Question about Compaq NC8000 Notebook
Battery Power My nc8000 battery does not charge. I got this computer of a friend and they said they thought it did not have a battery as it always turned off when unplugged from main power supply. They thought a battery was an extra they had to buy. I have checked and it has a battery. The battery light will flicker a couple of times then nothing. In control panel it shows as no battery present
  • 868 Answers
Replace the battery
Posted on Jun 02, 2008
My friends nephews dsixl was left overnight out in the rain. My friend' s nephews parents gave it to my friend to fix because it would only turn on and play when plugged in to the adapter. At first my...
I would say it's done. With the battery in and the water, most likely it's shorted the device out. Applying AC now could be a fire hazard, you could have a complete melt down.
May 27, 2013 | Computers & Internet
How to charge ups for pc's
Your PC connection must always come via UPS, and your UPS will always keep charging.
UPS Power cable should be connected to DC, and your PC power cable should be connected to UPS.
And this way your PC will always be safe.
Nov 06, 2009 | QVS NetStar (UPS650A) UPS System
HP Compaq nc8000 - display will not stay lit
can you take out your battery and plug in the power to check if your battery is faulty? if yes, you need to replace it.
May 29, 2009 | HP Compaq nc8000 Notebook
Laptop won't turn on with either adapter or battery.
if you take the battery out completely and just have the mains adaptor connected i take it its not powering on either ?
Apr 11, 2009 | HP Compaq nc8000 Notebook
Computer shuts off
Maybe it's your power supply, I suggest you get a voltmeter and check the voltage on the power supply.
Good luck
Nov 07, 2008 | Acer Aspire 3000 Notebook
HP nc8000 shuts down after 10 seconds
try pushing on the upper right corner of your laptop, above the home key, does it start up again?
If so its the maxim chip
if not take one so dimm out and dissable wireless.
Could also be your battery not charging because a battery or power cord malfunction.
Oct 21, 2008 | HP Business Notebook NC8000
BATTERY NOT PRESENT
If that is an old battery , it only means that the battery is already dead and needs a replacemenet, but if that battery is new make sure that the battery is charging if its not changing the prokblem can be the battery still....
Hope that helps...........
Sep 18, 2008 | Compaq NC8000 Notebook
My nc8000 shuts down after few seconds and starts after power plugged in or battery inserted
Hi Turecki, It's a moderately easy fix for this common issue with HP/Compaq Laptops. Simply go to ebay, purchase an "inverter" board built for a NC8000 laptop can range from $10-$50 just purchase one with a minimum 6 month warranty. Its about a 0.5 inch by 15 inches. Unscrew all of the tiny phillips screws located and hidden behind black rubber covers on the LCD screen. Pop off the plastic LCD cover and replace the inverter board located at the bottom of the LCD (plug & play). Put it all back together and voila...problem fixed.
Have fun and practice some repair skills.
~Alex
Sep 13, 2008 | HP Compaq Business nc8000 Notebook
AC Power and Battery Problem.....
Sounds like the battery or possibly the charging circits themselves are the problem. Can you try turning on the laptop with just the power cord in and no battery?
Aug 20, 2008 | Compaq NC8000 Notebook
Hp nc8000 power issue
Many of the power jacks also contain switch contacts that allow the adapter to power both the laptop and the "charging" system. I would suspect that one of the leads had either been broken or at least detached from the pc board. This laptop needs to be dis-assembled and the power jack repaired. Worse case will result in the replacement of the jack or the repair of the board if that part has been cracked.
Dan
May 13, 2008 | HP NC8000 (DE503AV) DVD+RW Burner
Compaq NC8000 Notebook Logo
162 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
