Question about LG LDN22735 Stainless Steel Bottom Freezer Refrigerator
Freezer not cold enough
I have the freezer set to -6 degrees F but it will not keep ice cream hard. I have had the temperature control replaced under the factory warranty but the problems persists.
  • jaslporter Jun 03, 2008
    The temperature inside the freezer will get down to about 5 degrees F and will go as high as 16 deg F. This is plenty cold for ice cubes and frozen goods that have a high water content. Ice cream, in this case more like ice milk--low fat ice cream, needs to get down well below zero F. The cheap old Sears unit that was replaced by the LG had no problem getting down to -10 to - 15 degrees. I suspect that something is pouring excess heat, either the ice maker or the frost free. I just don't have a good way to test that theory.
    An expert whose answer gotĀ voted for 100 times.
  • 210 Answers
How is the other products in the freezer. Some ice cream doesn't get too hard and it is because of the ingridients. I can't remember now, think it is the sugar content. If your ice cubes are solid you should be ok.
Sgt 48
Posted on Jun 03, 2008
Freezer Constantly Runs.
Do you know what design temperature is for that freezer? Some are meant for 0 degrees others for -10 or 15. I would say you are trying to maintain -10 for a food freezer and trying to keep ice cream frozen. Ice cream freezers need to be colder than food freezers. I know it sounds dumb but look it up. Check the door gaskets to see that there is no leakage and the surrounding area should be no higher than 75 degrees, (otherwise it\'ll run all the time). Hope this helps and good luck.
Apr 20, 2014 | True 72 cu. ft. Commercial Freezer TS-72FG...
My freezer does not keep my ice cream hard, yet it freezes meats, etc. without a problem. What is wrong?
You don't note whether or not you've adjusted the thermostat. Ice cream (and juices) requires at least zero degrees, if not minus 5 degrees, for storage. Meats, fish, bread, etc. can become rock hard at much higher temperatures. Try setting the thermostat lower.
Jun 07, 2011 | Freezers
Freezer 8 degrees, fridge 48 degrees. Fridge fan was replaced and worked ok for a month.
Sounds like both are about 8 degrees over optimum, if your thermometer is accurate. Can your freezer keep ice cream hard?
Usually, one control affects the temps of both chambers, and the other affects the balance between them. Your balance seems ok, so if you're unable to set it to run longer/colder overall, and your ice cream is not firm/hard, this could indicate a more serious problem. Airflow is important, so you should avoid loading in such a manner that restricts airflow within either side, and verify that fans run when door switches are actuated.
May 18, 2011 | Samsung RS265LABP Side by Side...
Hi. My fridge is about a month old. Although we have the freezer set at 8 degrees (the warmest it will set to), the freezer is extremely cold. Ice cream becomes rock hard (we can't even cut it with a...
This is not an adjustment issue, this is a malfunction issue. If you have a thermometer that you can place in the freezer, as opposed to any temperature readings from the freezer itself, your temps would normally be around 0 degrees F. At the warmest freezer settings, you should be around 10 degrees, which would make your ice cream very scoopable. I would contact the store you purchased it at or Samsung for a refrigerator repair service as soon as possible before they tell you its no longer covered under warranty.
Oct 04, 2010 | Samsung RF265AA Bottom Freezer French Door...
Ice cream will not freeze, but will make ice cubes.
Actually, it's not as you think. Ice cubes are made between 0-4 degree Celsius and ice creams are frozen below -3 degree Celsius. Your freezer temperature may be between 0 and -3 degree Celsius and that is causing the problem. An ideal freezer should have temperature between -3 and -30 degree Celsius.
Apr 20, 2010 | Samsung RS2578BB Side by Side Refrigerator
What should the freezer temperature shouls be????????????????
Normally, freezers are at 0 degrees. If you have ice cream, shoot for -10 degrees.
hope this is what you are looking for.
Feb 21, 2010 | Nor-Lake Freezer Norlake Refrigeration 6'...
Freezer is no longer keeping ice cream solid/frozen
Ice cream is usually kept at -10 degrees to stay firm. Need to check temperature. Look at condenser coil for cleaning. This is usually the most simple and common issue. If not making the desired temp, and the temperature control is set for that temp, and compressor run constant, it is a refrigeration issue. If compressor does not run constant, then a control issue.
Jan 24, 2018 | True GDM-49FC Refrigerator Commercial
Freezer way too cold - ice cream hard as a rock
The freezer may get as low as -18 degrees F or 0 F this is the point when life and bacteria stops growing.
Ice cream shouldn't be that cold unless it is whipped with air.
Feb 27, 2017 | Kenmore Refrigerators
LG LDN22735 Stainless Steel Bottom Freezer Refrigerator Logo
188 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
