Question about Sharp Office Equipment & Supplies
I have a Sharp copier MX 2300G.It has developed a problem and it instructs me to call service under this code L4-02
  • 46 Answers
The tray one lift up motor (angles the paper up to the feed rollers) has a plastic shaft that can twist and will need to be replaced. "To enhance the strength of the output shaft gear against twisting, the material of the
output shaft gear has been changed. Along with the material change, the colour has also
been changed from Beige to White." new part number is CCOVP1607FC438
Posted on Oct 14, 2010
How to fix the sharp MX-3100N printer? the message on the screen is install the developer.
Developer unit is not detected , or developer is depleted ( which is very bad , because it could mean that it spilled inside your copier , it is very abrasive)
try removing and re-installing the developer unit , and maybe try using another unit for control,
could also be your harness, see if plug of developer unit is plugged into mainbord
Feb 23, 2015 | SHARP MX-3100N
Sharp MX-M232D Copier call for service F2-40
Problem with your toner supply .... you're not getting enough toner mixed into your developer tank. Sometimes the cartridge will empty out without the machine giving warning, or the CRUM counter chip on the back of the cartridge wil zap out or wind down to zero. Try replacing your toner cartridge, if that doesn't clear the code your developer mix is out of balance and may need to be changed and reset.
Aug 19, 2013 | Sharp MX-M232D Multifunction Copier
Unlock password Problems for sharp mx-2300g
Here's a link to a site that has the user manual. It's free to download, but you'll need Adobe or Nitro PDF reader to open it. I found the instructions for the same thing for my copier in its' manual. Good luck!
Aug 31, 2012 | Copystar Sharp MX-2600N Copier : Sharp...
After installation my sharp ar-m420u copier mx-2300g displays error codes L1-00 and F2-00
L1 MEANS U HAVE TO REMOVE THE SCANNER LOCK WHICH IS ON THE SIDE OF THE MACHINE.
F2 MEANS SOME PROBLEM WITH YR TONER CATRIDGE.CHANFE IT AND SEE
Jan 11, 2011 | Sharp AR-5320 Black and White Copier
The Sharp MX2700 Colour machine has come up with an error code DK, what does this code refer to.?
This code means the Black Developer powder has reached the end of its life A service call will be needed to replace this for good black prints
Apr 26, 2010 | Sharp MX-2700N Color Copier
I have sharp mx 2700 .mechine is working but no display in the screen.i can make a copy .no display in lcd screen
Most likely the back light is blown out....try shining a flashlight down on to the displat and you might be able to see the display but this will reqire a qualified tech to repair
Mar 22, 2010 | Sharp MX-2300N Color Copier
Sharp mx-2300N printer error maintenance required code vk
VK means black developer has reached end of life. You can safly carry on using the copier with this message displayed but over time the copy quality may slowly degrade. You will need to call a Sharp authorized dealer to replace the developer in the developer unit.
Dec 23, 2009 | Sharp MX-2300N Color Copier
Sharp-MX2700N Maintenance Code VK
VK = 100,000 pages printed on the developer counter or 715,000 revolutions of the developer unit (as mixing can occur even when pages are not being printed). Developer can break down over time and or the seals can be damaged - so service by a technician is indicated. If maintenance was recently performed and the developer replaced then the counter needs to be reset.
Feb 04, 2009 | Sharp MX-2700N Color Copier
133 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
