Question about Sony Playstation 3 (PS3) Console
My ps3 switched off and flashed red , tried switching off and on started up then done same again
    Problem Solver:
  • 19 Answers
You have the red light of death pal.
You will need to get it repaired in a local shop or ring playstation ..
Sorry i had same probelem .
Posted on Oct 14, 2010
Ps3 40gb fan test fail
you over heated it thats a temp fix it wont work again
Jan 25, 2012 | Video Game Consoles & Games
PS3 switched off during use, Red light flashing at front,can't get game out.Tried switching on while holding disc removal button,that did not work,left unit overnight to cool down,tried it again and it...
Sounds like a heat problem. You can either send it to sony and get it fixed for about $50. Or check out this youtube video below which has help many people through this problem.
Hope this helps, Nathan Taylor
Jul 18, 2011 | Sony Playstation 3 (PS3) Console
My PS3 (40Gb) has just shut down on me. I was playing COD Modern Warfare 2 when the PS3 just shut down and then beeped at me 3 times the red light started flashing and when I pressed the power area the...
Its called yellow light of death. Here is a link to my step-by-step instructions on how to fix.
http://www.fixya.com/support/t8396931-ps3_turns_ok_but_turns_itself_off_after
Feb 24, 2011 | Sony Playstation 3 (PS3) Console
My ps3 turned off during a game, when you try and turn it on the light on the power switch goes green for about 3 seconds then switches off again and has a red flashing light
Your PS3's problems are actually being caused by a connection error between the hard drive and motherboard. Without a correctly working hard drive connection your PS3 is unable to function and goes into shutdown mode, with the flashing red light warning.
So in order to fix the blinking red light on your PS3 you will need to repair the connection between the HDD and the motherboard.There is actually a rather simple way that you can do this yourself; while your PS3 console is switched off, locate the hard drive enclosure on the end of your console. Remove the plastic cover plate, then using a screwdriver unscrew the hard drive itself from its socket. Carefully remove it completely, then put it back in again. Tighten the holding screw, then restart your PS3
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
I was playing online when suddenly my ps3 switched off, when i tried to switch it on by touching the touch sensor when the indicator was red, it turned green normally as soon as the normal green and blue...
This is a rare problem ............ i faced similar kind of problem
i solved my problem with the help this repair guide you can also try this out i hope this will help you a lot .......
all the best
Click Here
Dec 11, 2010 | Sony Playstation 3 (PS3) Console
Red light flashing
With the older FAT PS3, if you turn off the system from the main switch in the back then back ON. The red light should stop flashing. But if you do this and Power On again. Watch the color of the light. If it goes from red to yellow then flashing red light. Then this is the YLOD = Yellow Light Of Death. This can only be fixed by shipping it back to Sony ($150.00) or void the warranty and take the system apart to reflow the motherboard. There are guides on Youtube if you have the right tools. I have done the reflow many of times.
Oct 30, 2010 | Sony Playstation 3 (PS3) Console
PS3 shuts down playing game
this is called the Red Light Of Death it can be caused by the following
1.overheating
2. hardrive coruption or needs to be reset back into the system
3. the soldering on the motherboard of the console needs to be reflowed by a local repair shop that specialisez in PS3 gaming consoles
hope this gave you some information and good luck!
Jul 22, 2010 | Sony Playstation 3 (PS3) Console
I switch my ps3 on and start to play a game and then sfter about 10 mins it switces itself off and a red light flashes, then the same happens again after i switch it on. could it be overheated?
sure, it can. try cleaning your coolers : turn the on off switch behind the console OFF, then hold the eject button and , HOLDING THE EJECT BUTTON,switch the on off key ON (behind the system). it will clean your coolers.
Jul 11, 2009 | Sony Playstation 3 (PS3) Console
Solid red light, flashes green when i turn it on then it dies.
Pretty much the only thing worth trying is starting the PS3 without the hard drive.
If it doesn't work it's more than likely a GPU problem that only Sony can fix.
Either way check out my guide here for tips and details.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Feb 28, 2009 | Sony Playstation 3 (PS3) Console
Red flashing light on ps3
When the light flashes red and you ALSO see the green light on too this indicates that the system is getting hot and you need to switch off and let it cool down.
if you switch on get the beeps see yellow light briefly then flashing red only this indicates failure.
The system has shut itself off to stop further damage ..... supposedly caused by getting hot .. maybe fan failed .... only thing that can be done is to contact Sony for repair or replacement.
I know this post is old but thought the info could help others ...... I hope you returned your PS3.
Sep 27, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
