seconds.
The 400D uses flash assisted focusing. In low light conditions the auto focus cannot get a focus lock so it pops the flash a few times so the lens has a chance to focus. You will notice this will go away when in the manual focus mode (the switch on the side of the lens).
The only way around this problem (as people in a photo think the photo has already been taken and looks away when the camera actually takes the picture) is to use a hotshoe mounted TTL Canon Speedlight (430ex or 580ex) which use an infra-red focussing beam.
Sep 04, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Canon eos 400d
Contact Canon - some makes of lens which are not Canon are not electronically compatible for various reasons, and can actually damage the camera. So, get using the phone and check if it is compatible before doing anything else - but personally, I would not use the lens until I find out
Jul 02, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Attaching it to a Canon EOS 400D REBEL XTI
Totally different lens mounts, you might be able to get an adapter ring, but it wont function amazingly. Honestly, you're better off just selling this lens and buying a Canon 70-300 instead.
Apr 30, 2008 | Tamron 75-300mm f/4.0-5.6 LD Lens for...
Tamron lens for Xti?
if it is an auto focus lens that works on one eos camera, it should work on almost all of them. the only known exception is that some high end extenders will not fit the eos1dmarkII as it protrudes into the opening too far.
but a good rule is that if it fits without any obstruction issues, it should work. try cleaning contacts on the lens and camera body. if that doesn't fix it, talk to Tamron. you can use it manually, but will not be as easy and you would get less predictable results.
my suggestion is to always go with lens from camera maker.
sounds like there is an issue with the tamron lens. not the camera.
good luck
mark
Dec 16, 2007 | Canon EOS 400D / Rebel XTi Digital Camera...
AF 70-300 causes error 99 in my Canon 300D
This is usually a torn flexible circuit or binding aperture in the lens. It'll have to go to a repair shop for replacement. About a $80 job.
Nov 04, 2006 | Tamron Zoom Telephoto AF 70-300mm...
Cameras Logo
67 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
